Home » Modeling » EMF » [CDO] Collaborative work on UML models
[CDO] Collaborative work on UML models [message #883393] |
Fri, 08 June 2012 08:39  |
I have a web application that programmatically creates and changes UML models (based on EMF of course).
Now I want to make this application collaborative, i.e. several users should be able to work on the same UML model at the same time.
I think CDO can help me for this purpose.
Till now I have stored the UML models as files. As I see when using CDO I have to change to a database right? Or is CDO also for file-based models?
After reading the documentation, when using CDO in a collaborative environment, I assume the process is as follows:
1. User 1 logs in
2. User 1 wants to open a model
3. User 1 opens a session
4. User 1 opens a new transaction
5. User 1 works on the model
6. User 1 commits his changes
N. User 1 closes the session.
Is it correct that the session is opened during all my web session? Or do I open a session every time the user wants to work on a model?
Well, what I am confused about is, that first the transaction is opened and then the resource is chosen.
I had assumed:
1. User logs in
2. User opens a session
3. User chooses a resource
4. Wants to change the model -> opens transcation -> changes -> commits transaction
Because in my collaborative application of course some data is cached. For example:
My model contains an entity "Person". Now the user wants to see all persons and edit some. He starts a session, opens a transaction, opens the model, gets all persons and closes the transaction and session.
The persons are now displayed within a table. Now, the user wants to change a person. He clicks on a certain person and now the details have to be determined. What is happening now? Again opening a session? Again choosing the resource and opening a transaction? Does CDO still now, which element I have selected? Or is the internal ID different now?
Maybe you can give me some hints about how to work with CDO in this example.
Tex
Re: [CDO] Collaborative work on UML models [message #883410 is a reply to message #883393] |
Fri, 08 June 2012 09:20   |
Am 08.06.2012 14:39, schrieb Tex Iano:
> the same time.
Currently there is no file-based IStore available for CDO. So yes, you'll need some kind of database.
> 1. User 1 logs in
> to work on a model?
You should think of a CDOSession as a jdbc.DataSource and of a CDOTransaction as a jdbc.Connection. Now you see that the
CDOTransaction API is very similar to a JDBC Connection, including methods like commit() or rollback() and concepts like
CDOSavepoint.
You can open multiple CDOTransactions on a CDOSession.
> I had assumed:
> 1. User logs in
You need a CDOView or CDOTransaction to access the object graph (including resources or folders).
You can call commit() multiple times on a CDOTransaction until you've called close().
That's not possible. All objects craeted and managed by a view/transaction become INVALID if the view/transaction is closed.
For pure viewing a CDOView is usually best.
What details?
Usually you'd open a new transaction and load the selected object:
Person personInTX = tx.getObject(personFromView);
Cheers
/Eike
http://www.esc-net.de
> Regards,
> Tex
Re: [CDO] Collaborative work on UML models [message #883494 is a reply to message #883418] |
Fri, 08 June 2012 13:04   |
Am 08.06.2012 15:44, schrieb Tex Iano:
> thanks for your detailed answer. So, this means: Everytime I create a new transaction when the user acts on the model.
> What happens when I have an opened transaction and another user wants to work on the same model?
The other user probably wants to commit separately, so you'll need to open a transaction per user or per user action.
CDOTransactins are cheap, copared to CDOSessions.
> Btw, is model == resource?
Th term "Model" is not well-defined. Everything can be a model. In particular there exist two flavours:
1) EPackages and their contents (EModelElements) are sometimes referred to as "meta models". All other EObject
(including CDORecources and CDOResourceFolders) are then referred to as "models" or "the model".
2) Those that don't like the term "meta" often just use "models" and "(model) instances", respectively.
> Is the resource locked when a transaction is opened?
CDO uses optimistic locking by default, e.g., a resource is locked in the server *during* a commit operation, if and
only if the resource is directly modified.
Pessimistic locking is optional and available through, e.g., CDOObject.cdoWriteLock().lock(). This also only applies to
the specific object/resource (not their contents) unless you use CDOView.lockObjects(objects, LockType.WRITE, timeout,
recursive).
> Or do I get a conflict when another user changes the model while it is opened within a transaction? Then I could leave
> the transaction opened during the entire web session and reload the model when I get a transaction conflict. And after
> every operation within a session I do only a commit.
That would require to synchronize all operations on the transaction so that one user can not commit the changes of
another user. Transactions are comparingly cheap to open, so I would give each user an own transaction.
Cheers
/Eike
Re: [CDO] Collaborative work on UML models [message #884506 is a reply to message #883393] |
Mon, 11 June 2012 04:02   |
Hi Tex,
as I know there is no CDO compatible UML till now.
I think this Bug is the biggest drawback.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257102
Peter
> 1. User 1 logs in
> I had assumed:
> 1. User logs in
> transaction
> For example:
> example.
> Regards,
> Tex
Re: [CDO] Collaborative work on UML models [message #884515 is a reply to message #884506] |
Mon, 11 June 2012 04:24   |
If https://bugs.eclipse.org/bugs/show_bug.cgi?id=257102 was the biggest
drawback, there would almost 'no' problem. UML users have survived for
3.5 years since that problem was reported. It doesn't appear to have
anything to do with CDO integration. If there is such a problem, please
add a comment to the bug to motivate its resolution.
