Home » Language IDEs » ServerTools (WTP) » web.xml error timeframe
web.xml error timeframe [message #87873] Tue, 29 March 2005 01:59 Go to next message
Originally posted by: qminor.austin.rr.com
I know I'm beating a dead horse here. I have searched all through the
newsgroups and read all of the posts and I still don't know where to go. I
am new to the eclipse environment and I am new to XML and Java. There are
a few people who have made this error disappear and each person has their
own individual way of dealing with the error. One post said to use the XML
Catalog tutorial, the other said to change the plugin.xml file, the other
said that the new link will be set to redirect, the other said you can
download his patch.zip file and everything will be included except the
file was empty, etc. I have found the folder plugins/org.eclipse.jst.j2ee
but I don't know what to do when I get there. No one is giving any line
numbers of files. It's probably just me that doesn't understand how to do
these things when they are explained. I am just not understanding why
there should be a hyperlink to verify XML rather than just downloading the
file to your computer and use as a parser for example.
Never mind me! I'm frustrated. Does anyone have a timeframe or can anyone
show me step by step a workaround?
Re: web.xml error timeframe [message #87889 is a reply to message #87873] Tue, 29 March 2005 02:26 Go to previous messageGo to next message
It's no wonder that you're confused. There have been a lot of posts about
this topic. Hopefully this will clarify some of the questions you've
asked.
The WTP XML validator uses the Xerces parser to validate XML files. The
Xerces parser will go to the net to retrieve schema files when the files
can't be located locally. This is why the remote resource is being
referenced.
The XML catalog approach
The XML catalog allows you to specify XML schema and DTD files. When these
files are requested from Eclipse tools the XML catalog will be queried
and, if the XML catalog contains the requested file, it will return the
file from your local location instead of the remote location. In this
case, there is a file that is not available at the correct location
online. The file has been relocated to
http://www-128.ibm.com/developerworks/webservices/jsrproject /j2ee_web_services_client_1_1.xsd.
If you place this file in the XML catalog you should see the error
dissapear.
The org.eclipse.jst.j2ee plugin approach
This is really the same approach as the XML catalog. The J2EE plugin
contains some entries which are currently commented out. These entries add
the necessary schemas to the XML catalog through the XML catalog's
extension mechanism. The schemas can not currently be redistributed with
the WTP project as we do not yet have the legal clearance to redistribute
them. If you download the schemas, place them in the J2EE plugin, and
uncomment the entries you will achieve the same end result as manually
adding the schemas into the XML catalog.
The redirect link
The reference file problem started because the JSR109 developerWorks
project was closed at the beginning of March and all the files in the
project were removed from developerWorks. The schema file that is
requested to validate your web.xml file is an ibm.com resource that
redirects to the JSR109 project. As the project is no longer available,
the redirect is invalid (causing the referenced file errors). I have
spoken with the JSR109 project lead and the necessary schema file has been
reposted at a different location (the original server is no longer
avaialble). I am now working with the ibm.com webmasters to resolve the
final issue which is to correct the redirect. Once the redirect is
corrected this error will dissapear.
I suggest you follow the manual XML catalog approach as it should be
easier to follow than going in to the plugin.xml file of the J2EE plugin
and will accomplish the same goal. There is a tutorial describing how to
use the XML catalog at
http://www.eclipse.org/webtools/testtutorials/M2/xml/XMLCata logTutorial.html.
Hope this helped.
Lawrence
I
XML
the
Re: web.xml error timeframe [message #88013 is a reply to message #87889] Tue, 29 March 2005 08:21 Go to previous messageGo to next message
Originally posted by: jeremydyoung.sbcglobal.SPAM.ME.NOT.net
I'm going to refer to my post:
web.xml error. ( Possible Solution ) ( j2ee_web_services_client_1_1.xsd
not found ) ( reference problems )
The reason I wrote that post and had to solve the solution that way is
because the XML Catalog Tutorial made no sense to me. I spent a good 5
hours looking through the newsgroups and I still don't understand the
XML Catalog Tutorial. I do know that in my Eclipse XML Catalog, it
shows all the files that I redirected in the Plugin Specified Entries.
I just downloaded my patch.zip again to verify that I did include the
files. If there are any problems with it I'd like to know. I'm really
just trying to help people avoid the time that I spent trying to figure
this problem out.
If the tutorial had helped me I'm sure I would point people there. But
the tutorial definitely doesn't address where to get the supplimentary
files, nor does it address where to put them when you get them. That's
what I tried to do as well as provide them a set of files with the work
already done.
I've been using my "patch" at home and at work, and I gave it to a
coworker and it's been working flawlessly.
If the patch.zip is failing to go through some filters etc, please let
me know, I can re-attach it with a different extension like patch.piz
I'm not here just to randomly spout, I'd like to actually be helpful to
people.
Re: web.xml error timeframe [message #88187 is a reply to message #87889] Tue, 29 March 2005 10:55 Go to previous messageGo to next message
Originally posted by: hoichong.dnium.com
--------------000206070300050107080308
