Home » Eclipse Projects » Eclipse Platform » Meaning of the icon symbol?
Meaning of the icon symbol? [message #88734] Fri, 04 July 2003 01:40 Go to next message
Originally posted by: krush_krush.hotmail.com
I have added a dependency plugin into my plugin project
(Dependencies tab of the manifest editor), but I noticed
that the dependency I just added has a little yellow dot
at the left upper corner of the plugin icon. Other dependencies
have a little blue arrow instead.
What does that little yellow dot mean? Warning? Error?
If it's an error, the Source tab should also show that
it is an error, right?
I'm asking this question because I've spent the last
two days trying to figure out why the class loader
can't load classes from this dependency library.
I always got the error NoClassDefFoundError.
Thanks for any help.
kk
Re: Meaning of the icon symbol? [message #89600 is a reply to message #88734] Sun, 06 July 2003 04:40 Go to previous message
Originally posted by: loemming.gmx.net
Hey
"konrad krash" <krush_krush@hotmail.com> schrieb im Newsbeitrag
news:<pan.2003.07.04.05.40.17.950817@hotmail.com>...
> I have added a dependency plugin into my plugin project (Dependencies
> tab of the manifest editor), but I noticed that the dependency I just
> added has a little yellow dot at the left upper corner of the plugin
> icon. Other dependencies have a little blue arrow instead.
Go to the Overview page. It will show you errors and allerts in the upper
left part. Probably the plugin you depend on cant be resolved. Check the
correct name or package.
Either the plugin you depend on cannot be resolved (see above) or it sources
are not visible.
A plugin can make sources visible via the export tag. If it does not export
any class files, they cannot be found and you get the NoClassDefFoundError.
Hope that helps
philipp
> kk
Previous Topic:Synchronizing Tree View and Editor
Next Topic:Two different plugins under the same menu (ActionSet)
Current Time: Sat Jul 19 10:28:53 EDT 2025
Powered by FUDForum. Page generated in 0.04110 seconds
