Home » Modeling » TMF (Xtext) » Set focus after quickfix
Set focus after quickfix [message #881260] Mon, 04 June 2012 04:42 Go to next message
We're trying to implement a quickfix using a ISemanticModification, which introduces a new object in the model. Now we want to set the focus to this model, to let the user modify (refactor) the newly introduced random name of the object.
acceptor.accept(issue, "introduce prototype", "Introduce a new prototype", null, new ISemanticModification() {
   public void apply(EObject element, IModificationContext context) throws Exception {
      Prototype newPrototype = ExamplePackage.eINSTANCE.getExampleFactory().createPrototype();
      model.getPrototypes().add(newPrototype);
Now we want to set the focus.
I understand that this would be possible by using
EditorUtils.getActiveXtextEditor().setHighlightRange(offset, length, true);
But we struggle determining offset/length.
I tried
locationInFileProvider.getFullTextRegion(newPrototype);
as well as
getSignificantTextRegion
but this seems to return bogus values.
NodeModelUtils.getNode(newPrototype);
seems also not possible.
It seems to me that the underlying model still has not yet been updated.
Anyone can give a hint?
Re: Set focus after quickfix [message #881411 is a reply to message #881260] Mon, 04 June 2012 09:55 Go to previous messageGo to next message
Hi Michael,
I'm afraid you'll have to schedule a UI job that performs that task.
Alternatively you may want to use the underlying JFace API that allows
to access the ITextViewer.
Sebastian
Am 04.06.12 10:43, schrieb Michael Ehrmann:
> Exception {
> I tried locationInFileProvider.getFullTextRegion(newPrototype); as well
> as getSignificantTextRegion but this seems to return bogus values.
> NodeModelUtils.getNode(newPrototype); seems also not possible.
Re: Set focus after quickfix [message #881864 is a reply to message #881260] Tue, 05 June 2012 07:55 Go to previous message
This worked for me:
final String uriFragment = model.eResource().getURIFragment(newPrototype);
final IXtextDocument doc = context.getXtextDocument();
doc.addModelListener(new IXtextModelListener() {
	public void modelChanged(XtextResource resource) {
		EObject eObject = resource.getEObject(uriFragment); //fetch our newly introduced prototype object
		if (eObject != null) {
			final ICompositeNode node = NodeModelUtils.getNode(eObject); //fetch the node, so we can get the offset
			if (node != null) {
				PlatformUI.getWorkbench().getDisplay().asyncExec(new Runnable() {
					public void run() {
						EditorUtils.getActiveXtextEditor().setHighlightRange(node.getOffset(), node.getLength(), true);
		doc.removeModelListener(this);
Previous Topic:Problems since recent update (2.3 RC1)?
Next Topic:Please help with simple grammar
Current Time: Sun Jul 20 02:01:55 EDT 2025
Powered by FUDForum. Page generated in 0.03214 seconds
