Home » Eclipse Projects » EclipseLink » Internal Exception: java.sql.SQLException: Invalid state, the Connection object is closed.
Internal Exception: java.sql.SQLException: Invalid state, the Connection object is closed. [message #879932] Fri, 01 June 2012 02:43 Go to next message
I have a JSF application that uses Eclipse Persistence Services - 2.1.1.v20100817-r8050, and I sometimes get the following error:
    Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.1.v20100817-r8050):    org.eclipse.persistence.exceptions.DatabaseException
    Error Code: 0
    Call: SELECT XXXXX FROM XXXXX
	bind => [/Home/Footer/]
    Query: ReadAllQuery(name="WWW.find" referenceClass=WWW sql="SELECT XXXXX FROM XXXXX")
I have no idea what is causing it. The exception is thrown in the following function on the "return q.getResultList();" line.
    public List<WWW> find(String url) {
        EntityManager em = getEntityManager();
        try {
            Query q = em.createNamedQuery("WWW.find");
            q.setParameter("url", url);
        } finally {
            em.close();
Re: Internal Exception: java.sql.SQLException: Invalid state, the Connection object is closed. [message #880180 is a reply to message #879932] Fri, 01 June 2012 11:08 Go to previous messageGo to next message
Does this error occur after a period of inactivity or under load? A google search for the error suggests that it can be caused by connections being timed out on different servers, so you'll need to look at your connection and datasource settings.
Best Regards,
Chris
Re: Internal Exception: java.sql.SQLException: Invalid state, the Connection object is closed. [message #881112 is a reply to message #880180] Sun, 03 June 2012 19:20 Go to previous messageGo to next message
Our site is never under heavy load and there is usually a few users online at any time.
Below is the properties in our persistence.xml. Any suggestions on what should change?
<properties>
      <property name="javax.persistence.jdbc.password" value="password"/>
      <property name="javax.persistence.jdbc.user" value="user"/>
      <property name="javax.persistence.jdbc.driver" value="net.sourceforge.jtds.jdbc.Driver"/>
      <property name="javax.persistence.jdbc.url" value="jdbc:jtds:sqlserver://SERVER:1433/DB"/>
      <property name="eclipselink.ddl-generation" value="none"/>
	  <property name="eclipselink.jdbc.timeout" value="20"/>
	  <property name="eclipselink.jdbc.connections.wait-timeout" value="20"/>
	  <property name="javax.persistence.query.timeout" value="20"/>
	  <property name="eclipselink.allow-zero-id" value="true"/>
	</properties>
Re: Internal Exception: java.sql.SQLException: Invalid state, the Connection object is closed. [message #881946 is a reply to message #881112] Tue, 05 June 2012 10:26 Go to previous messageGo to next message
Can you set logging to finest and include the log when the error occurs.
EclipseLink should be retrying dead connections by default.
Re: Internal Exception: java.sql.SQLException: Invalid state, the Connection object is closed. [message #882128 is a reply to message #881946] Tue, 05 June 2012 18:39 Go to previous message
I could do that, but I have no idea when this error will occur. So the log would fill up with a lot of junk, and when the error does occur, which is usually over night, the log file would end up being GBs in size.
Previous Topic:class not found javax/validation/ValidatorFactory and ValidationException.errorDecryptingPassword
Next Topic:Proxy could not create EMF from provider org.eclipse.persistence.jpa.osgi.PersistenceProvider
Current Time: Sat Jul 19 21:04:39 EDT 2025
Powered by FUDForum. Page generated in 0.04108 seconds
