Home » Eclipse Projects » Rich Client Platform (RCP) » HTML 5 in SWT Browser
HTML 5 in SWT Browser [message #883835] Sat, 09 June 2012 10:47 Go to next message
Will HTML5 be supported in SWT Browser?
are there any other alternatives that i can use?
Mak
Re: HTML 5 in SWT Browser [message #884302 is a reply to message #883835] Sun, 10 June 2012 15:00 Go to previous messageGo to next message
Hello Mak,
I guess you´re using a windows OS for your RCP client with the swt browser.
By passing SWT.NONE to the constructor of the swt browser, it will use Microsoft´s Internet Explorer version you have currently installed on your system.
Unfortunately IE 9(the newest stable version) does not support every HTML 5 feature yet.
As an alternative you could pass SWT.MOZILLA to the swt browser´s constructor and use MOZILLA instead of the IE.
To make this work you´ll need to run a xulrunner (developer.mozilla.org/en/Getting_started_with_XULRunner)
To define that xulrunner properly for the swt browser see this : www.eclipse.org/swt/faq.php#specifyxulrunner
Simon
Re: HTML 5 in SWT Browser [message #885117 is a reply to message #884302] Tue, 12 June 2012 09:45 Go to previous message
One other thing to note is that if you're using Eclipse/SWT 3.6.x or
older then your SWT.NONE-style Browser on Windows will run in IE7
emulated mode, even if you have a newer IE version installed. As of
Eclipse/SWT 3.7.x you will get the full capabilities of your installed
IE version.
Grant
On 6/10/2012 3:00 PM, Simon SSC wrote:
> Hello Mak,
> your system.
> HTML 5 feature yet.
> Best regards,
> Simon
Previous Topic:Use actionSets or extensions of menus, commands
Next Topic:Can't find IDEWorkbenchAdvisor
Current Time: Sat Jul 19 22:29:55 EDT 2025
Powered by FUDForum. Page generated in 0.03140 seconds
