rpt document generated with large size (900 MB) [message #886622] |
Fri, 15 June 2012 05:53  |
I am using Birt 3.7 eclipse.I am facing problem where my report which is generated for nearly 23000 records and the size of rpt document is 900 MB.
I have used table layout,grids for aggregations and label in my report design.
my query is:
What could be the cause for getting the report document generated size will be larger.
Please help me out for comming out this issue, As it surprised me with this behaviour.
As my report design is not having any images inside layout, it just having 10 aggregations, grids for labels inside my report layout.
Thanks in advance for your concern on this issue.
please suggest me how to reduce the size of generating the report document generated and also suggestions about why this behaviour of getting large size of report document.
regards
kishore G
Re: rpt document generated with large size (900 MB) [message #886832 is a reply to message #886622] |
Fri, 15 June 2012 13:49  |
Kishore
Any chance you could create a bugzilla entry to look into this? It
would be good if you could post your design to the bugzilla entry as well.
Jason
On 6/15/2012 5:53 AM, kishore G wrote:
> design.
> my query is:
> will be larger.
> this behaviour.
> regards
> kishore G
FUDForum. Page generated in 0.36281 seconds