Hi Lawrence,
The XML catalog approach just do not seem to work. I have followed the
XML Catalog tutorial as best as I can and after adding the missing XSD
to the Catalog, I clean the project and rebuild again. Now it is worse
more errors highlighted on the XSD file itself. Please see attached
screencap on the errors.
Can you provide a set of files that we can just import into the XML
Catalog and get it working.
Thank you very much.
> asked.
> referenced.
> dissapear.
> The redirect link
> Hope this helped.
> Lawrence
> I
> XML
> the
Content-Type: image/gif;
name="errors-with-webxml.GIF"
Content-Disposition: inline;
filename="errors-with-webxml.GIF"
R0lGODlhAAQAA/cAAAAAAIAAAACAAICAAAAAgIAAgACAgICAgMDAwP8AAAD/ AP//AAAA//8A
/wD//////wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMwAAZgAAmQAAzAAA/wAz AAAzMwAzZgAz
mQAzzAAz/wBmAABmMwBmZgBmmQBmzABm/wCZAACZMwCZZgCZmQCZzACZ/wDM AADMMwDMZgDM
mQDMzADM/wD/AAD/MwD/ZgD/mQD/zAD//zMAADMAMzMAZjMAmTMAzDMA/zMz ADMzMzMzZjMz
mTMzzDMz/zNmADNmMzNmZjNmmTNmzDNm/zOZADOZMzOZZjOZmTOZzDOZ/zPM ADPMMzPMZjPM
mTPMzDPM/zP/ADP/MzP/ZjP/mTP/zDP//2YAAGYAM2YAZmYAmWYAzGYA/2Yz AGYzM2YzZmYz
mWYzzGYz/2ZmAGZmM2ZmZmZmmWZmzGZm/2aZAGaZM2aZZmaZmWaZzGaZ/2bM AGbMM2bMZmbM
mWbMzGbM/2b/AGb/M2b/Zmb/mWb/zGb//5kAAJkAM5kAZpkAmZkAzJkA/5kz AJkzM5kzZpkz
mZkzzJkz/5lmAJlmM5lmZplmmZlmzJlm/5mZAJmZM5mZZpmZmZmZzJmZ/5nM AJnMM5nMZpnM
mZnMzJnM/5n/AJn/M5n/Zpn/mZn/zJn//8wAAMwAM8wAZswAmcwAzMwA/8wz AMwzM8wzZswz
mcwzzMwz/8xmAMxmM8xmZsxmmcxmzMxm/8yZAMyZM8yZZsyZmcyZzMyZ/8zM AMzMM8zMZszM
mczMzMzM/8z/AMz/M8z/Zsz/mcz/zMz///8AAP8AM/8AZv8Amf8AzP8A//8z AP8zM/8zZv8z
mf8zzP8z//9mAP9mM/9mZv9mmf9mzP9m//+ZAP+ZM/+ZZv+Zmf+ZzP+Z///M AP/MM//MZv/M
mf/MzP/M////AP//M///Zv//mf//zP///yH5BAEAABAALAAAAAAABAADAAj/ ALvkGDgmx48c
YxIqTHhoTMOHDiNCnCixIsWLFjNi3KixI8ePHkOCHCmyJMmTJlOiXKmyJcuX LmPCnCmzJs2b
NnPi3KmzJ8+fPoMCHSq0KNGjRmsyVNhw6cIxXQoSHLhCRg6rOAYeLMgVYUKv XL9C5RoVYdmx
ZsmqTcsWrduzcNe+lRu3bd25dunqzcsXr9+7gPf+FRy4b+HBhgkrTswYsePD kBc/lhy5ceXJ
lilrzswZs+fLoDd/Fh26c+nRpkmrTs0atevTsFe/Dtu1NsLbtm3nyCpjBQ6s uwdqFX5wq8Hj
xocrP778YHPi0J9LZ07defXo16db346du/bu4L+L/89O3nv58OfHm1+Pnr36 9vDfy09P3339
+Pfn29+Pn7/+/gD+J2B+BPpXYIAHDmjggggyqGCDED4oYYLXHVLNPxhmqOGG /xwinEMchqjh
IQINdMg2Iop4iAy9xcDib79dFVxWNM5oI283ylgjjjvqaCNwNQIZnJA8/pgj kT4GeeSSPSLp
JJNGNgmlklJWGeWVVGI55JRbWpnll11qWSSYY4ZJZpJmplnmmmiy+aSXarYp 55tizsmlm3fa
CSeee+pZJ51nAhqnoHz+mSehfgZ66KJ9Iuooo4Y2CqmiklYq5iHUHALIIVx0 wQWnnobaqQxc
ZJqVIdsYwimonbYaKg6eVv9jyFWH4ANPMerg+ks6xaTzSzG7+lKMsNQYEoOL MuRRxR/LNqss
s9BWsZtzWQ1UbXDWCnftttp2m+232IbLLbjjiuutueSeW+666rab7rvoxssu vPPK66699N5b
77769pvvv/gGzC/AAwvsr8EEH1zwwgo3nPDDCEfMMMQTS+ywxRRfXPHGGnec 8ccYh1zwP7Gs
Esshqxyi8soqB0LiGFxwUc1AHZZ8csosH+JyFyR6+k9W/8TTzD3xxGMMPOrA c3TSuPYq7Da9
VUUFFSpQXYUTV1PhBBUpUNFEHllaJbaMY5dN9tlmp4322mq3zfbbbscN99xy 10333Xbnjffe
evf/zffffgcO+OCCF0744YYnjvjiijfO+OOORw755JJXTvnllmd+Vc2q4Lyp yp/y7GoM/1jV
ocmqqvz5qqJ7ysXPMvxjjNBGK620Okc3rc6vmvyzwgou/lG1Ck88kcfxWydP hbQ9hh0mcNA/
L32R0VM/vY/VY3999txv77314Gsffvfjfy/++eSjb3767K/vfvnwqx9/+/O/ L//99ONvf/78
7+9//QDUXwD7N8D/CfCABESgARPIwAU6sIAQ1F+HDnGynPHsgj2L2T82R0GT 5YxEILxgF0gn
Axz8Ax5FY0btjmaMXOWKV776RelUIDWq5UEVziDFKKiQh6k5wQkpqAKO/9IW oxKKrYhIPKIS
r5JEJi7RiE6MIhSn2EQqPrGKWLyiFqWYRS5u0YpeDCMYx9hFMn6xjGg8oxrF mEY2rtGMbowj
HOfYRjq+sY54vKMe5ZhHPu7Rjn4MJCAH2UdC/rGQiDykIgWZSEYu0pCOjKQV //Ep1a3KVa6C
FQlNeIjUrSpEoSIV7P5RDNtNg5Qv/JUMmwGsYvTudyz6AxVW4Ix/5AMQW/hD HmSJh60xj2Ya
mlmhKBWpYppQQ1XC0G7+sY1JdWlDqwjOhYaZoUdZipjYHJQzh6nNa3bTmN/M JjfHmahwmpOc
1gQnOrdZznV6053qbKc80ynOebKTnue05zv1Gf9PfMKznsCZIM5UdsGxdOGg MHvdMrswUJ2B
8qBdsELpcvAPdagQHhnSXTEy6quNyoCGMlheHpCRjz/kcpfLmtrXAvoPFcSA Gv+YmeYshyGX
ulRtGIpBDi6kU8XV1BAwVcXm/uGitcFiojK40CpUwCLMOXWmT40qVKcq1apS 9apWzSpWt6rV
rnL1q14Na+T+wbNNuYwLgThopw4Kq06RkKI80xQI19oFWJG1ra/7DSltt1EM 9UqGGPJFOoT1
SqbK4A8pyMMzVEEFQPzBsbrk5S+PWVQMNTCCBMSQENGXU6sga4GdjYVlKdrS 51nWdKXF7AMV
qNrWsva1l4XtamNL29n/2ta1tcXtbWWr297y9re5Be5ug0vc4RrXehNcGQaj AlGIanBzcT3E
QzcI0bdWlIVKy2iGdsVdGX5UaqsARHjlKt5NAcIQgACbjGq6OWpUBUUxvUos LlSNFeUApswU
mzJjt0H+VkOm//0HNWJhFfxCbW/sFVs1YFoNApNWBdUkLYPle6FMFRhDBx5b ggXsIgxVJUPV
WAV/lamhC+d3qP+laIAHXGH7gvXFYo0xjGcs4xrT+MY2zjGOd6zjHk+Vkpe8 5KvqSmTreopT
IerUXbsgA4lu7hcubNqGBCsswvquKslSbHgfy2XIUoFZwiGttOgbAxRVQxXx xZAh/gGLnZLs
/6jNJO0K5ExaVcSizMwk3cwuFIujblBgGhrIhbZBOmoIRLNiFvOEMQQIAbu5 z8rEFqKlS1Q6
48AKa67Gof9RhTl7uAp8hjMw7Uy6mK6ZZKcWmcdUDTKOtXrV17LKQGQto1kL h9a4vrWubc3r
Wvs6170G9q93PexgE1vYyD62so3N7GI7O9nNhvazlz3taFNb2ti+tratze1q ezvb3Qb3t7c9
7nCTW9zoPre6zc3ucru7Qy6LdwgNKpCE/pmsK+sQBv8BFbIKhMkT/QevkHar W3GUu4P1qApY
EFJAlNfhmkKvIbisXqAFUwU4uBDGLYshVbCIvx0eJVFBTvKMt9SIJP/HUBG1 p+GWxkAFbsb4
xx9Mc/Zy/B8eZ1FnVd5yFVjoH3/Q68jhm1Oap3zkPO/sMTde2qKPbYgsj3r0 nr42qE9d6lui
utmsnnWsc/3rVQ/71n1Mdh6bvexoP7va0872tW8V36Hj1Fg6lQMi193IooP7 QX+GISLjQKGx
g7JGpzzYwf7ilViW5R+coYomRBYPsvTDFJYX5pyimRoW11AMKN2hmlfa5k0v baKFwyGdZitD
3kL0MiutraLnlLKk3XyGPFT61mvIWKiFcExLrdPXex7mrhc9oofPaXCF+VrH D/O5kq/8cDFf
+chfvvSNP33nVz/61M++9bWP/e17v/vgb/7/98Uf/uaXH/rkT7/51Y/+9bu/ /fB/vvyvz/75
c7/+9H+//cev//zH3//7d34BiH/3138F+H8HOIAGyH8IyIAK2IACCIASmIDd 4m86E0IvcxZ1
93cbZEL7Nm/8poEANwMUxSu5YnB+xVFU5l0rwHBflgJO8Ax/MAU95AdTM3lB VCPsdSFCVVMr
YFNXcSGls3PudXQfNnL3VVr65Ts2VVRjA4Q9JyMoAnNRCHrAp4RCyF8/+HJO +GAv11QgV1NL
Z3Q75zuxQw0hVxW/Z3Rt14Zu54Zw+IZyGId0OId2WId4GDsycGQhMgaw8oc5 YGStQkkwAzOE
GCSxszmCJWV+5SsZ/+IL4uALvkAJvhMDM3BYKdA1OUQKeGCDNsg1lHcbiNYI KmdmojUz29BM
GGIFPEhmpGUIouU7dJYDZqZibkYNgyYcJaJ8u4hoAlGLMbVp0kJ8VSBa1GAF qUharChguTgQ
wqiLwLQCKGJnHTd6HuZmquCK15hoxFh34reLYQaO0Nh84uiM33iO5IiOvKiO 4ciO47iO6RiP
8DiP4leP9niP+JiP+riP/NiP/viPABmQAjmQBFmQBnmQCJmQCrmQDNmQDvmQ DmmBXQBKaFFX
JkQzOQBCfVgW/xY7JChwjIhKvZIOGSIOhlc6LTgDoDgKXaNLW9M1mZhYlSd6 orUNJhdTHv8X
i2emU0JYDRiXAzoZfDFQLQvGTCIGlBliCDgQgRsiaPR1lKuAc55XYS7Sk6ow Z7H4D0p5LeyF
fMZoctsQVEh5b0SVFT2JcbC3huy1gBFIgW7pgBMIl2/ZlnLpa2FGa3cpfnhJ bHnZfHvZa32p
fH9pl3xZmIBpmIR5mIqZmIw5mI6pl5Dpl5EpmJMZmJaJmI8pmZpJmZt5mYuZ mZwZmp7ZmJWJ
maX5madJmp1pmquJmq2pmqLJmrHpmrMJm6OJl6UTKn2IEDVCOjQjKgcld1EB Kxt4FYk4A/+w
