Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to test CreateAlphaMask method in Image Widget ?(Need help with implementation that shows how CreateAlphaMask method in Image Method workds)
How to test CreateAlphaMask method in Image Widget ? [message #884655] Mon, 11 June 2012 11:09 Go to next message
Hello Everyone,
I am trying to figure out how CreateAlphaMask method of Image widget works.
I have tried using code from "Taking a look at SWT Images" (can't post links yet) - "Single alpha value" to see if Image widget will react if I comment out CreateAlphaMask method, but there is no reaction at all.
Can someone give me a piece of code that reacts on changes made inside Image: CreateAlphaMask method, so i could see how it works ?
Any help is appriciated.
Anatoly
Re: How to test CreateAlphaMask method in Image Widget ? [message #885189 is a reply to message #884655] Tue, 12 June 2012 11:18 Go to previous message
I understood why I was unable to see CreateAlphaMask - I am using Linux and CreateAlphaMask is not used when Cairo is used.
So problem solved Smile
Previous Topic:Strange Composite.pack(true) behavior in e4
Next Topic:FileDialog delay
Current Time: Sat Jul 19 14:33:33 EDT 2025
Powered by FUDForum. Page generated in 0.25041 seconds
