ESC keybinding firing twice [message #878757] |
Tue, 29 May 2012 17:45  |
I've been testing the keybinding using the org.eclipse.ui.binding extension point and I found an issue and this is, with the ESC key sequence my action is firing twice.
Here's the configuration I'm using to register the binding to my action.
<extension id="test.ui" point="org.eclipse.ui.commands">
<category
description="Tool Bar commands"
id="test.ui.category"
name="category"/>
<command
categoryId="test.ui.category"
id="rap.test.app.TestAction"
name="TEST ACTION"/>
</extension>
<extension point="org.eclipse.ui.bindings">
<scheme name="key scheme"
description="Application's shortcuts"
id="scheme.id" />
<key commandId="rap.test.app.TestAction"
contextId="org.eclipse.ui.contexts.window"
sequence="ESC"
schemeId="scheme.id">
</key>
</extension>
With ever other key sequence I've tested everything works fine.
Can anyone tell me if I'm doing something wrong, or is it a bug?
[Updated on: Tue, 29 May 2012 17:49] by Moderator
FUDForum. Page generated in 0.05620 seconds
