Home » Eclipse Projects » GEF » Zest Bug - Small Nodes(No proper redraw of the graph)
Zest Bug - Small Nodes [message #889814] Tue, 19 June 2012 14:18 Go to next message
I'm new to Zest and GUI. For my GUI I'm using JFrames and JButtons and the Graph is shown by Zest. Somehow I'm facing a problem, when trying to redraw my graph.
Here is a simple demo of my problem:
public class shelltest {
	Display d;
	public void showGUI(){
		JFrame frame= new JFrame("SWT GUI");
		frame.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
		JPanel buttonPanel = new JPanel(new GridLayout(2,3));
		final JButton createButton = new JButton("Create Graph");
		buttonPanel.add(createButton);
		frame.getContentPane().add(buttonPanel);
		createButton.setEnabled(true);
		ActionListener createListener = new ActionListener() {
			public void actionPerformed(ActionEvent e) {
				showGraph();
		createButton.addActionListener(createListener);
		frame.setVisible(true);
	public void showGraph(){
		new Thread() {
		public void run() {
            		d = new Display();
        		Shell shell = new Shell(d);
        		shell.setText("Test");
        		shell.setLayout(new FillLayout());
        		Graph g = new Graph(shell, SWT.NONE);
        		GraphNode a = new GraphNode(g,ZestStyles.NODES_CACHE_LABEL, "A");
        		new GraphConnection(g,SWT.NONE,a,new GraphNode(g,SWT.NONE, "B"));
        		g.setLayoutAlgorithm(new SpringLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING), true);
        		shell.open();
        		while (!shell.isDisposed()) {
        		   if (!d.readAndDispatch()) {
        	           	d.sleep();
        	    a.dispose();
        		g.clear();
        		g.dispose();
        		d.dispose();
      	  }.start();
		shelltest myshell = new shelltest();
		myshell.showGUI();
If I press the "Create Graph"-Button, the Shell opens and shows me the Graph. Somehow, if I close this new opened window and again press the "Create-Graph"-Button, the graph is shown in a inproper way, with tiny nodes and unreadable labels. Can anyone tell me, how to fix this?
Thank you
Re: Zest Bug - Small Nodes [message #889826 is a reply to message #889814] Tue, 19 June 2012 15:38 Go to previous messageGo to next message
Interesting. If you don't recreate the display, but use always the same instance it works fine.
But why is that, I really don't know.
Re: Zest Bug - Small Nodes [message #889832 is a reply to message #889814] Tue, 19 June 2012 16:21 Go to previous messageGo to next message
Thanks for your reply. How do you use just one instance of the display?
If I instantiate the display d only once, I'm getting an invalid thread access exception.
Re: Zest Bug - Small Nodes [message #889872 is a reply to message #889832] Wed, 20 June 2012 01:55 Go to previous message
import java.awt.GridLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JPanel;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.zest.core.widgets.Graph;
import org.eclipse.zest.core.widgets.GraphConnection;
import org.eclipse.zest.core.widgets.GraphNode;
import org.eclipse.zest.core.widgets.ZestStyles;
import org.eclipse.zest.layouts.LayoutStyles;
import org.eclipse.zest.layouts.algorithms.SpringLayoutAlgorithm;
	final Display d;
	volatile boolean closed;
	public shelltest(Display d) {
		this.d = d;
	public void showGUI() {
		frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		frame.addWindowListener(new WindowAdapter() {
			public void windowClosed(WindowEvent e) {
				closed = true;
				showGraph();
		d.asyncExec(new Runnable() {
			public void run() {
				shell.open();
		Display d = new Display();
		shelltest myshell = new shelltest(d);
		myshell.showGUI();
		while (!myshell.closed) {
				d.sleep();
		d.dispose();
[Updated on: Wed, 20 June 2012 02:51] by Moderator
Previous Topic:Best way to add Draw2d to a GraphicalEditorWithFlyoutPalette?
Next Topic:Integrate tree drawing algorithm in GEF editor?
Current Time: Sat Jul 19 21:14:32 EDT 2025
Powered by FUDForum. Page generated in 0.06299 seconds
