Home » Archived » Test and Performance Tools Platform (TPTP) » Testing workspace plugins using AGR
Testing workspace plugins using AGR [message #87964] Mon, 20 November 2006 01:42 Go to next message
Originally posted by: omkarashish.gmail.com
I want to be able to use AGR to test my plugins. Ideally one would want
the tests to be part of the same workspace that contains the plugins.
The problem I am facing is AGR records using the current workbench
instance as the context and my plugins are not active here.
Is it possible for AGR to launch a new workbench with my workspace
plugins and record the test?
Also when I run an AGR test the launched workspace still does not have
my workspace plugins enabled.
Am I doing something incorrect. Is there a better stratergy to eclcipse
plugin testsing?
Any help would be greatly appreciated.
Thanks and regards,
- Ashish
Re: Testing workspace plugins using AGR [message #88008 is a reply to message #87964] Mon, 20 November 2006 10:44 Go to previous messageGo to next message
Originally posted by: dequeker.gmail.com
As far as I know, the plugins you're testing need to be present and
enabled in your TPTP workbench.
After copying your plugins into the TPTP workbench plugins folder, is
there a reason you can't enable them?
Ashish Shinde wrote:
> want the tests to be part of the same workspace that contains the
> plugins. The problem I am facing is AGR records using the current
> workbench instance as the context and my plugins are not active here.
> my workspace plugins enabled. Am I doing something incorrect. Is there
> a better stratergy to eclcipse plugin testsing?
> Thanks and regards,
> - Ashish
Re: Testing workspace plugins using AGR [message #88126 is a reply to message #88008] Mon, 20 November 2006 13:07 Go to previous messageGo to next message
I am able to get AGR to work after copying the plugins into a TPTP
workbench. But I have a set of plugin projects in my workspace and what I
wanted to do was launch a workbench with these plugins enbled, run the
recorder and also launch the tests on these plugins. All this without
actually copying the plugins to a TPTP workbench. This way I can use the
same workbench for development and testing instaed of using the launched
runtime bench (and hence a new workspace) for creating tests.
Thanks and regards,
- Ashish
>As far as I know, the plugins you're testing need to be present and enabled
in >your TPTP workbench.
>After copying your plugins into the TPTP workbench plugins folder, is there a
>> Hi,
want >>the tests to be part of the same workspace that contains the plugins.
The >>problem I am facing is AGR records using the current workbench instance
as the >>context and my plugins are not active here.
>>my workspace plugins enabled. Am I doing something incorrect. Is there a
>> Thanks and regards,
>> - Ashish
Re: Testing workspace plugins using AGR [message #88266 is a reply to message #88126] Tue, 21 November 2006 12:30 Go to previous messageGo to next message
Hi Ashish,
See enhancement https://bugs.eclipse.org/bugs/show_bug.cgi?id=109880
It was marked as helpwanted in 4.3 but resources were not found to have it
implemented.
Ali Mehregani
"Ashish Shinde" <omkarashish@gmail.com> wrote in message
news:c91312053003ad0f15caa4540c7be008$1@www.eclipse.org...
> Thanks and regards,
> - Ashish
>>enabled
>>> Hi,
> plugins. The >>problem I am facing is AGR records using the current
> workbench instance as the >>context and my plugins are not active here.
>>> have my workspace plugins enabled. Am I doing something incorrect. Is
>>> there a better stratergy to eclcipse plugin testsing?
>>> Thanks and regards,
>>> - Ashish
Re: Testing workspace plugins using AGR [message #91238 is a reply to message #88266] Mon, 15 January 2007 09:38 Go to previous message
It should be possible to use a clean workspace for both, record and
playback. Currently a clean workspace is supported for playback only,
and most of my tests fail, because there is something in the record
workspace that is not in the playback workspace and vice versa.
Ali Mehregani schrieb:
> Hi Ashish,
> implemented.
> Ali Mehregani
>> Hi,
>> Thanks and regards,
>> - Ashish
>>> enabled
>>>> Hi,
>>>> Thanks and regards,
>>>> - Ashish
Previous Topic:Probekit extension
Next Topic:remote agent controller dies with "free(): invalid next size"
Current Time: Sat Jul 19 19:23:01 EDT 2025
Powered by FUDForum. Page generated in 0.04405 seconds
