Home » Modeling » OCL » constraint on EReference
constraint on EReference [message #882130] Tue, 05 June 2012 18:47 Go to next message
I have three ECore classes A ,B and C.
Now I introduce two EReferences from A to B and from A to C. as follows:
A "ref1"--> 0..1 B
"ref2"--> 0..1 C
My Questions is now how can I express that if "ref1" is set (1 B) "ref2" should be unset (0 C) and vice versa? I.e. only one EReference at a time?
Do I need OCL or is there some standard way to do this in EMF/Ecore?
Thanks for all help
greetings
Re: constraint on EReference [message #882239 is a reply to message #882130] Wed, 06 June 2012 01:26 Go to previous messageGo to next message
You may be able to to express this structurally by introducing a BorC
interface which B and C both implement.
Then you can have a required ref to a BorC and derived optional refs to
B and to C.
Ed Willink
On 05/06/2012 23:47, Roger Druback wrote:
> Hello,
> A "ref1"--> 0..1 B
> "ref2"--> 0..1 C
> at a time?
> Thanks for all help
> greetings
Re: constraint on EReference [message #882337 is a reply to message #882239] Wed, 06 June 2012 05:17 Go to previous messageGo to next message
thank you for your answer.
I have attaced a graph of my problem and of what I understood was your possible solution.
My problem is that the EClass A is in another metamodel than B and C and at runtime their will be instances of both B and C. So I guess both B and C need to implement the interface?
A should make the decision which instance to reference but only one at a time.
I am not so familiar with OCL but isn't there something like:
"IF ref1 set to B THAN ref2 = null ..."
But sure a good model without OCL would be better.
  • Attachment: questions.png
    (Size: 15.40KB, Downloaded 211 times)
Re: constraint on EReference [message #882344 is a reply to message #882337] Wed, 06 June 2012 05:26 Go to previous messageGo to next message
OCL is the power solution; you asked for a simple solution.
Using the OCLinEcore editor you can open your *.ecore file and do
something like
class A
property ref1 : B[?];
property ref2 : C[?];
invariant ExactlyOneBorC: ref1->size() + ref2->size() = 1;
[There are many algorithms for implementing XOR; the above avoids 'if'
cases.]
If you're really clever/insane you do it all with EAnnotations in the
Ecore Diagram Properties View.
Ed Willink
On 06/06/2012 10:17, Roger Druback wrote:
> Hello,
> Regards
Re: constraint on EReference [message #882449 is a reply to message #882130] Wed, 06 June 2012 09:33 Go to previous message
Thank you very much for explaining both options. Smile
I think I'll go with No.2 as I do not want to introduce new model elements.
Previous Topic:Association Class in Ecore
Next Topic:[Announce] Eclipse OCL 4.0.0 (Juno) RC3 is now available
Current Time: Sun Jul 20 03:56:59 EDT 2025
Powered by FUDForum. Page generated in 0.04694 seconds
