Home » Archived » BIRT » Problem with Script Datasource(Getting error running a java script)
Problem with Script Datasource [message #891916] Tue, 26 June 2012 10:46 Go to next message
On BIRT version 3.7.2
I have encountered an issue when doing a data script birt report(My first one). I compiled and jarred the classes successfully. I verified that I have the most current version of the jar.
I created the following for open():
importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
prodDb2Test = new Packages.birtjava.tdcj.ProdDb2Test();
ntoNcrList = prodDb2Test.build();
fetch():
while(count < ntoNcrList.size())
row["email"] = ntoNcrList.get(count).getNeoEmail();
row["userid"] = ntoNcrList.get(count).getNeoNtouserid();
row["rptType"] = ntoNcrList.get(count).getNelRptType();
count++;
return true;
return false;
Additional information: Per other programmers here, I placed the jar file in the same location as the .rptdesign file.
When I did a Preview I encountered the following error:
The following items have errors:
ReportDesign (id = 1):
+ There are errors evaluating script "importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
Fail to execute script in function __bm_OPEN(). Source:
" + importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: TypeError: [JavaPackage birtjava.tdcj.ProdDb2Test] is not a function, it is object. (/report/data-sets/script-data-set[@id="8"]/method[@name="open"]#5)
Script source: /report/data-sets/script-data-set[@id="8"]/method[@name="open"], line: 0, text:
__bm_OPEN(). (Element ID:1)
Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "importPackage(Packages.birtjava.tdcj.ProdDb2Test);
count = 0;
count = 0;
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:99)
at org.eclipse.birt.report.engine.script.internal.DataSetScriptExecutor.handleJS(DataSetScriptExecutor.java:256)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:98)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open(ScriptDataSetRuntime.java:80)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.java:247)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:223)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1134)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_OPEN(). Source:
count = 0;
__bm_OPEN()
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:147)
at org.eclipse.birt.report.engine.script.internal.DtEScriptExecutor.handleJS(DtEScriptExecutor.java:90)
... 70 more
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.
__bm_OPEN()
at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:123)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:996)
at org.eclipse.birt.data.engine.script.JSMethodRunner.runScript(JSMethodRunner.java:138)
... 71 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: TypeError: [JavaPackage birtjava.tdcj.ProdDb2Test] is not a function, it is object. (/report/data-sets/script-data-set[@id="8"]/method[@name="open"]#5)
__bm_OPEN()
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoException(JavascriptEvalUtil.java:303)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:102)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:134)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:992)
... 72 more
Caused by: org.mozilla.javascript.EcmaError: TypeError: [JavaPackage birtjava.tdcj.ProdDb2Test] is not a function, it is object. (/report/data-sets/script-data-set[@id="8"]/method[@name="open"]#5)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime.java:3660)
at org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntime.java:3679)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3734)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3722)
at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime.java:2324)
at org.mozilla.javascript.gen.c30._c1(/report/data-sets/script-data-set[@id="8"]/method[@name="open"]:5)
at org.mozilla.javascript.gen.c30.call(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRuntime.java:108)
at org.mozilla.javascript.gen.c8._c0(/report/data-sets/script-data-set[@id="8"]/method[@name="open"]:0)
at org.mozilla.javascript.gen.c8.call(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.gen.c8.exec(/report/data-sets/script-data-set[@id="8"]/method[@name="open"])
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:95)
... 74 more
+ There are errors evaluating script "while(count < ntoNcrList.size())
count++;
return true;
return false;":
Fail to execute script in function __bm_FETCH(). Source:
" + while(count < ntoNcrList.size())
count++;
return true;
return false; + "
Error evaluating Javascript expression. Script engine error: ReferenceError: "ntoNcrList" is not defined. (/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]#1)
Script source: /report/data-sets/script-data-set[@id="8"]/method[@name="fetch"], line: 0, text:
__bm_FETCH(). (Element ID:1)
detail : org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "while(count < ntoNcrList.size())
count++;
return true;
return false;":
count++;
return true;
return false; + "
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:143)
at org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch(ScriptDataSetRuntime.java:103)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery.java:260)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch(OdiAdapter.java:226)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.doNext(RowResultSet.java:113)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.next(RowResultSet.java:91)
at org.eclipse.birt.data.engine.executor.cache.ExpandableRowResultSet.next(ExpandableRowResultSet.java:63)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.populateData(SmartCacheHelper.java:316)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.initInstance(SmartCacheHelper.java:285)
