Home » Modeling » Graphiti » Graphiti Editor in a custom Editor
Graphiti Editor in a custom Editor [message #883331] Fri, 08 June 2012 05:57 Go to next message
Hi all,
I would like to know if it's possible to integrate the Graphiti editor into a custom editor created with Eclipse RCP.
I explain, my use case is about to create a graphical plugin to modify some configuration files (text files).
And I would like to provide the same functionality as adt plugin (Android one) : in a java project, when I'll double-click on a config file, the editor will open with two tabs : Graphiti diagram and text file.
What I didn't want, is to create a new Graphiti project to modify my configuration file (which is in java project).
Before asking questions, I looked through the Graphiti's forum but I didn't find what I need to know.
I hope some of you could help me, thanks.
Re: Graphiti Editor in a custom Editor [message #884507 is a reply to message #883331] Mon, 11 June 2012 04:03 Go to previous messageGo to next message
Yes, it's possible to embed the Graphiti diagram editor into a multi page
editor. We do have an example in one of the test tools in our upcoming Juno
0.9.0 release. With some modification it will also work in 0.8.0. See our
Git repo at
http://git.eclipse.org/c/gmp/org.eclipse.gmp.graphiti.git/tree/tests/org.eclipse.graphiti.testtool.sketch/src/org/eclipse/graphiti/testtool/sketch/editors
Using a Java project for storing Graphiti diagrams is perfectly ok. You
don't need any specific Graphiti settings on project level.
Michael
Re: Graphiti Editor in a custom Editor [message #892162 is a reply to message #884507] Wed, 27 June 2012 05:27 Go to previous message
Thank your for your answer.
Now I use XText to model my configuration file. I saw there is a new framework called Spray which create a Graphiti editor with our own DSL.
But it's quite new, so I surely use Graphiti.
Previous Topic:Customized Editing Domain for Diagram Editor
Next Topic:Simple collapsefeature
Current Time: Sat Jul 19 07:05:19 EDT 2025
Powered by FUDForum. Page generated in 0.03111 seconds