iOnQDCIJQ74QNIM1iVcWSy9INdZZNTC5PFJhEC4VZirABQMRA1X/YHpdcFMl IgNVAHNhJp4y
8HLhqZ7OeCymdxVWwFT9qALp6Z7hOZ53aRXdmVPs6YwuNZ9NZp/K153iFwMC gQMqwGRDuRv6
qZ9XkZ7rCZ/4ORAXmgMZCpEc2qEe+qEgGqIiOqIkWqImeqIomqIquqIMSVZ1 x1wZ6BazdpEU
9aIZGKO3USK+WYK70jQm6DSFR2XP2Rsu2ENVwENIaqRJeo902aQEWJdOOpPw +YBUGpdRCoFP
eqVVOpdZ2qVs6aVY+qViGqZkuqVQCqZmqqVWiqZrOqZpyqZc6qZtWqZz+qZy Gqd0iqd2mqdn
eqd9Wnl72FZDBoi8gQM72l/A2Sl/WFdD/5KIseMLvyAs3AUsCUdlkSidx9JU JPghnNoVxlEc
nLoc22kdoxqq1FGqUyGq2IGqt6Gqrnocqneqqzqrr0qqtCqrtWqqtpqrqYqr vrqrv6qrwtqr
wFqsw9qqwUqsx8qqzHqrxqqs0Iqszyqty+qs1cqr1BqtzYqt25qs2fqt3Tqt 4Xqt3jqu2mqt
58qt4redYcauptqu6xqvzeeuvQqv8yqvykevyGqv+Yqv/Pqv7xqw9Sqw+0qw +nqw/mqwCTuw
DFuwDKtpi6qog0o2CkVREptJfseoVuFktDgsraRKwxKk0SksKMkCl3gvLJqi EpqyLNuyLvuy
MBuzMjuzNFuzNv97szhrItTABS4SAzzbnj/LIj1bKh6SA4ZQDVbQnkDbs4aq tD0rKzp7eIen
CZowtZowiVhLCZuQKTGAZdXnsDkbtmI7tmRbtmZ7tmibtmq7tjfLeSkSTEVb d277trNXIjMw
t3S7DStCpGAYds1zLunWboHrboNbuOtGuIdruIKbuIy7uI6LuI+ruJA7uZJb uY1LuZdruZGb
uZy7uZ6LuZ+ruaA7uqJbup1LuqdrutZGgo1zia57LCdrRCu3h2KjsdJzh7ib h7qbu3HDZGjj
u2UDvGQjvLWbNsR7FcdLu79rvMy7vM4bvM0Lvc87vNFLvdNbvNeLvNWLvdLb vdbrvdz/+73i
G77kq73Zq7zga768u7vsu77uizixe7KXmJJK9CIf9xv2m78ot7/4y7/3+7/6 278CDMD+G8AE
PMAGnMAFvMAIzMAH/MAK3MASDMEOHMEUPMEWnMEVvMEYzMEX/MEa3MEiDMIe HMIkPMImnMIl
vMIozMIn/MIq3MIyDMMuHMM0PMM2nMM1vMM4zMM3/MM63MNCDMQ+rMHtuQIC 9g/4kMRLDFNN
rMRMHMVOLMVQPMVWXMVY/MRaTMVbfMVdnMVcHMZeLMZgPMZmXMZo/MVqTMZr fMZtnMZsHMdu
LMdwPMd2XMd4/MZ6TMd7fMd9nMd8HMh+LMiAPMiGXMiI/MeK/0zIi3zIjZzI jBzJjizJkDzJ
llzJmPzImkzJm3zJekwN/gDKohzKpDzKplzKqHzKqpzKrLzKrtzKsPzKshzL tDzLtlzLuHzL
upzLvLzLvtzLwPzLwhzMxDzMxlzMyHzMypzMzLzMztzM0PzM0hzN1DzN1lzN 2HzN2pzN3LzN
/+APSQzOMCXO3xzO5jzO51zO6LzO6tzO5PzO6QzP7CzP7hzP9jzP91zP+LzP +tzP9PzP+QzQ
/CzQ/hzQBj3QB13QCL3QCt3QBP3QCQ3RDC3RDh3RFj3RF13RGL3RGt3RFP3R GQ3SHC3SHh3S
Jj3SJ13SKL3SKt3SJP3SKQ3TLC3R2/9c09180zad0zi90zrd0zz90z4d1EA9 1EJd1ER91Ead
1Ei91Erd1DsdylkM1U2MAvgg1Uxs1U6M1Uos1SiQ1V6s1VX91WId1WOtxWB9 1mV91WJN1WpN
1m5t1mnt1W/d1nA913Jd13hN10mMAmht11sd10rc1X4d1oPd13l913qN2Ir9 14UN2IR92IwN
2Y+d2JFN2ZO92Jdd2Zht2JbN2Zvt2J6t2aKd2aQd2qUN2qjd2Kot2abd2qnN 2q/d2bH92ast
27VN27B926Pt2rqND6eMAsAN3P7A13z9y8Et3KNM3MPNy8Atyl1dy88ty9FN zMd9zMXN3MFt
y9O9ytc9y9X/Hc3RHd7UsN2pTN7GPN3dTcrp7dTszdTu3d7w/d7yHd/0Pd/2 Xd/4PdTuLNjv
zN8R7d/rzNcCJuALDdx7HdMHjtIo4NLhDOAKTeAE7tIO/s/8PeEZveAwheH/ oOEAveAyXc4e
PuDyHOEfXuIIPtMnzuAovuIq3uImzuIv7uIpHuM0PuM2DuM3LuM4vuM63uMv /tuorNzj3dy4
vN7HvdzBXeTLPd6gnORMHspd/dzf7eTZPdzIDd2/feVU/uRJ/t3erd5IDuVE PuZaLtxOTsvX
XdzifeTa7dxuHuVnPuXILeVQ3uZgPuR07uX3vef53ed8/ud+HuiAPuiCXuiE Ts5T/33c+BDl
i+7Egt3Gxx3Yjj7ejZ7HjL7hWLzgC77Emo7pnJ7pnh7qm87Gwf3ppn7gwH3q lD7gevzocM7q
sN7pGR7qq27HbL3qoy7rmG7rjU7Vgt3pn67hwI7pGM7Wo37Gx93ct+7rtX7r mczJ0O7J0f7s
0l7t1H7tnYzt057t3L7t3m7t3Q7u367t4l7u5H7u4Z7GQJ7cSM7maB7kYC7k Ss7kUl7lQh7l
bm7lyu7cet7myd7k2S3ed77kaG7vA6/meL7vA+/dVf7k9J7vX67cCL/mb17x +G7e5c3uyR7m
TX7ohv7xHh/yID/yIl/yJH/yS73fAT7c4/3RAA7hLE/i9/8s4J0e4h4e5eCs 652e87ve8yCt
6zzP88Le4ONs4StP9N9c4bMe4rNe9BP96wlO7CDu0DiP81K/9FM/9DXv8/bM 9MS98krv4zle
4zxO9mJf9mOf9mi/9mff9mb/9mrv9nEP92xP92e/7vFO8OvNyumd5hw/71bu 8AL/8HVO8XV+
+LqM74Vf8Yiv94Df8ZC/5IpP+JH/5ZBv+A6P5Yg/+Zwv+JG/96qM3o4v76Bv 8qaP8qh/+qqf
+qy/+q7f3lhN1VxN6fou28le1dUt+6lu2a6+6ZGe4VBd7MEd2FQu/I9O2Yo+ 4M1N/GZexQE/
1act6X/t7MNv6qWu/L/+6GhN/WL/buDF3fPRL+zB7+nDzfxqvvyVnv59reGV Xv1wbuDRn9vy
b9vzj9v0f//2n/+7Pdv739u8Xf8A8Q+fP2oC/xUciPCgQIIGETbEtzChQ4YK H1qsSHFixIsa
IUr82JFjxpEbQWI0KfKkR5QhSa4s6TLlS5U1ad6cmVPmzpY9Wf6M6TMoUJhF beoUahQnT6JH
ZVIjGBXqVKlVqV61mhXrVq1duX5F8dXrWLFlyZ41OzUsWrZp2751GxeuPxRz 5d61mxfvXr19
+f71GxjwYMGFCR82nBjxYsWNGT92HNnsP38LKxe8TNnyZsycNXcG/Vl0ZtKe S4cmjUL16dGm
XaN+3Rr2/2zZtS/Xjc1ad27etHf77m07OF3gxYUb/31ceXLmw50jf748enPo 1aVbp35de3bu
071j/749fHfw5cWbJ39efXr23yG/lxwf/nz59enft58f/379/fn/9y9AAAcU sEACD8xPIgVR
WlCjBkt6MEIGJ3SQQggtlLBCDS/cMEMOP/QwRAxH7JBEEE0UsUQVT1wxRRZf dDFGFGdskUYY
bZSxRh1v3DFHHn/0MUgch+yRSCCNFLJIJY9cMkkmn3TSRQSnNLBKKq+0Mkss t9SySy6/9DJM
MMcUs0z61hsvTfTURHNNN9uEs7035YyTTTrvtDPPOfWsc08/+wQUzz8FDZRP Qv8PNTTRQRWF
8x9HH4U0UkknpbRSSy/FNFNNN+W0U08/BTVUUUcltVRTT0U1VVVXZbVVV1+F NVZZZ6W1Vltv
xbVVpobiVSmkmloqKaeEDRbYX3sd1thdfV02WWSLffZYZomV1tlplaW2WWiv jVbbare1Nlxw
x/22XG/PzTZdbNftVt122eU2XnHNdVfejCrLNV99SyWzXzP/9TdggAcWuGCC DzY4YQMfVbjh
BBFdNOJCJYZ4YosrxpjRjCnWuGOOP77Y45BB3nhkkxGtrGSVRV65OodfRjhm mGeWuWaab7Y5
55kZ1rlnyKJEMugmhYaSaKCHRrropI9WummmnzY66qX/pXaaaqinxrrqrK/W uusc8d0aoWlS
Gbtsss82O22011a7bbbfdjtush21mmic7/Y5b7z31rtvvv/228yD4kvF78EF 1uyfaVo+Obdp
HK1YcZI9czQViyu//B/LGeecZc8nB73x0Dsf/XPRTycdzYg2XnzfU1OnDirK CgfcLMvhm31h
alIRK5RlTlnGd+CFJ+sg3h0zvvbAlWd+eeeb7/dwwlPWjHrrq8f+eu2z5357 77MvyGCIppl3
mXovoiZ99ddfnyn202/qcZmkYWYaZui3XxpqD5qGV2oIIQQYCFEIbbyrW5iz SaXMR5TKocse
oWAGKu6hEwSSC13wmtcFDWgv/3ph0ILn+6AHO7jBDIJwhBzUIApNmMISipCF ISQhDJWSmRjm
ZIElIV+kTsGMHe7wUWCDFBB/OCkhQo6IR5QUEFtYQ2/Jzh+0a4v5zKeXgiyE bgyjW1ngV7nd
jeV2WUEFFh11P7fkbiuv+EIrXOEKAH4hfYZJnla2AAsqVOMf2/iHHfEYiuJR oxl3eccy/EE+
VHgljlt5I1R4xxdQKAM/i3xeJKEnSUpOcj/SW4wUsVI47DGjiv9gxjK6N8rv lZKUp2wIl1QD
lVVG5TOtC80WDCHLPxjCENuoxu/+sYwFpqeKn4TUL5UTTPjp5nGyOWak7lE/ 5OSQNNoAwyse
t0ZXvP8CDNogFOZ24yhVdFMVhTAEKJOjzd7YAx7+2II/lkkbcoJmd/ALn3iI 8Q9laCx8sDMd
Pku3T9Tl05/81Gc/92RE7GzBoAdVRS5Pscte8k+IC33UMpnhukwFtDKr+QdG 32hGqzTCEB6N
BSyqkcuB+MMf+JjiXuB3OyzeLpFaEaajqvHSTWIyKhM1xDcN8QfFLVN/Y+Eo VQRIiCqycRAA
hOM75UhHPDb1jv/gY1kOSZZAorMf97hHHwyp1Ku8k3aUoelZQEGZlEbGcgex ZCXVmla2rhUt
POPLDWLBiJDGgqQnPWlZOUm9MFJDFYqzXxhNOVhUFlZ791TlWlopkRxCSJb/ j1WFIWa6DFD0
AxTLUJoVIyVMCoVPfSyd0DFRksxJTXRE/VsQAAnxiketEYBGqyCHuAmLbtby H6jAUGwlZA9m
+KMf6lymPUCk2/ClopufXOT6OjTWylyWGJRdxjyN9L5PUsNrdQtbdq+rXa51 F7vbBa93uftd
8QLJUUU76Ba4sAVVwIKylsUsY4H5D4hGaqKTUo1qXEdeEq0yo2ERiBOheJVl VAOXBy7INk5h
D1D09i8rXUg8XcoV3i0ywmitcFa+iJUwdrMQqqjlH/5QDfIB9YlZycIXssBa umWBEFlI6h+X
Wsen6hGqfZRx71AhClRM46r3WMY7pOpHRKbibPFE/7LmugIKvJY0KgNh8oOr K8awttXKbr1y
ln0GOcKE4sCoOHA1TiENUGzyerilLSyoUQxQFKN7uKELYeVsWLDaFEGtbKUT HeoZUeLRUX6m
zG/vMZv8alQ0BZkpkgkizNNwVn1//SVqjnmaYwIaUoJ1HGrAkGIWa+MLXxAg cwoNYNa0szV4
7GZOwbmNQsbG1KXBbfqcwQysMsMe49RcbeKpm2JuhskmBXawTSpI04yanZaS naTRBtB/CtTZ
