Home » Archived » BIRT » BIRT chart engine issue(client disconnect)
BIRT chart engine issue [message #891952] Tue, 26 June 2012 12:28 Go to next message
Can someone please help me with this error.
Jun 26, 2012 10:20:25 AM org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher renderReport
SEVERE: Engine exception
org.eclipse.birt.report.engine.api.EngineException: Failed to initialize emitter.
at org.eclipse.birt.report.engine.emitter.EmitterUtil.getOuputStream(EmitterUtil.java:82)
at org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitter.initialize(HTMLReportEmitter.java:352)
at org.eclipse.birt.report.engine.api.impl.EngineTask.initializeContentEmitter(EngineTask.java:2205)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:117)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.createReport(ReportLauncher.java:594)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.renderReport(ReportLauncher.java:541)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.run(ReportLauncher.java:455)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.main(ReportLauncher.java:104)
at org.eclipse.birt.report.debug.internal.core.ReportDebugger.start(ReportDebugger.java:39)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: java.io.FileNotFoundException: \new_report.rptdesign.html (A required privilege is not held by the client)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.eclipse.birt.report.engine.emitter.EmitterUtil.getOuputStream(EmitterUtil.java:77)
... 22 more
[b]
Jun 26, 2012 10:20:25 AM org.eclipse.birt.report.debug.internal.core.vm.ReportVMServer$1 run
WARNING: [Server] client disconnected[
/b]
Thank You
Tanny
Re: BIRT chart engine issue [message #891995 is a reply to message #891952] Tue, 26 June 2012 15:12 Go to previous messageGo to next message
What version of BIRT are you using and how do you call it?
Jason
> renderReport
> emitter.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> ... 22 more
> Thank You
> Tanny
Re: BIRT chart engine issue [message #892002 is a reply to message #891995] Tue, 26 June 2012 15:36 Go to previous messageGo to next message
Hey Jason ,
its 3.7.2
and right now I am just clicking on "Debug as" and then click on "Report"
because its not giving me any other option.
I am new to BIRT so Im still learning
Thank You
Tanny
Re: BIRT chart engine issue [message #892043 is a reply to message #892002] Tue, 26 June 2012 20:30 Go to previous message
Is this Java Code? If so have you setup a Java project?
Jason
On 6/26/2012 3:36 PM, tanmay varma wrote:
> Hey Jason ,
> its 3.7.2
> Thank You
> Tanny
Previous Topic:Custom Parameter Page in Run Time
Next Topic:How to override the function for the "Finish" button on a Data Source Wizard Page?
Current Time: Sat Jul 19 19:10:50 EDT 2025
Powered by FUDForum. Page generated in 0.03839 seconds
