Home » Archived » BIRT » fixed chart bar width(fixed chart bar width)
fixed chart bar width [message #886266] |
Thu, 14 June 2012 11:19  |
I need to assign a fixed bar width in the chart, I have a report here it contains 3 chart in this report, I have workgroup name for axies and central offices for each workgroup, Im using afterDataSetFiled assigned dynamic block bounds for each work group, this park is ok, now I got dynamic block width. but when 1 work group contains a lots central offices in this workgroup bars getting really thin, and if they have same number of central offices the label on the bar become stack on each other make user hard to read.
var totalBars = 0;
function afterDataSetFilled( series, dataSet, icsc )
totalBars = dataSet.getValues().length;
if( dataSet.getValues().length > 9 ){
icsc.getChartInstance().getBlock().getBounds().setWidth(110*dataSet.getValues().length);
//icsc.getChartInstance().getBlock().getBounds().setHeight(300);
}else if(dataSet.getValues().length == 1){
icsc.getChartInstance().getBlock().getBounds().setWidth(600);
}else{
icsc.getChartInstance().getBlock().getBounds().setWidth(200*dataSet.getValues().length);
//icsc.getChartInstance().getBlock().getBounds().setHeight(400);
is there any way I can assign a fixed bar width for each bar? so they can display the same width for each bar?
here is my rptdesign file, please take look, when it has a lot central offices in one workgroup.
Thanks for your help
Re: fixed chart bar width [message #890006 is a reply to message #889847] |
Wed, 20 June 2012 10:34   |
Thank you very much for your help Jeason, finally I have some answer, I do have code to determine the units spacing too, but number of workgroups and number of central office are not fixed, they could be a large number for both, when number of groups greater than 9, I set unit spacing to 10, but that will not fix when in each block have a lots bars(lets say 18 bars in one block), in this situation, even I set units spacing to 0, it still makes bars really thin, and when two bars sit beside each other with the same hight, the label of the bar(there is a counts label on top of each bar) become stack on each other, or too close to each other. Is there any way I can get the counts in the legend area? so I can add it to determine the width of each block. I am not sure I explained this well enough or not, if not please let me know I will give more informations.
Thank you very much
var totalBars = 0;
}else{
function beforeGeneration( chart, icsc )
if(totalBars < 10){
chart.setUnitSpacing(40);
if(totalBars > 9){
chart.setUnitSpacing(10);
Re: fixed chart bar width [message #890070 is a reply to message #890006] |
Wed, 20 June 2012 17:51   |
On the bar question can you post a picture? You also may want to turn
your data point labels to 90 degrees rotation. What are you displaying
in your legend. What you display will determine how to count it.
Jason
> Thank you very much
> var totalBars = 0;
> }else{
> if(totalBars < 10){
> if(totalBars > 9){
Re: fixed chart bar width [message #890713 is a reply to message #890626] |
Fri, 22 June 2012 18:33   |
Can you not just set the master page to a custom size and expand the
chart? See attached.
Jason
On 6/22/2012 1:33 PM, Hao Song wrote:
> Hi Jason:
> Sorry about I reply late, and thanks for your help. Here is a sample I made use sample DB, when you preview this report please set number of rows to display to 15 in the preview preference, it will shows better, I hope you can give me a example on this one that can display bar label(which will be 1 in this case in my own case I will get it from the database) well in each bar,so they dont get too close to each other. I dont care the width of the chart, because after I embedded into our User Interface it will be in a scroll panel, so user can scroll it as far as they want, I just want the count for each bar (which will be 1 in this case in my own case I will get it from the database) that can display well for user(each bar has enough space to display this number inside).
> Thank you
Re: fixed chart bar width [message #891697 is a reply to message #886266] |
Mon, 25 June 2012 10:17   |
Hi Jason:
Here is the report with the custom in master page, if you mean use this way to slove this problem, I dont think it will, because all the data in the chart come from our database, and you never know how many will be there, and if there is only one central office(data in the legend area) in the database, it will make that bar very wide, if there are a lots central offices in there, it will make bars very thin.
and count of the bars get really close to each other like in this example. so thats what I want to know, is there anyway I can count how many central offices in this chart so I can use the script to set the width of the chart or master page or set the block bounds.If you can give me an example, that will help me a lot.
Thank you very much
Re: fixed chart bar width [message #891773 is a reply to message #891697] |
Mon, 25 June 2012 16:40   |
If central offices is the field you use for optional grouping (2nd tab
of the chart wizard)? If so in the beforeGeneration you should be able
to get the number of bars using this script:
var xAxis = chart.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var ySerieDef = yAxis.getSeriesDefinitions().get(0);
var numOfBars = ySerieDef.getRunTimeSeries().size() );
In the example you posted it will be 110 bars per category, which is
what your script:
returns. That script returns seven (the number of categories)
Jason
On 6/25/2012 10:17 AM, Hao Song wrote:
> Hi Jason:
> Thank you very much
Current Time: Sat Jul 19 14:44:31 EDT 2025
Powered by FUDForum. Page generated in 1.18849 seconds
