Home » Archived » BIRT » Excel Report Error(Excel Report Error)
Excel Report Error [message #881941] |
Tue, 05 June 2012 10:22  |
I am using birt to generat an Excel Report. While trying to generate it, i get the below error
The birt version used is 3.7.1
Jun 05, 2012 2:59:28 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingManagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://2384.fwk1280962114/fontsConfig.xml cost 143ms
Jun 05, 2012 2:59:28 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingManagerFactory$2 run
INFO: register fonts in /usr/openwin/lib/locale/ja/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_13/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ru.ansi-1251/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_15/X11/fonts/TrueType cost:0ms
INFO: register fonts in d:/windows/fonts cost:1ms
Jun 05, 2012 2:59:31 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingManagerFactory$2 run
INFO: register fonts in C:/windows/fonts cost:3611ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/truetype cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ar/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/WINNT/fonts cost:0ms
INFO: register fonts in /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType cost:0ms
INFO: register fonts in C:/WINNT/fonts cost:1ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_2/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/tt cost:1ms
INFO: register fonts in /usr/openwin/lib/locale/th_TH/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_8/X11/fonts/TrueType cost:1ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_7/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TTF cost:1ms
INFO: register fonts in /usr/openwin/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/truetype cost:0ms
INFO: register fonts in f:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko.UTF-8/X11/fonts/TrueType cost:1ms
INFO: register fonts in g:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_5/X11/fonts/TrueType cost:0ms
INFO: register fonts in f:/windows/fonts cost:0ms
INFO: register fonts in d:/WINNT/fonts cost:2ms
INFO: register fonts in /usr/share/fonts/ko/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/windows/fonts cost:0ms
INFO: register fonts in /usr/share/fonts/zh_TW/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/ja/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_CN.GB18030/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/default/TrueType cost:0ms
INFO: register fonts in /usr/X/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/euro_fonts/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/hi_IN.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh.GBK/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/OTF cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_9/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW.BIG5/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_HK.BIG5HK/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/KOI8-R/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/zh_CN/TrueType cost:0ms
INFO: register fonts in g:/windows/fonts cost:0ms
Jun 05, 2012 2:59:32 PM org.eclipse.birt.report.engine.layout.pdf.font.FontMappingManagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://2384.fwk1280962114/fontsConfig_win32.xml cost 17ms
INFO: load font config in bundleentry://2384.fwk1280962114/fontsConfig_pdf.xml cost 13ms
-> Can any one say what the reason for this error.
-> And how to overcome this error
Re: Excel Report Error [message #882001 is a reply to message #881941] |
Tue, 05 June 2012 11:51   |
I did not see any error in that log.
Jason
> run
> run
> run
> run
> run
> run
> run
> run
> cost:0ms
> run
> run
> cost:0ms
> run
> run
> run
> run
> cost:0ms
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> cost:0ms
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> run
> cost:0ms
> run
> cost:0ms
> run
> run
> run
> cost:0ms
> run
> run
Current Time: Sun Jul 20 12:33:21 EDT 2025
Powered by FUDForum. Page generated in 0.03537 seconds
