Home » Archived » M2M (model-to-model transformation) » [ATL] creating objects in ATL
[ATL] creating objects in ATL [message #88336] Thu, 14 August 2008 20:05 Go to next message
Originally posted by: aaniculaesei.gmail.com
Hello to you all,
I am writing an ATL Transformation to transform a UML Model of a state
chart to a NuSMV Model that describes the NuSMV program which eventually
can be run to watch and verify the behavior of the state chart.
In testing my helper functions I need to be able to instantiate and run
objects belonging to the UML model (e.g. state configurations).
The question is: can I do create and instantiate objects the way it is
done in an imperative language ?
Thank you very much for help!
Adina
Re: [ATL] creating objects in ATL - defining new classes [message #88352 is a reply to message #88336] Fri, 15 August 2008 04:43 Go to previous messageGo to next message
Hi again,
Rephrasing the question a little bit ... I need to define new classes,
instantiate objects of these classes and run them in ATL.
For example in UML Metamodel I have the Vertex class or the State class.
These classes both describe a state in a Statemachine.
Now what I want to do is define a new class to deal for example with
StateConfiguration objects.
Can this be done in ATL ? Can you point me in the right direction to
read more about it ?
Thank you very much!
Adina
Adina Aniculaesei wrote:
> Hello to you all,
> Adina
Re: [ATL] creating objects in ATL - defining new classes [message #88381 is a reply to message #88352] Fri, 15 August 2008 06:03 Go to previous messageGo to next message
Hi Adina,
You could use lazy rules and called rules.
rule createClass(String name) {
to c: UML!Class (
name<-name;
and call it for example in the etrypoint rule:
entrypoint rule Start { -- don't call it main!
thisModule.createClass("aClass");
Alfons
"Adina Aniculaesei" <aaniculaesei@gmail.com> schreef in bericht
news:g83fjv$7ch$1@build.eclipse.org...
> Hi again,
> Can this be done in ATL ? Can you point me in the right direction to read
> more about it ?
> Adina
>> Hello to you all,
>> Adina
Re: [ATL] creating objects in ATL - defining new classes [message #90081 is a reply to message #88381] Mon, 15 September 2008 01:02 Go to previous message
Thank you for answering my question.
Here is how I wrote it, in case other people run into the same question:
rule createClass (name : String){
to c : UML!Class (
name <- name
However the following code gives me errors regarding 'thisModule':
entrypoint rule Start() {
to t : KM3!UML
do {
thisModule.createClass("StateConfiguration")
Is it a keyword to identify the current module ?
Also, I have another question: can I define for such a class, created
the way described above, operations and attributes ?
Thank you very much,
Adina
Alfons Laarman wrote:
> Hi Adina,
> to c: UML!Class (
> name<-name;
> Regards,
> Alfons
>> Hi again,
>> more about it ?
>> Adina
>>> Hello to you all,
>>> Adina
Previous Topic:[ATL] refininig and parameters passing
Next Topic:Sequence Diagram to Java Code questions
Current Time: Sat Jul 19 14:19:18 EDT 2025
Powered by FUDForum. Page generated in 0.04043 seconds
