Home » Eclipse Projects » Marketplace Client Project » problem to connetc to marketplace on indivo realese 2
problem to connetc to marketplace on indivo realese 2 [message #887020] Fri, 15 June 2012 20:41 Go to next message
Hello, i've a problem to connect my eclipse indigo release 2 JEE with marketplace to download the jboss tools...
LOG
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1029)
	at org.eclipse.equinox.internal.p2.ui.discovery.wizards.CatalogViewer.updateCatalog(CatalogViewer.java:563)
	at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.updateCatalog(MarketplaceViewer.java:453)
	at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage$6.run(MarketplacePage.java:332)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand.execute(MarketplaceWizardCommand.java:171)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.IllegalStateException
	at org.eclipse.equinox.internal.p2.discovery.Catalog.performDiscovery(Catalog.java:64)
	at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.performDiscovery(MarketplaceCatalog.java:255)
	at org.eclipse.equinox.internal.p2.ui.discovery.wizards.CatalogViewer$6.run(CatalogViewer.java:569)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
THE LOG:
Code: [Select all] [Show/ hide]
Solutions?
Everytimes i go to marketplace or ceck updates or installa new software there is the same problem, the connection Unable to read repository
Re: problem to connetc to marketplace on indivo realese 2 [message #887459 is a reply to message #887020] Sat, 16 June 2012 13:05 Go to previous messageGo to next message
please help!!
Re: problem to connetc to marketplace on indivo realese 2 [message #889642 is a reply to message #887459] Tue, 19 June 2012 08:41 Go to previous messageGo to next message
plaese some solutions, i don't know what i have to do
Re: problem to connetc to marketplace on indivo realese 2 [message #889829 is a reply to message #887020] Tue, 19 June 2012 16:15 Go to previous messageGo to next message
What version of the JBoss tools are you trying to install? It needs to be the Indigo version and not the Helios version.
Re: problem to connetc to marketplace on indivo realese 2 [message #890028 is a reply to message #889829] Wed, 20 June 2012 12:29 Go to previous messageGo to next message
thanks for help!!
I install indigo Realese 2 JEE the last version, that i think want jboss 3.2.
But i don't know to understand why the connectin between eclipse indigo JEE to marketplace doesn't work.
Other thing if i try to enter in marketplace with the other eclipse that i've installated before now, there is always the same error.
Maybe there is a conflict between the different version of eclipse?
There is always this error and other:
Address family not supported by protocol family: connect
Please help me
thanks
Re: problem to connetc to marketplace on indivo realese 2 [message #890049 is a reply to message #890028] Wed, 20 June 2012 15:45 Go to previous messageGo to next message
Based on the given stacktrace it indicates a misconfiguration of your eclipse installation. Could you please try to install the solution from the marketplace with a fresh install of Eclipse?
Cheers
Tom
Re: problem to connetc to marketplace on indivo realese 2 [message #890926 is a reply to message #890049] Sat, 23 June 2012 09:13 Go to previous message
thanks for help
i try to install another version but it's the same!!
Previous Topic:How do I test install for my project via Marketplace Client?
Next Topic:Filtering entries based on Eclipse platform version
Current Time: Sun Jul 20 05:51:40 EDT 2025
Powered by FUDForum. Page generated in 0.05463 seconds