Fm02tJk97WenaXXjOYWfmwFoBZv2lUIMBaTC7ahxRwoFjzq3o/KLbv3+N93p zmi8393udVdK
2rIRsFaYYWMba+Mf9tilV//y+xV4evWdnqUwWu2I5CoOOCobrkpf87iQhee4 K0GNCiE+Hb4s
gAHUhEDLwLd6vK3MkQp45PeNh0zyrITis7sTRZDTMtWuXgUfZt4KKO6hTp7v 3Of+iLJWRI7I
JBfdK0ZuBt2wvHQtN53pXrLzXLyMxzCi/I6nMDP2UJHoYtyjH/bgLZuLwUfK wBk3575ovFNm
9jiXnS5oh7Pa5Z4yxP5rfCqpr6Ud9VtmIAsFv1r4xBEd4acg/H13tG5I5IeS ZswUBgmFBQxG
So3HH4V/QYHmaj39aUKoQx3G8PyuAEzBXCfwH94EsaNwy0AltwQVEfysM0Ih XGbFNiSJPNzh
rAv/k2X83PfqLIZQRu+Sol84njk5JhNXuHwXMl/5zYf+86WvwuhTf/pLtH72 sb99GSaLhiwE
8x1TgYrxN4P84cbhfEUxcT4KG9jjLjS7163ftKs73vZH+/3VHf8hYvGE3M+J fNuKrZs4q6sM
gIsqu4AnzdkdWACtKnsi45NAh1OkqAujF6CGFzgIKoCFf8DAFzAxClw0FxMg UJuGTUAIFPQL
mpMKk0s5PNKqIbM4Ars1l0sFZ0gFUYgLFqy59DEygysLneuHaQCFIjRCYiCM CvOqm+uimXO6
J3w6KJRC5FE6wuiDHEwFnuI3l6uKvdIMNFuznRO0ngu3tsu//KOe1WC7/zVc uzQkpbrzl2/z
jDCilHtQPfOIpw6ElL8KvEYLvD+kuF7DjEnjjGnYBiqghpOrBhjYhkNMROZw Js7QBgASIM8D
vUuEB3UIj1fbDFT7pn+gRJBztVw7DXv4LUfRQd4JN+PgRHeaiu3oOsuypyS7 t1qMtlukNlvM
RVystl2knjkJv1yLlD4oRCHyg6fio99SRt/yB/hDN/uDRvx7Rng7N2qEFGuk FF38DAG0CgL8
s4h6lARUKcPzwYL7ioPYhvCZKXQsCBGEOKq4QMr7BzoqCAyEgRBEi2Iwhk1g hnjYR2YIPr3g
QYIwOavbhhcDAydkual4B34AG3+4QnHso4WEKf/1gQtQsIeApA9ImsKOjMKP 9MhLqsLA6AM/
O8Zv/Ac/yDrqEQU/QAVUCAWvk8mruqoyjDu4w6h1uyj6c7e6uEn6y6/Dijow kS8HWb9IuapL
U5p2jDC/ksCS8CtqUDPeUYV3msrdswjR0ohUqIbIS6hFHCmvPC0Y+YVNKEs4 MEuzbBLiogin
wiNQgxG2lIaH7AeYjBG2vJAF/BE2Gy+9LK+/5K/xEszwCkzCHEzAPMzCRMzM gho/8LOzghRi
TL9KCYWvo0lT9LqxoqhgSswd4car2DHyw6ohZAYe6wNU8AMqIsfkap9NUrOo VLOqTJ/2ckcL
xCV2TEdcokiswLiv+IX/XyiGTSgG4DTLwTiIGayKPhCFPvAD5eyDhHwrIrOK fvghabCHGGyL
4wxJkOTO7fTO7syKkUQM5pyC5vSD8iRPlezC75k9sLsHsLOH9yxDOpuz+qwz g5HD0KGu/dS1
/VQuSSOozzCyASXQAV2OSKQNdRhOYwDOXwC9TSRFPmnFRonQXbTQXsRQbdRQ XtzQC+1QZ7si
fWodygyFUACFEjXRctvMANVFRTKyp3vHwkiFZhDB/6DR3RSMscHRw7jR7/RR 8PzRIA0c8SwQ
L7TPI6VP+oTDMnmh/+u+J3XSKG3SKXU+7YNSKq0+AMTS67vSKtVSL+3SLA1T LpVSMC1TMT1T
/zLd0pW4ojTloMayUjdNljZdUwAU0jsF0jzF0z3V0z6VKiLFkhUlFfz80ELl 0EP1UETNUEU1
1ER11EV91EbtJxZl1EqN1N7g00z1003V1E7l1OfZrE+9ssUkVcU01c40zFQt VVRdVVU9VVdl
1Vf9mgZpj2vrDFvVjGu7NurZ1STdHiMC1sQR1ofsP0FVFRpq1WSV1WVdEU91 VlGF1meV1mil
1mkFDEjFVknVVkvNVm7d1ksF124N128V13Il128VCx3V0Rkd0HW90bNBunYd 0Hd1V3mNVyOr
V3ydV3tlV329V3jtV4Cl133114DNV4Hl14H914NlWIJF2IJVWIN12P+GXdiJ tdiKvVe3UNeL
lViM7diPjdiQTdiRhViSfdiTpViQNdmUFdmSdVmU5diWhVmPlVmWXdmYvVma zVmVfVmb7Vmc
/VmdDVqenVmi9dmirVmgRdqdTVqhXdqhbVqjVdqjpdqptVqnPVoIhIqnIBs1 PZ8nIi1jNZUj
M9M6HVNuGRu8QondQa0vRVOzldOzdVuvfduytdu6xVu61ds4hdu+vdu9nVu+ /VvBJQqyeUWo
tIom1JLdEdYgQqJIKaLGLVbHTaLHpVzInZQB1do85UipUFxrrdbQBd3RFV0v aYbF4U3SwIfN
wcUIFNtYMVxv9afCUV3WHVfZvd3cNVfc3V3/3T1X3v1d0Mkhd/LcGhUQxo3c 5LXcyWXeYL3c
521eyXVeRzldu1gNarhe5+HIzy1d0vXe7gXf792PaUBdV8pKWGURagjbf+Cp 122VsYGfH9Ev
fJjfVfWDlkRNP3DJ+2WQ/dVf1MTfyeSIto3VAkZfZTVgBD5gZl3gBGZgBYbg B5ZgB3aQwkHc
qdjRAJmGPxIN9sWM4CnRhpqyzAhRzQqNEh5hE+5gymHhE96Mzo2L683eATlJ SUnNrajhSLlh
qSC5DBbf8AXiHxbiIGYLhxMNlrKo1Z2UGi6GZvQHN3PfStnfS3NJSkmFm7sO /cLecyudHL40
1rjf/UVNAA4NlkJi/+BFY99N495l4+Bt4zV24zgeDgS9ihLjkrFB4T/wg0Lw g1DQhDuwg3Fz
4UEWDS5eYUIm4RY+5JNkZEc5xhSGYYGriy02EP215Eve4avw4kfJZILIMTsm 4iEW5VAm5VGm
Cof7CMsZiEIblr9TiknGFtcdohrmo01oRszlP+XVP+nlZV3GXEipYf3lZOW1 sBEavsHNoE1W
vZhQ5VyL22f227wlXMCV22qGZmS25mim5muW5sD15mzGZm7eZiol4JvjYbVA Z79YC7mAX4qg
hj9AiGLQhBINPncePQA7vgs7t5HI5yTj5wbp5wuLCGLUYX++sEiO4UkGGGVO SavoYVMu5f+I
huiJLl0jzgyWMuRqjLctBjD/0kl3A2nkUOJgrWFfxsZ6ezuNvj+U5r96g97p NaIcbrXKhZQr
Lg/ceFSGXr2LXogzVuOffmOglmOhhuOiJuqjfjY6loocW+ewkOF09smoiOp0 ZmdOAo0/uIxl
GDvfOQ2cxumyw97M0OjUCOuD8EnMILXpyOFjbA6EPguFDhiG7mT1nQrkpOi7 lui8xmunM2KF
aGZW3ujA5uK/MzZXLghDvpEIvB6eqowm5iM3u55CW7v5SxyeTOmxljf+4x4j oh7OPkpgHlbs
MaJidpHRi2AH0WkIaeZmnuAGdu3Tfu3Whu3Zlu3apuDYvm3aduD/cr4Kkltn gmhqqI4zqoDr
39ZYDkYyPdbjULCDO5jnosNnsw4fp44njcbe6b5u6Y7u4uPuCAtmgk5JCSw+ txYLuDYTS2ZO
THZoDN5rvXbv9oZvt7Lonl4IQ067+1Y7p74N4tCM/Cvr//7qk4JM6qFlJy43 NzSiM5y7d5M7
zHbwsoMcs+NsYT1JUaiMk2w1Yu1szbBp6Vg3pDZjow7qER9qEhfxEkfxE1dx klHqqbBj4/7t
oGQl4M4zkcMzqcZxqmjn5A4fFD1R6E4ywKbsw+7Jwx64kBbs+hbvg7DkeLLk JR/vzbWkT47v
Kn/vK7dyvEFlv/4gw+7SCMTVY8TVyhhz/4MojTJH80I2881I8zNvjTZn8yOO X22eZhRabXDu
Zjwf53Cm828W5zr38z7Xc0Af9EDn80PP8z83dJbg7XOGC+MuDPhNpUlHrNx7 xUundEvP9Ff8
8E339ErHdFD/dE1vR7KJwofG8lTPclVn9baab6bMRSUmc+7p1Vm/nlpfc16l 9V2/dV7HHlwH
dl9PGQQ1cesIcaROcWRf8WJn9mRv9mV3dtJocU8Gkx0f9VAn9WzH9m2/9m4X 9W/X9k3/QSuz
Y7tu9XNf9XRH9zDpa4NgbQeOQGWfHLLNbau5c9zGd93Od9ve93r3934HeH0X eH4feIdodPbu
kg0GXc2FHlRX9/+HX3eIl/i8eHXNkZuLh5uMx3izefZd1PiP33iQF/mQl5ue JvmRR/mTV/mU
Z/mVd/mWh/mXl/mYp/mZt/max/mb1/mc5/md9/meB/qfF/qgJ/qhN/qRJ14X n/g9pfKId/ql
f/qop5Itd/dCt3pFv3pBx3pzuXet93pE3/NE/3qxB3tC3/qxD/u0N3u0X/uy X3TlO3iC8GGp
r1aHp3uox/u713u3qHif7vi/j3Y2OXbAh/bCl3fCP/zAT3zDz9Bpl868R4wY vZlyh/y9t/zK
h/h2j4h3D3iC9/wNSb6reS7FvPeC7/x/N/3U//zTZ33VR/3Vd/3Yjnuuuny0 8KoiHsr/vhir
oNsPu8f82v/94M/rvmd8xlGf9RDE4wCmXXsNrSSNqKzK6I/K5KingBOZwVd8 xNf+7Of+4vf+
xQf/7XB8UHbW1qN489eiqXi5DEs4Cguz91eFsRgrKKMsZbgs3leMphf+/Qf+ /h9iqgcIfP9S
/cPnj1rBfwgNLlRY8GDChRAFSmxYMeJDixkxMuQ40WFHihtFhgT58SJChSUv kjyZUuNKhyn/
+ftnEyHOkdNsrqS2TVUhVamEEg3aEiExf0qVGlzqD9TJkSZhRjVIUODVqlqp cvXY9ajXsGDH
ThVblizLs2rTspXaNibcrWbfykXr9m7cr2vx1t2bdy5fvXQF/wcG/NfuYb99 BxteXBix48SM
IROW/Fhx5ciaM3OdRpLawYOpQJMOXfq06dSoV6tuzfq169iwZ8cmiHA0bmqp ZPvLjdvh7tnU
cg63rXB4a9vJt/3ZVs059OeFYoPqd68fqOzaodLu7nq0aO/ieY8vT/68+fTo 16tvz/69+/jw
58uvT/++/fz49+vvz/+/fwECOKB6wYVGE3AO1YTQgggyqCCED0roIIUNWhhh hRheOOGGGXKo
oUw2iTjiTSDORKKIH354nG4eOriThj6pss0/NNpkoyoq/lPdPct0+KOCf+Dh BxVEEomCHy4a
ZxyQOjbp4pNRmgjllFI6WSWWV2pJ5f+WVnL5pZdhZgnmmGJ2WSaaZ6pJ5ppm svmmm3GmCeec
crZZJ5536kmnk9NIeFozAgpKIH4hEseia6CBhGEzsg2nUI7H2YYcaspVuk0h 29BIYzU1/jMd
bNVxd9AyprBXBR5UTEEFFUjK5udBgRI6KK2z2lorrrfqmiuvu/raK7C/Chss scMOaKCiDV21
KEzMcuQsSdBK2yy1z1Yb7bXQPtqgSNw6m5O3DD6KrUP/wEJcizmRBCO2Mtro qYiqkCsSKMU0
BMoyy0zLkZBHJjnvQAktmy3B1hoMcMEIH7yvwg0z/HDCEC8cMcUTW+xwxRhf LLHGHXP8ccYg
bxwyySOb7HH/ySifLLLKLbP8csowW+sZSKeBVyzO/D1KmkIQDffacPiQJvRB QlOa6G2pFFJc
KqMdXZqlqaXC3DYw3AAD1ld/Cp8y/iwzaneoujrbzTcbmzPaZ6udNttru902 3G/LHTfdc9eW
