Home » Eclipse Projects » NatTable » Select column & RowSelectionModel(Very long hang...)
Select column & RowSelectionModel [message #890982] Sat, 23 June 2012 12:54 Go to next message
There is a bug between SelectColumnCommandHandler and RowSelectionModel.
SelectColumnCommandHandler uses Integer.MAX_VALUE to identify all rows as being selected, however in RowSelectionModel, it has to iterate each row and store the values (where those rows exist). Looking up 2x10^9 rows takes a very long time however.
As a quick fix I've extended the RowSelectionModel as follows:
public void addSelection(final Rectangle range) {
if (range.y + range.height > gridLayer.getBodyDataProvider().getRowCount()) {
range.height = gridLayer.getBodyDataProvider().getRowCount() - range.y + 1;
super.addSelection(range);
Paul
Edit: version 2.3.1.1
[Updated on: Sat, 23 June 2012 14:06] by Moderator
Re: Select column & RowSelectionModel [message #891922 is a reply to message #890982] Tue, 26 June 2012 11:14 Go to previous message
Hi Paul,
Thanks for this - I have checked in a change to RowSelectionModel.addSelection() to consider the layer rowCount in order to limit the iteration. https://bugs.eclipse.org/bugs/show_bug.cgi?id=383565
Edwin
Previous Topic:Select column upon RMB click
Next Topic:Using a different configuration gives a NullPointerException
Current Time: Thu Sep 18 12:32:31 EDT 2025
Powered by FUDForum. Page generated in 0.03476 seconds
