Home » Language IDEs » PHP Development Tools (PDT) » [Announce] PDT 2.0.1 M200901080831 is available
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #88961 is a reply to message #88903] |
Thu, 08 January 2009 15:27   |
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
That should have read BIG numbers, not bug numbers.
Nick Boldt wrote:
> Generally, bug numbers == newer.
> 2.0.1 are maintenance fixes for 2.0.0, targeted for Eclipse 3.4.
> 2.1.0 is a work-in-progress, targeted for Eclipse 3.5 and to be released
> at the end of June.
> So, it depends on if you're using Eclipse 3.4.x or 3.5.x, really.
> rapkasta@gmail.com wrote:
>> Thu, 08 Jan 2009 19:02:09 +0500, Build Monkey
>> <pdtBuild@build.eclipse.org> написал:
>>> The following build [1] will be available at eclipse.org in the next
>>> 30-60 mins.
>>> [1]
>>> http://www.eclipse.org/pdt/downloads/?project=pdt&showAl l=1&hlbuild=M200901080831#M200901080831
>>> Updated release notes [2] will be available within to 24hrs.
>>> [2]
>>> http://www.eclipse.org/pdt/news/relnotes.php?project=pdt& ;version=M200901080831
>> Cool, my problem is solved.
>> But can anybody tell what version is the lates (i don't understand
>> it): 2.0.1 OR 2.1.0 ?
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #88975 is a reply to message #88961] |
Fri, 09 January 2009 05:55   |
>> released at the end of June.
>>>> 30-60 mins.
>>>> [1]
>>>> [2]
I was also confused, i thought 2.1.0 supercedes 2.0, but it seems that i
was wrong. You guys should update the project plan, it does not mention
2.1.* at all :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89023 is a reply to message #88975] |
Fri, 09 January 2009 09:41   |
If you look at the PDT homepage (http://www.eclipse.org/pdt/) you should
see:
26th of June, 2009 - PDT 2.1 Release
29th of December, 2008 - PDT 2.0 Release
The project plan is for 2.0; a 2.1 plan has not yet been drafted as the
2.1 cycle only started this week.
And yes, 2.1.0 WILL supercede 2.0.0, if you also plan to move up from
Eclipse 3.4 to 3.5.
>>>>> 30-60 mins.
>>>>> [1]
>>>>> [2]
> 2.1.* at all :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89216 is a reply to message #89023] |
Fri, 09 January 2009 15:45   |
I am having the same problem that rapkasta cited.
but I download the M200901080831 fix, SDK (Runtime, Source), Runtime and
Automated Tests, unziped the files in plugins/features folders, but the
problem persists.
I am doing something wrong ? How can I resolve this ?
thanks
> see:
> Eclipse 3.4 to 3.5.
>>>>> <pdtBuild@build.eclipse.org> МапОÑал:
>>>>>> 30-60 mins.
>>>>>> [1]
>>>>>> [2]
>> 2.1.* at all :)
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89571 is a reply to message #89527] |
Mon, 12 January 2009 06:22   |
1st all sorry to repeat the message, I have had problems to do the post,
so I try to do it a lot of things, I know that is not appropriate.
I will be honest, I am trying to check if the PDF is a old version, but I
cant check this correctly.
In about box I have this info:
Eclipse SDK
"Version: 3.4.1
Build id: M20080911-1700"
And I have downloaded the M200901080831 fix, SDK Runtime, Source and
unziped the files in plugins/features folders.
Michael Spector wrote:
> Weird... it works for me:
> http://img519.imageshack.us/my.php?image=22419895jx6.png
> Any chance you are still running an old version of PDT?
> Thanks!
> "Fernando Dias" <fdias.webdev@gmail.com> wrote in message
> news:c6f0ce286ebcb1c69f04e54c8c4d1924$1@www.eclipse.org...
>> problem persists.
>> thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89629 is a reply to message #89571] |
Mon, 12 January 2009 11:01   |
If you are unpacking the new PDT into an older PDT all-in-one, you may
have to disable the older features first.
Or better, unpack the new PDT into the same place that the 2.0.0 version
is... put it in eclipse/dropins/, not in eclipse/.
As to determining the installed version of PDT, look at Help > About >
Plugins or Help > Software Updates > Installed Software.
> "Version: 3.4.1
That's the version of Eclipse, not the PDT plugins on top.
> I cant check this correctly.
> Eclipse SDK
> "Version: 3.4.1
>> Thanks!
>>> and Automated Tests, unziped the files in plugins/features folders,
>>> but the problem persists.
>>> thanks
Re: [Announce] PDT 2.0.1 M200901080831 is available [message #89915 is a reply to message #89629] |
Tue, 13 January 2009 08:09  |
I've tried unzip in /eclipse and eclipse/dropins folder, unsuccessful.
I tried to update the plugins in Eclipse, and not working either.
with any chance to work, I create another folder, put the new all in one
there and unzip the new pdt in /eclipse and eclipse/dropins folder. and
now Its working...
Thanks people, for support !
> > "Version: 3.4.1
>> Eclipse SDK
>> "Version: 3.4.1
>>> Thanks!
>>>> thanks
Current Time: Sun Jul 20 02:39:13 EDT 2025
Powered by FUDForum. Page generated in 0.04643 seconds