GoVM5skn33b2reDOfv6MnImDD+cni1yG5k+O6UK0IYwcuuvppjVGCiQxyyiz TObKIOh5l38k
+eSSe/t9uump74n66qr/3Trsr8vO+uyu03677bnHjvvuutfeO/BwIr7gabDW fbxqyCE7n9NP
16YbNUsLhVttPV+a6bvvgkqdP/d0/7333oMNoKzUGG838umjv7767bP/vvvx wz9//7HLf5QV
Z43lT5n+/fNvNDUs05Of+c9wX2GXS1QxIxTZRF57qRcEi8Ej7PhPMcvCXwUn g5kMXkaDHuwg
CAW4GQ6KcH8b/N8JU/jBEpJwhChcoQtVGMIYwtCENWyhDWeYQxa+UIc41B/N FmIz+aVPN/tx
Gn2okSPqsSZqqGnOjUREo+2JBxTXGV9+ykZE+nFxi17sIhi/KMYwknGM41le 3nzHu9+xcY1h
MqCHIuchogyljkRZk6jamKDbqLGPwXOjH/X4x0ACcpCGFCQiC5lIQjLykIp8 ZCMXyaDhHcc0
5SsjJtXnxF2FAosEMt4lzZjJUYqylKQ8pSlTicpVggaNyv9aWcxiCctZukyW tSwIu2R2y10G
DCu01CUwbRnMXwqzmMQ8Ji+NmUxkDnOZzmwmNJUZTWZKs5rUvOYzLRLEggyR ld5UJdq0+M1x
gpOc5iwnOs+pznRWCm8N0psjIwnJeNJTkogsXT3naU998lOe/sznP/cZ0H4C tKACNShBD9o3
Sj7tfOxcJ0TjUz6HRrSiD72oRTOK0Y1q9D32eyU+ppEKkZJ0pCYtKUpPqtKU snSlLm0pTF8q
05jSdKY2rSlOb6rTnPJ0pz7lqVUE5sMe8lCGRb0hUWk4VKMq9ahLRSpTd9jU qUq1qj9MqlWx
etWobhWqXn0qWJ2al20SjTTgYSD/WtOa1i2ota1ufStc4yrXudK1rna9K17f Gp69crSvHfUr
YP8q2MBuEY3vLFde0crWxDK2sY59LGQjK1k+UlahCb3sQDOLUM1alrOY3Sxo Oxvaz4o2kQwF
lKLwygxmTIMZKFqsZGMr29nStrZ0PQgoCTvY3eq2t7z9rW9r5UqhCuSuMLKJ a0cEWxGhwLbO
fS50o1tXX1J3mtnEpnWza83rcle72N2ud7sL3vF+t7ziNW9400teipC1myNq WiqaAV/5oigV
fkjFdaRxD2ZII0mLXa5NmivdARO4wM/lq9mCC9wFK7jBDH6wgw27xxEdl8Io +oMqnOKUf/wX
RQI2MIhD/yxivFYWnqUlLYo9q+LRrvjELU4xi2PsYhnDGEynNQ2s3stcERHk wuAD3z9UsYUb
wMLDAUaBgJGM5BEzuckjjhVpKOrgKUO4ylS+spVX+VHiWjjAIqqwiP4QPut0 zzpqbe6H0bxj
J7O5zc8NKnWp2tWwylmrdubqnb8q1jrjuc965vOfs+pnOgs60HPec6EJfWhA 67C9pjkrj/+h
5CUTpNIB+0eP7vGPP3C6Cpz+g6f/QCI0T1rSa3YzqlMNWQRjudVZdjWsXy3r tEm4sl8+NZhF
xAyv/SMW2/A1sH8NiFGbekRpVjWyk03igFW2xs5+MbRpHO0ZU/vZ0r52tadt bf8b/8mSqbVJ
j4t9aRIx4x5M2K+5YhGLasBC3cMm9rGPrex509utuCVNKGet71jze9/+7rd7 hlvdW6Mo1/+w
hz3sgPB/VEPdDucCA5O8ZEkrud4WvziJqjsw9K5XvRz/+HlD7nGRd7zkIB85 yk1O8pOrPOUR
cbRZvz2QpsmX5uEWUaaX0SNpqCIWhoiFKiAe1w9jvOgWZ/W/kw5wpTN96U7v jTsnTNdl9CPh
0ugHM7hQBa0LfehG/3q9S6ztsWN722Yne7bLjvazq73taV9ot6Mscx2nVef3 CMU9egT2vfNd
rVC+d9MD//TBC77wgd3ywOc6jWUUI1/LMHjfI/91OPf/ktGIXnSiL59nRW9e 84P2vKE7b/nR
Z570mD+96EuvetR/fjMw3ytaby752dMerUgnPO4Nr/vc817LUbd17YMvfLWK 3e1sf/vxk7/2
5Ruf+ch3vvIdeWN8zz3Sb11ta4ev/WQDnhr57j34dy/+8JPfbQLvJV4rnNzt s5/NGmc5/Fcu
f5fPv+X2jz/983//+uN///rv/8S8HvTUBI/ZnM3V133l1371VyqIgn3J3pFN XPtNoGzd3vhd
YPllIAZu4KDUGrN1GYnkGoZpGAmqwigYGQWm4GwV3/M1nwu2IAxGXwxCHw2+ oAzeYJlMH+DR
nbhB4Kb9WPh8j6ihoLFNnJrJ/1vFmZrEEZ0Kat/fmY8GRiEHTqEUVuF5IB76 EZy4GZyYldmY
hc8QepgR7tgYelm8JVkTpiDlYVDqsV7otd7qtaEcwqEbch4dzuEb5qEd6iHo 7aEf9iEgml7q
CSCkgRvFVZylWVoV5B2ofVqoNWIYGtmkqRkZRuCSpRkTpuHwWaAVdiIVfqIn hp8HGocWfpjB
AcJ13AMgBBsrvlvEiZuXVSIszqIEaqLwsSAO2mANzqAu9iIv/mIuAuMuXpYO ep/MhduH+eAi
2sMWrFu7OaO7nZm4UeKpxRsR2mLwdd/3gSI3hmI3fuPTnd+yaCEIjggX2MMq qlvDOVwsdF0R
SmASMv8h0cUjc9UiNtbe+/GfPv7fPvqfPwJgPwIkPw7kPwakQRIkxxHiMRpg fPlgDFRBz/1c
RAKdO96jRSYWJ4KjRnojR25klY0iYtHV1o0k123dRZ4kY+HiMK6kLwajS7Kk MLYkTL6kDRZj
jjGQD6KkTtbWE0qZR3YkUP6kUD4UFo7jTh6lga3hHwriHTYlHzLlU8ahUy6l VEZlHQZiVVLl
VUKlVuIhVSokAdaXXVEDKjACIZxI2yClsmVkULblUL6lW44RSJ4IRhbCPeAD LKABWlKbWiKb
SsokYMakYNLkYM6kYQYmYTpbMcpK7MEV9rmWKvyDNEzDKxgCbKVlX6qaNsb/ JVx2Jmd+JiaJ
Y0IY14gwAyPAwjScAir8gSGMCHehQMRkZqrlI0IeZEHWJm7epm4K5G7aJm/+ pm8GZzSB5Xsx
JH2RyAMqIH8VAhqEQSj4geikiD+gQGxQJ21YZ2pgJ2poZ1jKZpuxpWeGJ2iO p3ia3+99IDmm
56ZlGAn6gyEcwh8Awh+gJXVqCGzySX1OCJJNiHe62V8WJmIeJoAOaGIKaIEG KILOjk0eI04y
0B8A4YJ8GlpOJ5JNZ2hQp5IdhJKBBoZaKDVsqIe2Bnf2p5v1JHmeaHmiqIrq SlGOpk0YHBd+
YZmpFT7cZ40uBGyiAEXoqIbWaHPdaEToqI1OhY4u/wqJul9vEBdXYuVWZiWT euWTTmWUWiWU
LqmVOumVNqmWVimWcgZxRtokBkwiAsMvkKmZdpojcpp0YiebhmibtumHZih3 lsaIHqmTgeeK
5mmK7qmeesdclqN6/kI8xIM6NEM8AMOvJSqwuaJC5KejTieD3CekPqqk5uiP SGpI2qmI/eeB
EqiBfmqCdqqogqqntuRiMqhYkggwNMM/HMM/NIMxPCO7ReOaXqitwqmFvumt VifeaCqTbSaf
BmufCiuxnhHegBSgviiK/EKhvqo6/MI6PhyKCASSUeuGUhxCVByQAumkbeui VFxD+OqI0WZv
5iZwmqtwlqu6nuu6piu7vv+ru5Lcl4KbcUIgMABDPPzDoQLDRAYdimCmuIYY nhYrwQ6rwZbn
n9LVLwhEvuLDL5RkRaZIIk1ic3VIwIYYp5LqqIaqxnYsx35sqYYsii1od8YV MBjDocbDMQCD
WwHsxRaYiRaszB4szSJsatyPi8oVs+6sMfzCW00pXrwsiCkl0BZtlnLplkrp 0SptlyYtlTKt
03Yl1CIt1U5tVM1rYuWk0FrkwNas184s2Ephwm4t2aJVxoLsxoqsx6ot2q5t 2r6t7ZxqyeKV
1rrVHZRtNkLhE4Yt336t336iaBbXczmevoSCHRgu4uKt5JErvKKr47br4zYu 5E6u5FZuvEZu
umL/bV3VXEPSHFqBwohQgx34AzPg3T3YQcTZ49AloeJCV9f2Lez+rewy3dja lQ/6YDFYRz/o
Fz6EwjTcwx3sVyikVSa+VfG2rnOdLdsuL9y2rfMyr9tG7/NGCcnmFTJaH4ks g0FMgz/07uHe
Afga7t2+4iHGYrHR46iVoRKerxGqLvLanjF2X+zO7+zWL+3eLLLS7anh7o/5 Qyh0zx34wzQM
L1rJ4zQSW/ke8Bma7wG/b1sR7dI+rQRL7QQbbdNWbQVHMAVvsAVHbQdjMAdT lebSFauGKasm
ok00A2vtSCiEggS18AsXsCWaYT3aIzXecANb4vE6sIi8rv3+MP0GsW7V/25d Xa8hMpA9+IM9
/IPupqLuErAkrhklypssri8NM/AO8zCJKG/zQu/0Sq8Xh3EXj7GByq317i8D 3YPVado96Jc9
tPHdEW8OU7EBW+MVwyIVazGKACsQ97EQ/7FvBe4Zpyq59YMUYN3BqbEa9wMU v2MN53GplVoE
PjIet28WazHjXi7larLlYq4nb/IndzIoj7IoB+BnPFr1zRXnrjKKMIM9SMMy IJwrI5x+NbIe
X5wPA7Iu+zEvmxMRyxbCna4a20MLu7At37LFcTEYk/EXN7MYLzM0O/PIxt0O NlbdVkdr6Vcx
IHPfxWwvf/Muh3M5tajg0hY+5EvjFYOmcfPeQf/wBVttBr9zPHuwBn8wPIew POMzPeezPc/z
IJ5yzM3tXdUtO9deLoMzQouzQiPPLxd0fyqzNEfzM0c0RU+0RTOzZZmxNdvV NLwD5Dk0qvHx
Qo90Qpc0GQkyiL1DPdQD313yXLGuXFFjgcH0XWVyKHMyTt+0TpNyTvP0Tpdy T/ffCKvyfM2X
XBGDMihDOTuyJB+iDdM0+dLVPM5iXk11AstxJmZx8UJ1DevwqeHVQZO0WJs0 WRtLQ8vV7TLQ
DYjBFoiBD7g1DtCEMtSD52C1FMuw19VVVj/WXjNwFBch8fY1VStwVC8bPl20 RGO0Yic2Y1f0
Yu9O9eqv+SojDGwBDFD/QWXDgE1oTl3LMBLidTVOcjxaMsUhsBnS4xLSMCTX IwKP9iWa7/HK
9DWG9lYzljePNW6XtW6bZ2ng7FLTlRGPG4mAAXEXd3ETA10L9B0vYVarr0zT 8flisbEp8F47
93R/NRrSNh6T7w7HNhnCtEv/bJLGGT/Xs3mXN3rvs3qDcD/rM3uf93rfc3tj 5VDLVQmX2gmL
qU3UgCIQwiIQQn+/Qg3gA3ITA1azrkujocRVYyTHolUvdyW/dhVLN2xDtw2n Lld391fnMFgP
oIfnNojvtoj7ylnHVXDnJBjUAA/UQIqvOBj8g+a8g11zOF4/Nw5fd3ZLtx0T 9oRvN1VL+Po+
/3hhb7hpG7Bfj+UHmthjI7ZjNzaTP/mSR3kOUnP8DnIPMlAxZLkxF4MLZzkx uAMx/DaED3aR
/zWP5/h27/iOH/lUe7cdr/Z1R7c0jjmZz5VIjzieh7ie2wdKD3SDokgxxEO5 MQM8DHo8FIM/
FHj6ojmpgTd4d/WRTbKcz2PFNTqjV7ppY7dTNzoln2EeN3CYYjikH/l0od/G BTWq/3Sq+zSr
A7Wqv3qrr/rMADTs4dUqGzWgFwMz6Ho67/o2J7WBx1Z4z3RhD3ubGbvfeXiC 7Tmz57mze9R5
kqJtaUIxULu1V3u1/0PmBLtkIbt0bTWQgxjFuhVX0xVEQ7mTS3mTr/87urP7 GEc2YxE0SEfe