Ed Willink
On 11/06/2012 09:02, Peter wrote:
> Hi Tex,
> Regards
> Peter
>> Hi,
>> models?
>> 1. User 1 logs in
>> I had assumed:
>> 1. User logs in
>> transaction
>> For example:
>> example.
>> Regards,
>> Tex
Re: [CDO] Collaborative work on UML models [message #884526 is a reply to message #884515] |
Mon, 11 June 2012 05:01   |
Hi Ed,
sure when you work with UML files that is no problem. But
as I know a CDO EMF model needs to be generated with reflective or
dynamic delegation. The UML custom code templates only support "None"
Feature Delegation.
Please correct me If I am wrong...
Peter
Am 11.06.2012 10:24, schrieb Ed Willink:
> Hi
> Regards
> Ed Willink
>> Hi Tex,
>> Regards
>> Peter
>>> Hi,
>>> models?
>>> 1. User 1 logs in
>>> I had assumed:
>>> 1. User logs in
>>> transaction
>>> For example:
>>> example.
>>> Regards,
>>> Tex
Re: [CDO] Collaborative work on UML models [message #884533 is a reply to message #884526] |
Mon, 11 June 2012 05:25   |
Hi Peter
I don't really understand your point, but I think you're confusing two
issues.
For collaborative editing of a UML model, no EMF generation is needed.
It is merely necessary for CDO to keep track of who 'owns' which parts
of the model so that changes propagate around correctly.
I suspect that you are talking about generating an Ecore model from UML
so that you can have an instance of the UML model. This is no doubt
important but not a collaborative issue; I would assume that the Ecore
equivalent would be a batch conversion; though of course incremental
transformation is the next interesting step.
Ed Willink
On 11/06/2012 10:01, Peter wrote:
> Hi Ed,
> Feature Delegation.
> Regards
> Peter
>> Hi
>> Regards
>> Ed Willink
>>> Hi Tex,
>>> Regards
>>> Peter
>>>> Hi,
>>>> CDO
>>>> models?
>>>> 1. User 1 logs in
>>>> opened
>>>> I had assumed:
>>>> 1. User logs in
>>>> commits
>>>> transaction
>>>> For example:
>>>> have
>>>> Again
>>>> example.
>>>> Regards,
>>>> Tex
Re: [CDO] Collaborative work on UML models [message #884548 is a reply to message #884533] |
Mon, 11 June 2012 06:11   |
Hi Ed,
ok I´ll try to make my point more clear.
When you want a native cdo emf model you need to migrate the genmodel.
See
http://wiki.eclipse.org/CDO/Preparing_EMF_Models#Use_the_CDO_Model_Migrator
And when you do this you can´t generate the uml api because the custom
code templates of the uml2 project don´t support the required feature
delegation.
I think the second problem is that the EModelElement extends EObject but
Eike Stepper posted a workaround in a bug report a while ago.
Peter
Am 11.06.2012 11:25, schrieb Ed Willink:
> Hi Peter
> issues.
> Regards
> Ed Willink
>> Hi Ed,
>> Feature Delegation.
>> Regards
>> Peter
>>> Hi
>>> Regards
>>> Ed Willink
>>>> Hi Tex,
>>>> Regards
>>>> Peter
>>>>> Hi,
>>>>> CDO
>>>>> models?
>>>>> 1. User 1 logs in
>>>>> opened
>>>>> I had assumed:
>>>>> 1. User logs in
>>>>> commits
>>>>> transaction
>>>>> For example:
>>>>> have
>>>>> Again
>>>>> example.
>>>>> Regards,
>>>>> Tex
Re: [CDO] Collaborative work on UML models [message #884577 is a reply to message #884548] |
Mon, 11 June 2012 07:36   |
Thanks; my ignorance of CDO was showing through.
The OCL project is evolving a UML-aligned pivot meta-model that like
Basic UML and EMOF has no derived unions. This may be more practical for
UML implementation rather than specification tooling. Something else for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=340719 to worry about.
Ed Willink
On 11/06/2012 11:11, Peter wrote:
> Hi Ed,
> See
> delegation.
> but Eike Stepper posted a workaround in a bug report a while ago.
> Regards
> Peter
>> Hi Peter
>> issues.
>> Regards
>> Ed Willink
>>> Hi Ed,
>>> Feature Delegation.
>>> Regards
>>> Peter
>>>> Hi
>>>> biggest
>>>> please
>>>> Regards
>>>> Ed Willink
>>>>> Hi Tex,
>>>>> Regards
>>>>> Peter
>>>>>> Hi,
>>>>>> changes UML
>>>>>> users
>>>>>> CDO
>>>>>> models?
>>>>>> 1. User 1 logs in
>>>>>> session? Or
>>>>>> opened
>>>>>> I had assumed:
>>>>>> 1. User logs in
>>>>>> commits
>>>>>> transaction
>>>>>> cached.
>>>>>> For example:
>>>>>> opens
>>>>>> have
>>>>>> Again
>>>>>> example.
>>>>>> Regards,
>>>>>> Tex
Current Time: Sat Jul 19 15:02:47 EDT 2025
Powered by FUDForum. Page generated in 0.38018 seconds
