Home » Archived » Jubula » Suggested built-in actions for database, file manipulation
Suggested built-in actions for database, file manipulation [message #882705] Wed, 06 June 2012 22:37 Go to next message
Do you guys have plans to provide actions for running sql scripts, and file and directory manipulation (i.e. copy, move, delete)?
I understand that scripts can be called from the executeExternalCommand action to do this, however as set up for databases/config files with test data for an AUT is very common, I think it would be great to have some built-in support for this in Jubula.
[Updated on: Wed, 06 June 2012 23:05] by Moderator
Re: Suggested built-in actions for database, file manipulation [message #882769 is a reply to message #882705] Thu, 07 June 2012 02:54 Go to previous message
The problem here is creating a generic implementation which covers most use cases. This is not that hard for file and directory operations but those are covered quite good by external scripts.
We have thought about database DDL and DML statements but we ran into several problems.
a) We would have to support (at least) all major database systems. Since DDL is not really standardized, this would create a maintenance nightmare.
b) To access the database, drivers would be necessary. Since most of them are not EPL conform, another maintenance and configuration problem would arise.
c) To provide a good user experience, editors and other tools would be necessary. We just don't have the resources to do this.
If you can provide good requirements/use cases/solutions to these topics (or even better some code) we would be happy to investigate further.
As a do-it-yourself solution you may (ab)use the newly introduced functions for parameter values and implement database or filesystem access yourself. This can easily be done by adding functions to an extension point. Please make it generic and contribute Wink
Previous Topic:Quick question about TestCase collaboration
Next Topic:Screenshot comparison
Current Time: Sun Jul 20 12:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