bT+7vTc7vsMGOc+7nbpzfPuzfMP3e6f3wP+7ewc8wSO8wc+3wGNGfRcxv29f WN87xec7bpd4
xO/kuat7u3c8x398uoe8qVI5Y250XXX0R2f8r+pt/Fa8y1v8s/d5gak0S6v8 bJq6q8c6rOc8
z8u6z+/8z+v8KD88XN2658YVUis1hruvXpN7U3t105M6Uk48zFf9y/cyxr9V WqPIWrf1W/tA
XPvDXHf2bFc1ucux2Wvqxou8x7M9yLu728f9aMG77aIxilRBZmO2ZW92UqO9 pFc6Jqb2VfP4
kFeip6c2p8Mj06tgvVu941/9xeMvl0n2lTP/kHFfPnJ3DWi/+R3DGxFauhg+ NWwT/hTTuS36
e8GnvsKrPsC3/sG7PsMnPOw3/OzLPj4T/Vvdd8Xlt6X9A3/7N4ATgoATeD1w e5lfsYIvumx3
vtT7OOmf+WmXewpSPeRX/+Pzbda71YmjVYuzuIqzOIwrg4xHNedb8ejXtmBf o4VXcemb/0Wu
PdzHf9vL/9vPv/0rJsmnMlrbPYlkOZf/P0CEKjaQmDti+P4lVPgPhcKGCRs+ lMhw4UOKFhdS
hOhwo0aPHi1G5BhS40SSGVGmVLmSZUuXL2Em9EdtGrWZzWzmnLlTZ0+eP30G BTpUaFGiR40m
RbpUaVOmT51GhTpV/2pVqletZsW6VWtXrl+9hgU7VmxZsmfNpkX7NdXPf9T+ IUwVN6bKuSjv
ZiwWj9k9ZvD6MotXzB+xesRSYkSxuONEhowfQ4ZcseLkkJM7QlwssrFIxxIx 1xU9mnTpjHLp
zkUIdzVd1m9dx249Gzbt17dl19aN23Zu3rt9B+89HDjx38eFF1eO3Hhy5sud R28+HTr159el
V9eO3Xp27tu9h+8+Hjz57+fFl1eP3nx69uudT5vdM5VN0wmbpdKff3/KgcyK AXCZAAf6Rxll
ELtPwQUZbNDBBxmcqT4J1apwLQsxvFDDDDnc0MMOQfxQxBBJHNHEElE80cO2 dPrHH9jmgv8L
wpU0KabGG2208R9ilklwxh+BDFLIIReCK8Z/jnwRLiVdhI3JJ52Mckkpm5zS yiqxhPJKLbOk
kssvvQxzSzG7HNPMMtEE80w10ySTzTfdjHNNOduc08468YTzTj3zpJPPP/0M dE9B+xzU0EIR
BfRQRRMllNEva6qyp5pebDAvIjHNVNNNhbwpJ0pTDFVFUUkd1dRSUT1V1VRZ XdXVVmFl66eZ
UqOL01txzVVXTfHxRzUk46J1NmFrI5Y1Y4PlDdlelW1WtmWhdXZYaYul9lhr k30WW2a17XZa
b6sF91pxs/3W3HDPHTfdctFtV1132X1X3njp5XZde+HFd159643/llx+Afb3 XoHzJXhfg/vd
FuGAFW7434UhdnjgZuWrjT77LN1V4405xpTCj2MN+dWRRS6Z5JNNThnllVVu 2VQWd8LyyI5p
rtnmjY2E0dGdF+W50Z6B/lnoR30mOmijhy5a6aOXTprpp52OGumpm6Yaaqul rtrJSJXsCadK
Gbz05rHJLttFmnL62uW1WW6b7bfdjhvuueWum26dYLbvtV83XcbvZWbEyOzB zUbNcPjaSxzx
xd9r3L3HFXc8csgZp1zyyifPHPPNL+/c8s819zx00DknXfS3KmbtYrBL4y8V 15tRCZSFQnnp
pI84QmkzwVXifSXfCQ+eJZAnvNvu441P/x755ZVvnvnn2c77RSZnNk3shK7/ p5h+7ulHGr8G
/Lv33HHPjHyYgE9M+PVfytn9rK/WOv754a8f6/vltz9//OnnX//+9xdAAA7w fwX036O49pZJ
Ycx6KcneMno1DX8wa4L+qJ36MgMaDTomI5vRjGRAuMEPso+EKfHUTEAFPRU6 j4UrdGELYfhC
GbZQesTiWwPx4h9/3GOHPeThPS6oPs9kECTlI8kRyceZi5SQiafxVa0Y9jCJ FWyKB6tiwqSY
xYlpkYpctKIXsbhFMXZxjF8sYxjJmEYzqhGNa3RjG+EYxTPKkY10fKMd4xgx MOKRjxFLXVxW
p6DY7a4hsZvLIf9/AYxELjIUAgFFI4vxSN0tcYNKVGISi3gZDyKxiZ0kXgxB OUNRhpKUozRl
KVG5FOnJDDb3yd711GEMfBhDHsZQR/dwyb1+BHEkS8QdJymzEWAKDpidLOH7 kiRAAyrzgMx0
JgGbCc1nLlOa1aTmNaOJzWlmk5tVSyA1vMbA0rwSJb+Ixz/OGY9f3ON79mAn EMdHRGHmjpi9
nCcRi2lM9qEwban05ykB+k+BBpSgAy3VKvdmKxxmBJbGSKct3RnRXf7ufB6M jGIsmlF6alCe
odEn4Q73q9ON1HQlHd1JS4dSkqrUpCl16Upf2lKYzlSmNWXpTWOK0/P8ER+B vA/s9PP/unIa
4xj/OIY6fmEPpX6Plx916tg+WVCpGnSqVaXqVa2aVausknqtJJI6YhdWdTRS IE196llphsxt
rtWa3WwrW7X5VrnGla5urStc7ZpXvO51T99cIOuE9It1NAOs6kTrYct2QrRp lbFYdWxjIftY
ydathglFCKaQaoxfIFUdiPWszXr1K9XocY6kraNp74jaPF6xj6xVbWv3+FrZ upa2sa1taW97
2tymdrerte1vcQtc3dqWpz7NVfY+m9xNRXWyzY3sc50bXehO1ytc1ZmMlJtd 7RYJWO/T61y/
e1fw8lW85Q3vecmL3vGu17zp3Z9fefK1XSF3u/WFED8VS139/0qXv/v1b3+x ilAoEi58gLPv
gWMSUpvmlME01emCHdxgCE/4wRWWsIUjnGEKX5jDGtZpcXkyoVu9LqiuU0kx FjI7l1gmIru7
6GUSwxjLvBjBnGLuf3EM4BzvWMc9VqF138epaaRkyChZBi7f6bcAGVh3MPYd MYEHGnvW+FZq
Za9623tl92qZy1n2MpbBvOUviznMi4Lvp8SZqbxYJHuhqKBNIjhBJneQkuX7 CAeDyZlLUllT
ik2hjwHNY0EHmtCDFlFlByxk8hU5I0f24aNVPMkhurii5qNnSWjMZ0yFFoqz FS5vP+3b4I56
uKQGtalFXWpVn3rVqWb1q10da9iiev/Wra41rG8ta09PDMQ5ETGn5kJIYB0S WKHoxzTucY9I
QvKRjqQzpp+c5xFius6aXi41ilc8Qxea29v2drfBfRQgd/dWjLYIoxdyZO6p O5fdk8acqb3n
DAr72Saxs7WDZOUxd7nM+/Z3vwFOZoHze+D/LnjA13TmE46YfNkDxT3sUYx2 vtOd0jBrPaNt
Pt5xUMb47vNiqaG2b4883CUn+cl9LODDKRol6FZIMeyxjIhCvB8Vh7elW2zR Ip4vMiCRt8eB
pGAMb9jDHSb60YeedKMrvehNR/rSoe50pj99p/MJcZoxReL9BDUldpC4Uu0h DaWy06xAV+6N
TZ52lK9d7W3/B+i4q0e2skKSrCg2u331jXCDE5zve/e73gF/cMH3PfCEL5rC Fzvfuy9+JX52
++PZHnnIT/54iF454zHfMU4bbte27jyuP6/r3uaa9KEv/ehNn3rUrz7Up2+9 6l/PelrDfvY0
sbqvsb4p+mbe42iX/O8pH3zgD79VcPcq75GPq7wP/u/ML3zzDR996E//+dV3 PjMRL19d7T75
fMZvyIUffuKPX/zll1WLLEvgYvit+9oVetSpHv+pzx/+9Jd6/fF/f/3LP//8 379Ke+1jRgyo
9OPEUsx2MEnYKK0yWmwkFrD9FsT3zG8Cya8CKVD8jA+7NMXlEoID/4HdkmxA mOHm/+TJlzCp
3vIJAhlk+aTP+lrw+l4wBqkPBmdQBl2wBrME8SiF4XIIJdyMguIMH0hw50yw BC/N3lTwQRzP
ApnwApvwCZ3QJiwPWC5rUzzQAx3thyCNoobooj4o4/Qs05LwPjaPCmnP82QP DWNvDWuPDdWw
DeHwDeUQ9NKQDt3QDuMQD+dQ9O4wWQIQ23JvSILNxYjtkBTpEBOp2ZbN2eis C+tJmCSjMYpw
DBVEAqHwEqMQEzWx2zKw3IgMJYAhHggrHtRJl3Lp3STNlx7RiCTx5yiRNFgQ B29wFmmQFm2w
FnHxFnVRFt/LSsIJsLLOgVDCGMLqH5oBGCoO4sgunojQCP8lUTPu7RVF4/tE LhOtcROx8RoD
zC3Sj+UyggM3S6zWyR5qjp2GkAgVUOccouOgMX2kMcGoMB7/r//sz//ssR7x kR71cR758R73
0R/70Tr+8Nd0jwCvBxhCEZ0QUuwqruzeUXgsURuzcSIlsiJNqRPJ5hfkAZ3+ QR5+oRjq7iE7
KRZtkRd3sSRRMhdNciVT8iRrUQcDUc1YAhgcqiaBQSSdagktcicpsid5km6m 8IZuZrOIEqlw
8qPKcLTqkA/zkCn30PWaEiqf8gz1sCqd0iqlEiup8iq5Miu7cisZZiBjMhhF g/uO0mwi0ifV
8ifXsi1VBiPPMi5ZgiRVsiVZsi7/8dIl9fIu99Iuzyv7xpJIzLLl5LKEqJEt EdMtFTMxRUXl
4hGx/uYcny0aC7M03i8g/zEfMXMzAbIzNdMzMzM0OfMzSXM7xBIYdW80zDLS tAcBXbEySyMt
GXMxaXM2bXMr4PKplkGXkI0ZRjB8mNEdYVM06LIv85IvkdMvj1M5jbM5k9NP YBI1NWUwMyJ2
WGIZ4MwfJIiCHNIz1HE4SUMna3M8b7M8yRM3Z6Ubz8rNtLA9u9MEhRM8WSIp v3IpvfI+wTI/
7VM/+xA/9/M/+5M/o1JApxJAB7RhTlPxynLYjJFB1Q3ZHInZIKkRm1E+60I2 z9M8NTRDzzM3
ncrYugdE/02Re+CJMizJQmGR3JLJOZnzOVl0OWH0RWXURVkSMKVTJkXDA2mH qSiuRy8OPlF0
NA6TQze0SImUQx1TKJ3q4UKB5mbOncrOOz0qSF3iMkFzNEXzSrW0NLG0S7c0 S7n0S71UIG9P
ALdPNVuikcJu7BjyHliTSu8LEEHmSI20Tum0LT30Q+duT+E031Q0Rmm0RQUV UAd1Rgs1UA8u
OhW0LqyzT2tGPO00Uu9UUoUvKBXKUd+RPv0zQA20QDn1Uw8UVD01VEl1VE1V KzsVVUVVVWsv
Qc90QTGVZjCUUie1VmnV5PLUqU5hBJlhV3c1VmekOBHVUAm1WIn1WIc1WQ91 av9sdFFjQkcb
LSG2QSFGEFiVEOSq0Va19Va3dfyS9FLP6hRQwi+YgWPi01xvxkrDdF3BtF3H 1F3FNF7Z9V3p
VV47zFWPC01d4hTgwhC0AAaoQBqmoVfj6Tsh5FxJA2HRhzJ5bpJYAmFntVu5 dWIlFsdy9aPE
9R+04A+q4Q+0ICEyNjiDRGF3RWHdcUrXESaEdVmNVVlblmWRFWZdNma3xhd5 YgdflVFf4hSm
FQYKYVqr4R+2ARViDAU1qWA7Q4R6J4TmiZMyisWirOM4ygt7jhmt9gQhtWIp dmu11mLTM9EO
q3a2oRCoYGMV4j0v7Z7s7DMyqWHvzAHx6W3VFoOadsr/XtPSHDYVGUJTCZRV T7U+VxVwS9Vv
CVdw/3ZTB9dwCxdxD7dvEwZfcYU6F6IQGxSREFGRYOEPqOAP3iJkJ1OTZOwB e0lK2XFtQfeS
whCjNil9FOMiXCwFJ/Nqg4khIpZrbbdrb5eG3KKrNPCjYqmWZkkdptVjpxVt W3d2x2fSPvd3
9qx1kRBvH4Nuqy0BW0I4WZe7jmRFZ3Z7ZbZ7X/Z7aTZ8k7NZc/ZZWcKcONIj CwEWCgEG/qEa
iFaIlvd2lrdtodduf2nKmjHj6lZt75Zhj9cEhzR3cbeACfifvrUKnSqWHkod ypYKYGFa+yB5