at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper.getResultSetCache(SmartCacheHelper.java:246)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init>(SmartCache.java:73)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.populateOdiResultSet(PassUtil.java:110)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:62)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.doSinglePass(PassManager.java:170)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareDataSetResultSet(PassManager.java:94)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.pass(PassManager.java:134)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateResultSet(PassManager.java:74)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.populateResultSet(ResultSetPopulator.java:198)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.<init>(CachedResultSet.java:195)
at org.eclipse.birt.data.engine.executor.CandidateQuery.execute(CandidateQuery.java:154)
at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java:226)
Caused by: org.eclipse.birt.data.engine.core.DataException: Fail to execute script in function __bm_FETCH(). Source:
count++;
return true;
return false; + "
__bm_FETCH()
... 87 more
__bm_FETCH()
... 88 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "ntoNcrList" is not defined. (/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]#1)
__bm_FETCH()
... 89 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "ntoNcrList" is not defined. (/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]#1)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c20._c1(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]:1)
at org.mozilla.javascript.gen.c20.call(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c10._c0(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"]:0)
at org.mozilla.javascript.gen.c10.call(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"])
at org.mozilla.javascript.gen.c10.exec(/report/data-sets/script-data-set[@id="8"]/method[@name="fetch"])
... 91 more
+ Data Set script method "Fetch" returned null; expected a Boolean value. (Element ID:1)
data.engine.BadFetchScriptReturnType ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Data Set script method "Fetch" returned null; expected a Boolean value. (Element ID:1)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:244)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.addException(ScriptExecutor.java:233)
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:165)
Caused by: org.eclipse.birt.data.engine.core.DataException: Data Set script method "Fetch" returned null; expected a Boolean value.
at org.eclipse.birt.report.engine.script.internal.ScriptDataSetScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java:153)
... 85 more
Is below the problem? If so how do I get around this?
Thanks for your help.
Re: Problem with Script Datasource [message #891994 is a reply to message #891916] Tue, 26 June 2012 15:11 Go to previous messageGo to next message
Carlos
Where did you put the jar?
Also change:
to
importPackage(Packages.birtjava.tdcj);
prodDb2Test = new ProdDb2Test();
Jason
> count = 0;
> fetch():
> count++;
> return true;
> return false;
> ReportDesign (id = 1): + There are errors evaluating script
> count = 0;
> count = 0;
> Script source:
> 0, text:
> __bm_OPEN(). (Element ID:1) Error.ScriptEvaluationError ( 1 time(s) )
> count = 0;
> count = 0;
> Script source:
> 0, text:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> count = 0;
> Script source:
> 0, text:
> __bm_OPEN()
> at
> at
> ... 70 more
> Script source:
> 0, text:
> __bm_OPEN()
> at
> at
> at
> ... 71 more
> Script source:
> 0, text:
> __bm_OPEN()
> at
> at
> at
> at
> ... 72 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 74 more
> ntoNcrList.size())
> count++;
> return true;
> return false;":
> count++;
> return true;
> return false; + "
> Script source:
> 0, text:
> __bm_FETCH(). (Element ID:1) Error.ScriptEvaluationError ( 1 time(s) )
> count++;
> return true;
> return false;":
> count++;
> return true;
> return false; + "
> Script source:
> 0, text:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> count++;
> return true;
> return false; + "
> Script source:
> 0, text:
> __bm_FETCH()
> at
> at
> ... 87 more
> Script source:
> 0, text:
> __bm_FETCH()
> at
> at
> at
> ... 88 more
> Script source:
> 0, text:
> __bm_FETCH()
> at
> at
> at
> at
> ... 89 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 91 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 85 more
Re: Problem with Script Datasource [message #892016 is a reply to message #891994] Tue, 26 June 2012 16:26 Go to previous messageGo to next message
Jason,
I placed the jar per another programmer in the same place as the .rptdesign that I created. Is there a better place to put it? Thanks.
Re: Problem with Script Datasource [message #892045 is a reply to message #892016] Tue, 26 June 2012 20:33 Go to previous messageGo to next message
Carlos
Take a look at this post:
http://birtworld.blogspot.com/2009/12/birt-designer-classpath-changes.html
you can put the jar in the resource folder and add it to the report
using the resources entry in the properties view for the report or use
an approach listed in the post above.
Jason
On 6/26/2012 4:26 PM, Carlos Ferrer wrote:
> Jason,
Re: Problem with Script Datasource [message #892262 is a reply to message #892045] Wed, 27 June 2012 10:14 Go to previous message
Jason,
Thanks for all your help. Everything is hooked up and working.
Previous Topic:Performance of Birt
Next Topic:Problem with creating radar chart
Current Time: Sun Jul 20 09:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.06566 seconds
