Home » Language IDEs » Java Development Tools (JDT) » Refactoring -> Pull Up gives brocken code
Refactoring -> Pull Up gives brocken code [message #890218] Thu, 21 June 2012 09:51 Go to next message
im not sure if its really an bug or im just expecting somethign different Smile
If i use the "Refactor -> Pull Up" command inside an java editor and choose an interface theses extracted methods should be added to. They are added but with an "abstract" modifier.
public final ILHTreeNode getRoot() {
        return root;
gives ...
public abstract ILHTreeNode getRoot();
"final" modifier are removed correctly.
Am i missing something or is the "Pull Up" command expecting that i choose a base class as target?
Johan
Re: Refactoring -> Pull Up gives brocken code [message #893620 is a reply to message #890218] Wed, 04 July 2012 19:16 Go to previous message
I'm not sure what you are surprised about? What is broken? What'd you expect?
best,
Stephan
Previous Topic:Interface in one project and Implementation in annother
Next Topic:Marker ID Not Fount
Current Time: Sat Jul 19 06:43:20 EDT 2025
Powered by FUDForum. Page generated in 0.05966 seconds