KU3nDPYEq1Z01/Fo8zdpp+2C/0dIzyKxM5aWdWcsk9QVXufVXut1hV1YhWG4 hWOYhWl4NSCX
B+ti936BqIxKs95iG4KWGkRBdq11eOT0iA04iQ9YiavqYptIHc4pduJBHYIW aP9hgvNWNAiJ
ZBkQhH9kixkEjDuI3mJiZcGXe8/Ye8VXjdF4jclMUcsXJho1JcypGYhRnfyg D0RBj/W4iCMQ
/L6PiZd4kAXZhSxVgX2XKDWrs/wYQvg2VRU3khl3cR13kiW5kjEZki15kzM5 cDlZk1GoTOXU
WWFCchv5R2q3kAl5lVV5ZJzYmHZ1GXp1lk95QczYjXG5jXWZjXk5jX0Zmsg3 X3P0JQxsWhOi
WmvZNP8GuJVZuZmZeWUS2LM8NyHA5z64OIulMYVleJtreIZfmJu/uZvB2ZvJ eaRuGNj0tSWw
U2hhQ2AJtjSuOXalMZWduZ6f2Z6ra3evS5r/AYptaSGmuS7iGXml8ZZ3+ZcP Opd7WaEReqET
BY6FWWf3NYjZOWjhF4M+I4Q2zgEbkGHbL2vx+Z5FOqQt5JD5WRVgwRAMYRsM ISGitBXxl0Lj
zaO775E9uZMT95NvGpR5eqd9OqdxunF7GqiHGg3POTUXlNgMCUkWCRFhI4gD us5yrnT5l20H
+u7oeaS1mqS3+ipeuYR+V5ZsaRtU4Q+2IGhfWnlnt6phWiQN2qHhuqHlmqH/ 6Tqh7Vo7bbaf
bpQsHQR9z8kj3/ep4zdvOW7nnLatH3KZuXqxu5qxjSKaz4qB0cmWFmERwAAM ghaLCXuDvzBt
VXFuszkeRUqcSTucTbucSxu1T3ucWTu1bc9irm6vBRNCdriojsGHqQGIt0GI kzk8j1jbHLux
hTu4heKrSQiKG3SKLTqwNbu3y/hP6zquo3uu75q6pfuuITpyaVsU7/gX8niP wdu5pxGQQW64
zZu4z3soTDqyFXmzxFtBbJqof1qo55uSi9q+6/uS71u/81un5fu/deuop/O9 0fK30fvA0zuk
jXtjZjmW35nAheStrXvCp7vCq9vCr3sWg1m79zWw/6VVGqIawh1EsRO8xBHc mSHbbG5OGkAc
AUVcNLTZtWV8tWdctW28tWk8x2+c6AQcR9OUneFiG/zC4lYsYb34i7svq0/c xJmcVhdcY8p1
itXhJqm1yEeDfhtZwjGcwi+8yzOcy7+c8LIbh1midpY7yP+hO0MXap/xREWY bUuCaSeRaTWY
ykC6yfF8ybl2vc0GFXZbFcr6H7ZAaAcbeYdppiu4sK16raNXb52RypJyGlJB 0il90i290jH9
0jU90zl90z2900H900U91El91E291FH91FU91Vl91V291WH91WU91ml91m29 1nH91nU913l9
132914H914U92Il92G9dlP8JUrspl9gSYoIpmqKj9HbcXKpjmto7msairNEr 1M6RWM/z/NsJ
mZV6d2z8fIqRhGwJnXnt19rXHYm6MHpX8XNPFN+8C8ztfcvx3cvvXd918RcJ Z4Lh4tmv+GHb
vaOqvbBNVH/pd96tLZC9/eHBnYl1Q0nJvRqy4RVegRAIgQfet9A527BPOM5H eNpAnoMDOOc6
2+MO5zZ8pdhd3thfPuZhfuZlvuZp/uZtPudxfud1vud5/ud9PuiB/taZw7jK pg90O7eDeBua
+6M2Gqu7XTv140OwLRVkIAdkAAeuPuu3Xuux3uu5/uu7fuzFvuzD/uzBPu3J Hu23fj8kCChd
GZr/7SZbIb7uJaQ+hELcCQcVlrvvPd6Y+Bfo6p0mDggfUqELcCAHEn/xEV/x HR8HGn/xFT/y
H5/yGV/yL//xJx/zN1/zIZ/zcYDSbfCb4kqC0ov0w2wuwpzfWX/1oaQttOSv /n2Pv7sPav/F
ZyS/JJ1DsA3rfX/rfz/4gX/4hb/4if/4jT/5kf/49QOclkd6UgT6XUX6YQW4 I97ui9v5dcKG
wBX38a0Mbc/0sK3xUYEZUOH8d78+YIEaPr/z2//9Iz/+Mx/+51/+3d/+6T8H 2gLA5UU+BDRS
AAKfP2r/8P0jKBDhwYIDCy5M6BBhQ4MSFVKbBpEiQ4sbI3bUmPHhRJEc/1ON rOgxJEqQJz+S
TNlSpcuVL1lylIkzps6bO2Hy/OkzqE2hNYvSPDozaU6gQ5saVdrTKdKlRKdG fSrQJEhqAwem
4vovrNixZMuaPYs2rdq1bNu6fQs3rty5dOuG9cqVGjWTebv2/es3MGCu01LJ yCEDVbWFBAmq
Ogjr8GEciCtPtlyZsuTMmC9v9oxZc+jOOUSnSjVNsOrBq1uzft2Vr+vZsGv7 k207N+3WuHfr
/u26GfDhvosTP248OfLlypszf+48OvTcf/IWmr67j5/t2rn7Ye09/He/qAP/ 87cw1UK77Nu7
fw8/vvz5agmqt78QPUH95/P73/9ffxfl0AUOXf+gsk1YzRjDTFjUJPhPNQYS OGGBXVB4oYUY
bqhhhxV+mCGIHIro4TSNCYgifyoGuCKALqbIookwvtjijDa2mBqLOtK44435 yVhjkD0KySOP
6hHpY5FJLolkk0M+qaSTUULJJJVSVjllllhueWWXB+mll4BgavnHd/8UYmWa LqJylh8ssmmW
myoC+aVfwqFHX5567slnn36iNZCJA92J3V97FVgaKgQZow6jxvzzWIKqlEap gZRdWhqimFpa
aaabetopp5sWuJ0fl3ZRaqWaNpNaodIF1purtsX6KnK0yurcV7XuimuvvP7q a7DADrvcXsbm
ZexXrxmyRSF+OPudrsL/cuVmnOCViu12gPX20D/qGfRnuOKOS265ZBn0rbcp dXvTQSiAxO5B
01QoSoLG/KIOOY9Wk+A21YwYYsAb/vPhPwAf7GHA1aJCYLWmClygjO1OvC7F 8Fos78UVb6yx
QShwLGPH8YqM8cQYjYxyyRyn7NF9K6tM8ssyx0wzyzXDbHPOOO88s84983zz z0LHDCY+wunV
DD5g5rydQW4GDfVDoviBSqlVT10xnGW5adHJCP2lq7lij0122XPhhTY1KKy9 tm0o0LaXp4r9
84sxjP4CKWSidjHWqX5najCn/2hK+N97G17tP9uJ1QeoorLqG9tvCxur5LWi ABtulk8Lq1+b
//OK+UCh50YosaZzjvrpqqfO+rCpHN1M7NTEfqtg1Q1EBTXLgLJ6c4mTNV5f 3PLnstnGH488
2fgt39/HTWKe5DQUjuEHhAs2GGFYsBQ4BoE5GFwg+Dl0z7334OPQvcHko+/9 +uSPP337FGot
lh/vu++9xDdC76WWc7r4NjXZ6GNFyhFBCPgPBPaPS3RyXgK5pCMH+k9dC6yg AC04wQxCUIMY
3KAHOwjCC4qwMXpR2phESIx/KGNIf8CDH6jwwheiQE4jTJEo2pQiOunFL4JK ng9/CMQ8DSov
gsrL6PzBtq4kcXKhSyKyUmEhHKAiFapQBSy+ogpqZBEWsLCUhQZnoP/BiTF8 YQmjWMJIRoLx
LSxrtNQZowhHHPzOD3GsIw4gB5vJea5tSOyjHpnIx7cB8oiaGwzbuCI5IwZy baJDJCOF5zkj
qm2SSHxkJduGuSZa0omHjE0kG5lJRw7yj48M5SE1SUo9Gqt3rWslK1/pylj2 7ivCOZpxdodL
UCgDPbyrTRXwQIUpUIEKMzTd78YSPE/2ZSTpCqIznwnNt2TFId9qCAIh8rGP JeRd0JucRy7C
PupBiCyL6WL3zvk99hksLGPAgfq+l870wZNg8lTfP+o5vnDCr53n/B3D0MnP feZTfzJhW0Gg
h49MEvBdoksoQhTqLpVgxJokeVdEEZpJbC7/RJAPPOBEQoZEh2SzmxsNqccS SFKPajOiJ5no
AUu6tpMKJJswFSlKX6pSm3pTI3ypClSYgpWrWAWoQ/UpVaTyU6MKNalIPWpQ icrUpyoVqk5F
2uyuWlR8LMMfXPWHQLrqj14KpYUyfJpUmzoQ+iGTJF4rCNjAEs24ynWuaZNW I5V4SlIqUjCH
spQfFsOVYjTkMYWoY9/49sXEghGxYhwLYt2JxjLa0UJ92JoXLxvH8rjtkoxU ZSg5K0i8buuT
ffljHxFZSUmCUm2JVKboOKnaSY7us6zNq2g7p8hSxpa2Cj3lbmuLSVUOEZbE laVxi4vc4/7G
WLU8lm9AAYpiQBcU/8SYRj96SZtfFtNXx6zfaPuCouLNdbzk9SHzXIYeB6q3 eYJUG3/aJqBp
dGEM861eWJbRj2WEpZzz7W/6/Mu38SGWvuvsrxi/B2B7Eni+37unfwVMvfpp DRUMpq+FK9xf
/QUpkyri3wMX2mEAKrCBKeIfh92ln7U9ML0fnpEBO9q8GLMYgTRl8YoY6a4R A0iCMKbxilu8
YxkDGUXwRc+RahhCDiJ5yUpu8geZ/GQnJznKYqIlc48FQd6BwkplonKQqgZm qok5hy76y53K
i+Y0ky1QeSkdJd98xNC++bQD2Qs/cVCdfxTDHu+wRzHyVog78/Oe6EPfPcdH 6DHcM9GLVv/0
oB0dz0THs9DnlGNY7JcDhwVU0OEsNB5bI2c/Bsa0qBXunHsjXNOSerWrnS0k Y3tXOMva1bGm
86lJG2tX61qStJYtrFVpV+Umd9jCLjaxicXco71OOMqizXUGogVqQPfY0OGW Qpqp5mxru0/o
oqZHrik5lC6UIuHWyEX8a99l2KMf9tDvYv5hiAsv+MKDs7BYCHzvAee73g5u bL0BbOFSXbhq
dJQ3wAFM0Byr2GMqVhtIECruiCq8a/BKZMQdetDaPjSmD0woxxESso5v9CFs I7dBwc1xg2o8
Im29pshXLjmTp/SgNIX5wtPjs6gBLec837nPh9ZzoP9c50IvOtH/j86Y2Akn 6bJjmh+cZvSg
I91kWyEPXLeN9azDp67BsnM+/7CYZSyjGGLPW1gCTelOCzqfa+d0pdue9rdT mu1zdzvdN+3p
Vg27dpzje+Sq7Zwj9srN1C68sQ9v+MTPai+wYvyymuWHMn3n2YgnzvBwThCt a37zczkvlHE0
Bgv/YfSkfxbpR6+K+YZe9RZefehbD3vWy/71s3e97WNP+9zfvvaxL4zSvGwl HQI/Sy/uUhKR
LHwn8XjKRh6+85n/+ehLWfrPpz70p+/kMhEETdivvv90+Jcecn785FfLcC/S 9VTwc75csDD6
2O9+C7d/vu8fw/zXb//4w5/+8td//vm//3/4d3/1N4D9B4D/NwbN1jp+RzmJ x4DEFmyKJ4GV
N4EVSIG/QXkReIGz0RvM5BDlB4IhGBbT1G1VFVWNIV+6h3u7p4K854ItCIMs KIMrSIMviBpZ
dVZG4VJTxYNNAVJUtVRVtYNoBYRF2DJBiIRGSIQ9mIM46IQnCIUmKIVJyIRP OIVK2IRRSIVL
yIVZuBRtpTRWhyciSIacx3WnY2cBeH9raIAIyIZq2IZv6IZxSIdwaIdzqIan 8WkNKEsP2HcW
eH6AuIGDKIiFSIiHyBvmQTzrUYaNmHWe132gF3qH8HqUOImViImXqIljYImc mImeuImdKIqf
OIqhSIqnaIqbWP8Yyfd5rBiJO1J81jckruh9VXJkr4iLtXh9uiiLubiLv9iL vOiLyFdmdnJ1
joiMasZmg3IaqNGMzdCMhaGH0fiM1DiNp1GDMZiNM/iC3KiN3biN4Sh71+iM 5CiNr2ON6Hga
5wiN61iN7miO71iO6jiP7ViP6WiP7IiP+wiP9KiP/ZiP8viP9wiQ/EiQBzmQ CSmQCxmPDemP
