Home » Modeling » GMF (Graphical Modeling Framework) » Adding new context menu option to a palette entry(Adding new context menu option to palette entry)
Adding new context menu option to a palette entry [message #839964] Mon, 09 April 2012 09:36 Go to next message
Suppose i have a palette on my GMF diagram, and have nodes A and B on that.
I want to be able to right click on nodeA on the palette, and display a "View" option on the context menu, selecting on the "View" option would pop up some info on NodeA.
How could i accomplish this ?
Pls help.
Re: Adding new context menu option to a palette entry [message #880262 is a reply to message #839964] Fri, 01 June 2012 14:10 Go to previous messageGo to next message
you should take a look to XXXDiagramEditor.configurePaletteViewer() and override PaletteContextMenuProvider()
regards,
Re: Adding new context menu option to a palette entry [message #881444 is a reply to message #880262] Mon, 04 June 2012 11:11 Go to previous message
in my generated diagram editor XXXDiagramEditor.configurePaletteViewer()
never gets called (tried call hierarchy and a breakpoint on both
DiagramEditorWithFlyoutPalette#configurePaletteViewer()).
However, i've found out that the palette viewer is configured by the
PaletteViewerProvider created and returned by
DiagramEditorWithFlyoutPalette#createPaletteViewerProvider() [1, lines 153
and 171]. This method creates an anonymous subclass of
PaletteViewerProvider consisting of quite a lot of code. I would need to
duplicate that code in order to override
PaletteViewerProvider#configurePaletteViewer(PaletteViewer) which sets the
context menu on the given palette viewer [2, line 51].
[1]
http://dev.eclipse.org/viewcvs/viewvc.cgi/org.eclipse.gmp/org.eclipse.gmf.runtime/plugins/org.eclipse.gmf.runtime.diagram.ui/src/org/eclipse/gmf/runtime/diagram/ui/parts/DiagramEditorWithFlyOutPalette.java?view=markup&revision=1.13&root=Modeling_Project
[2]
http://git.eclipse.org/c/gef/org.eclipse.gef.git/tree/org.eclipse.gef/src/org/eclipse/gef/ui/palette/PaletteViewerProvider.java
To avoid duplicating the code I might override
XXXDiagramEditor#createPartControl(.) to set the context menu on the
palette viewer:
public void createPartControl(Composite parent) {
super.createPartControl(parent);
PaletteViewer viewer = getEditDomain().getPaletteViewer();
viewer.setContextMenu(new PaletteContextMenuProvider(viewer) {
public void buildContextMenu(IMenuManager menu) {
super.buildContextMenu(menu);
Although it works, I would prefer overriding
XXXDiagramEditor.configurePaletteViewer(). Can anyone check whether this
method gets invoked, please?
Additionally, it would be nice if we could extend the palette context menu
using an extension point. Does GMF provide an extension point for that
purpose already?
Manuel
Previous Topic:hide specific model elements
Next Topic:how to show EClass,EEnum and EDataType in ecore digram?
Current Time: Sun Jul 20 17:38:29 EDT 2025
Powered by FUDForum. Page generated in 0.03876 seconds
