Home » Archived » BIRT » Problem with namespace on web service parameters
Problem with namespace on web service parameters [message #882490] Wed, 06 June 2012 11:01 Go to next message
As mentioned in my previous thread I am using BIRT to fetch data from a web service I provide on a websphere app server.
I configured BIRT to call the service and set default values for the method parameters but all the values arrive as nulls and no data is returned.
On investigation I saw that the parameters all have namespace qualifiers like this:
<SOAP-ENV:Envelope
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
	<SOAP-ENV:Body>
		<m:StaffAttending xmlns:m="http://www.avms.firm.com/ReportService/">
			<m:username xsi:type="xsd:string">paul_ramsden@firm.com</m:username>
			<m:language xsi:type="xsd:string">en</m:language>
			<m:mmsFairId xsi:type="xsd:int">22</m:mmsFairId>
			<m:where xsi:type="xsd:string"></m:where>
			<m:sort xsi:type="xsd:string"></m:sort>
		</m:StaffAttending>
	</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
I then used SoapUI to test the web service. I used exactly the same wsdl file to configure the service and noted that the request sent to the service did not use namespaces on the parameters. The service returned data.
So I then took the request generated by BIRT and pasted it into SoapUI and it failed. I removed the namespaces from the parameters, tried again and it succeeded. Using the request below the first parameter arrives as null and the rest are ok.
<SOAP-ENV:Envelope
	<SOAP-ENV:Body>
			<m:username>paul_ramsden@firm.com</m:username>
			<language>en</language>
			<mmsFairId>22</mmsFairId>
		</m:StaffAttending>
	</SOAP-ENV:Body>
Why does BIRT generate a different request to SoapUI (and also the websphere service explorer)? Is there anything I can do to influence the way BIRT generated requests or how websphere decodes requests?
Re: Problem with namespace on web service parameters [message #882598 is a reply to message #882490] Wed, 06 June 2012 16:12 Go to previous message
Paul,
I believe it picks the prefix up from the target namespace in your wsdl.
Jason
> returned.
> like this:
> <SOAP-ENV:Envelope
> <SOAP-ENV:Body>
> <m:username xsi:type="xsd:string">paul_ramsden@xxxxxxxx</m:username>
> </m:StaffAttending>
> </SOAP-ENV:Body>
> data.
> <SOAP-ENV:Envelope
> <SOAP-ENV:Body>
> <m:username>paul_ramsden@xxxxxxxx</m:username>
> </m:StaffAttending>
> </SOAP-ENV:Body>
Previous Topic:Excel Report Error
Next Topic:Filtering crosstab data by dates
Current Time: Sun Jul 20 03:12:10 EDT 2025
Powered by FUDForum. Page generated in 0.03427 seconds
