Home » Archived » BIRT » Chart not visible when exporting to Excel
Chart not visible when exporting to Excel [message #884475] Mon, 11 June 2012 02:31 Go to next message
Dear all,
i am exporting a report to excel using the php javabridge. However, the charts do not appear. They appear in the pdf and word formats correctly.
I know that it is something to do with the excel emitter. The question is how to incorporate it in the php parameter setting so that i can use the other version of emitter?
Thanks a lot in advance. I need some kind help here...
Karvesh
Re: Chart not visible when exporting to Excel [message #884645 is a reply to message #884475] Mon, 11 June 2012 10:42 Go to previous messageGo to next message
What version of BIRT are you running?
Jason
On 6/11/2012 2:31 AM, karvesh Mising name wrote:
> Dear all,
> Karvesh
Re: Chart not visible when exporting to Excel [message #884681 is a reply to message #884645] Mon, 11 June 2012 11:41 Go to previous messageGo to next message
Dear Jason
I am using the version 3.7 version
Karvesh
Re: Chart not visible when exporting to Excel [message #884691 is a reply to message #884645] Mon, 11 June 2012 11:52 Go to previous messageGo to next message
I forgot to mention that even normal images fail to appear when the report is exported to excel
Re: Chart not visible when exporting to Excel [message #884713 is a reply to message #884691] Mon, 11 June 2012 12:47 Go to previous message
Images are not supported in the default xls emitter either. Are you
using the POJO runtime or the OSGI runtime(only available in 3.7.2). If
you are using the POJO runtime have a look at:
http://birtworld.blogspot.com/2011/07/replacing-default-birt-xls-emitter.html
Jason
Previous Topic:How to script a Stored Procedure on beforeOpen
Next Topic:Export to DOC Microsoft Word Issue
Current Time: Sat Jul 19 15:27:50 EDT 2025
Powered by FUDForum. Page generated in 0.05083 seconds