DPmQDhmQEmmQCkmRBYmRCAmRExmRHcmRH1mRGxmSF6mRJGmRHjmSKJmRJwmS KymSLmke1/aB
yUiT5VWC3lKKoKiTOcmTqLiTPtmTqfiTQhmUQ2mURYmUQKmURLmUR9mUScmU UemUUgn/lVNp
lVWJlU+plVS5lVfZlVnJlWHplWIJlmNplmWJll+plmS5lmfpk2D4VmNYk3MZ V3XljXcpjt+o
l3gJjn25l3nJl3/pl4FJmIBpmIN5mIKpmIWJmI25mInJmI/pmJFJmZBpmZN5 mZKpmZWJmZ25
mZnJmQmoiJhHl6UZTedFicKomsA4jK25msHImq/pmrFJm7Bpm7N5m7Kpm7WJ mxlEieDHQ8do
msOZPOc3DaGHiMlpiMupnM3JnM/pnNEJndMJGKHXgTIJLsSpncdDgjg5Blvo heBpheKphQeE
UELFUDcBceNZhBY1VO5ZniKVnlUYn0t4TeR5hfSZn13InvqJ/5//iYX9yZ/1 GZ4BSqACWqD+
aaA4EXpwKYbbCaFmY5djoHGvJXiwdKHQYWrF4URKpBobWhuo1FmiJisZamuz kWqWNGesAaIm
2qGshVepdqLEAaLUaaPSiaM3qqOtM1+XxzwRCqTmgppjEEDuZWK9KSANt5sB 4mNR4mFaAmL/
0V7Op0D58aT7E2Q2pmJEUqRJWqU41VFd2qRJikFdyptLiqRnqqa5uaZpyqZv 2pu/WYxtJpxB
aqd9soyzM1+lRWcpykS+hkqs9qKCcaF/elqdFFqtJUidBFyr0Wt+hKilxEcV ilqV6qGLOkil
tkcKFaMWKkqclVu51aKwFqqXRKghuv+iuIapnmqqk8qoJpqjsbqjsyqrtdoc 1hmT3padd8qr
e3KTqZCaOOWe8OljKWdRKzVSYCoyK/VQwvpwrCVxDpdRF9Ws64KsEcFNzTqs 5IZxz0pzp+RQ
23pRzBqmMjVy18qt1Jpx4moRxMou27qeNqUx8BVzG7We2Zpx6ypT06oQ5Dp1 UTd0UiewAUuw
AGuw/4qwA3uwCpuwBduwC4sQDVp1eRE2vWqxQrRKdkahfeqhospbvzVbNUqq oiZnlrNqiXqp
HXuqtRZqLXuphaqymppKI/oXTXRXifSoqmayMVtrqapqjoqqjzpnLbuzlLSo NWurSUurS6u0
TasaPTqaP3r/sVMLH0MKY0i0Hx7GY2NarER2pe8lpVjbXkU6pVh7Hhx2pGRb I2Mqtilmtm9r
YhKktlZqpFkLQDd2ti+1XmybtiGWt2TqH8vXt0zaIzX2Y2DatihGt2GaYmwL p2gKuW0auY8r
uZVLuXAqp2ISnHJJtZ1bF8YZejJqqbP2W6zGp6mKurT2s5aKsppaqYKXsxx7 sqrKs60ruyv7
p7vGsinruraWoTDbu0jbsbrra7s7u4bqWSPrtMvLtM3LvIiIq8uEnZ5LvXXR ncBKpBZnUA+X
cgzBrIfUYzenTRNRciMxvsgKriwlrQ7XUOI2c9sEX9vUrfx6ceXbr/nKrd2k v9p0/57OalKb
03Dpy74q574aITkLFb/2yr8rYb/DGr8NHL/tG1OXxFILDL7dCqAKqsEDup8J ysEZ/MELCsIe
TMIIasIHisIdPBUS+xBxWb0vHBcTalywilyGyjo0/LzNIbLEtcM57MPOC8Q/ zKOiCV6LmHkw
jMRrYbVtaqaPa1Bvy6Zfe7luCqVTLGRUPLlYbLlabMVbnMVffH2Zqx9mVqdJ bMZjkafNsKdB
zMZC3MZv7MZxDMdzjBzR2xXdgm1nrMdi8au/6Yyr+MeBDMiDLMiFTMiHbMiJ jMiLrMiNzMiP
7MiRDMmTLMmVTMmXbMmZjMmbrMmdzMmf7MmhDMqjLMqlTP/Kp2zKqYzKq6zK rczKoMzCX/Og
e0zL55Gx6qdocNFdtczLvezLv7w1YsO5aQG1RUyawIzES+wQ6MHMy9wfqXBD /dHMBtHM6EHN
0uzM04zN1rzN2dwf16zN1ezN3CzO4PzN3WzO5IzN6TzO7czO74zO8VzO8rzO 9BzO9TzP+YzP
+3zP/XzO+uzP6hzQ7mzP/8zPBj3Q8AzQCM3QAt3QBL3QDi3REH3QE63QFU3R CV3QFr3RGf3Q
F63REZ3N02BWIg3SH33O2+Av/lINLd3SsdDSByHGdUJEZYzMVAu6ufwbzcA1 dOzTcgzUPy3U
Qe2cqSAnsRQWK80vLl0NMA3TB2H/x1zhgRrhxVXdxVfNxVpyvcGqVKkAJyes wik8wmA91mIt
wme9wSVs1mlN1mgdwmy91m8t12od1nVd1nVN0ihi11CFHoux1Cy91E0N1WPg oBSbF25xxDet
Zo9xIo0NF4btFaFny75h1Acx1JdN1Jit2ZnN2cRV2ZbdSvvFL9Tg0rDQ1NVg 2gdRzHdsxP+g
0oEdCyzt1OR02jD90i5t26d927ut272d27+N28F9204d3MTN28B93MLt28W9 3Ma93MkN3c9d
280t3chd3cpt3bZtdv1xF2Lh10zt22KhzFri1d1tnjjWZE3sXoqb1WCM1e7d 3lYd3+8t3/Bt
3/UtJXnd/8zApZp/zS9aANgxrQozvUN0ih5KHeBMDQsL8d3g7eAP7uCmHeEP LuHgXeHZrdwQ
ruGlTeHY7eG8veETLuLgjeEgHuIK3uEjDiknYm6iHSEJftoLXtODMl8O4ht5 Lbyo+yo9vNk9
3tk/7uNBvoGffbozCiyi7dJU8AdaMN3/AAtRzR836ddKDXay7deu7d8InuVb ruVdzuVf3tKA
LeYuPeZebuZfruVhTuZrruZn7uZo7t9qLueBDedvbuexAG/cred9nT3/PeZ+ 3ceKZhA1U97d
8r0MR2MLV3IZ1Vv8G1P7+60u57AMS+mTbukQi+kPq+mVnumcvumX/umdDuqe Tv/qo+6w+k1y
1epxDgzp87u+EYcesf3fS77kuA0psexWDxrmpF0Nf6DkMG3aC/4Y/FLhxc7h LW3syH7sqL3s
yc7syg7tzy7tzk7tzb7sTM3r027t0V7t3L7t2u7t4Q7u417tK84Y5x4h2a7k TE7cwj6hk50b
lZ3jJErvQ2uzq0vvLgvk+y7k/c7v/246RK6yNkxbt1tqNnvYEdLS614NDJ/a 20PErE2a/k3r
vN3nW97mdG7ndc7xG1/mGt/xS/0PqzDyJb8KHh/nGB/yKO/lGf/xLL8YhqAW U84vW1Drt53u
6mIfqXkl0GzeV9voi3rFaju4dZu3czvfSX/f9M30So//302/9E4P9UmW19fM 3+kVbkVW9GXr
YQYB01rwB1uw0jbP5Isx4IQ9p8uo8C3t638A7DGeNxf+4dcd3SVO93dv93nP 1MQd27Gg93U/
93+P94FP+NGd5wHi3Q7u8KgNKTlt46TT079m5JhU5C6L7/ru75kP8Juv+Z2v G5U9arlmSJbP
u7a2X18/3VRw2k4O5VP9D7Je8dP91AvO1H8O8nNu+7nP5rfP+7qP+7vv+4tB 8odg8sFv/MCP
/L+v/L2f/Myv/Hgu82kB/GTv0hGy1YoGhIUuEeiKUdsPY66envgarvmr6ndt /m5N1+cP13u9
/uo/123d/ugP/+8f1+kv//U///8Pgeqq3k0Upa3kDxD/8KGghgKfv4L4/lH7 5+9frGoRq22L
CNHiP1VjxkxTyBAfNYQIU4H8JxHWHy1/YFWDuBIWxn8uWVZb2XJmTZo3ddrk mbMnTqA7fQ4N
+lNo0Zwsqa2aucroU6JHpUJFWnVqVKo6MTL8t7Ch15JBU1KZqQqjSJDUUmls mDakW7ip/Cx8
i8Iuirp2Qd4NyRfvXn93CSK0G5iwXsOA4b5lvNhxY8iPJUemPNlyZcyXNWfm vNlzZ9CfRYcm
Pdp0adSnVadmvdp1a9ivZZOW29XtX8J7CxdEzHuwb7y4fXONBVVVtZhdxqRi /JVhKq8QJ1ZD
+afiNv+IJUtOj0ixu0Tv3MWHJw/e/Hf00ymuV9++fPr3483/W0Xf/ir2+d2f lw+ff3n9Auxv
wPgKnM+QrhJUsKtY8tsCJexmiuk5r1I5ZAznMnSIoQ3/SQWVrjoU0asROSTx RA4J0hDFFU10
sUUYS4yRRRlrpPHGF23MEccZd/SxRyB1DJJHIYsk8sgfjUwSySGXdLJJKJWM kkkpq6Tyyiet
zBLLKbd0cpq5HNKyywwtkqhBM2PB6MJpXISrGZJmqqg6M80yC6c0Z8pzTz37 5PNPPwMFdFBB
BS3u0EMLJXRRRRtl9FFHJTQLrK8SLG6msfp8SRWE2kSoGeVs6wxMumZbTLj/ 2FI1VVVWV3W1
VVhflTVWWme1tVZcb9U1V9hqK5VXuBI8TiabYNkmJo2Yc8srhaBTSDo5/0BT wpfO7LOiayOF
dNtCsTXTW23DzRNcaMcV91xz00WXpX8QXHBB6bzTIkIzS2pWIA8v9HCaVPj1 t1+A/wXxX4ID
NrhghA9WOGGGF3a4YYgfljhiiie2uGKML9Y4Y4439rhjkD8WOWSSRza5ZJRP Vjlllld2GeW5
Xv7YH+TefbcafzTiiNm4SLoUKVVi2TQmrIq2Kiukjb7qaKWTZvrppaN2Wuqm iVJTFa4qBUvo
oy61Ey2RNPJjbD/6IPtss88eO2212UZb7bXhLltu/7fJrjtuuO+eO2+6++b7 77b9Dhzwtwm3
W/DCB1c8ccYPNxzvxR2PHPLGKZe88r0nzxxzvTtH/HLQLRd989BJH93zx01X HXXNWef889Nh
X11210uvPfbUb589d78XgkUVVQwRPvjhDcH6H+WUDSlD6BjCllx2tXvI2ufl tL5c6q/PHnvo
u9e+eu6/Fx/7bwMFf3v0z/deXfXHT19OmGxOUCLtLyqJwuf0lX9/Svn3/38A BlCAAyRgAQ14
QAQmUIELZGADHfhACEZQghOkYAUteEEMZlB+CgkgPtjkprd4Kmv+q8YINXhC FKZQhZNakEO6
8hIAlvBTaZmGRnZ1Q2DlEP+HO9RhD3n4Qx8GEYhDFGIRiXjExszPJDmpSYKS xRiE4MtZMYkF
8AwRC+NdMYtq8go1flcNVfxOjMcJYxm/aMYygnGMZ1wjGduoRjTCcYxyTCMa 2RhHO7oRj2/M
Ix3vOMc+BpKPg9xjIQE5yJcICRZYxGLwGqnFBgnEH1O0EIYKyEEVZlKTm+Rk Jz35SVCGUpSj
JGUp/+cQ5EynJOxhFzV01hGB9MyIs0RiLWkZq5GEzZIEdKEpfflLYAZTmMMk ZjGNqUkTonCJ
EQlKcpbTnA41j0xjoiaXqumlaVpTm9i8ZjZ/JM1K2owa8CiGMYrBDBMm85jr ZGc73flOeMZT
nsL/dJ6A4KeKDzrnTangJ7/42Qx+AuyfAfVnKgDaz4AeVKAGJWhCGzpQhEJ0 oQotKEUdGlGG
YtSiEq3oQzM6UY9u9KMd1WhITVpSlII0pSRVaUtZ+tK0gGqXCWrGL4wRj2bE oxjFaIaCejlP
oAZVqEMlalGNqkB1apB+9UMOLJ64LI8wS6pRpSq+qgpLrE7VqlvN6lW12lWu flWsXiVrWMsK
VrSO1axrTetZ1dpWtr5Vrl4Np4KoYQx4/EMd8VCHXo2RNUwO0C4ZRMGCBtuV wh4VsYhN7D8a
y7/H7i+yAZxsYScrWQpeVn6axawmOYvBz04wtJ8cLWkdu87DDtMhDWoP/3qu 9kqe3dKWs5Vt
bU21lpn+wxi/iEc8dPsPvto0QT917F06S1gFNdayDuRsaS2YWOWe9n+WFYzN nGvYdy2XstK1
LgAv21zsRnex2bWucacrwMhql7vUNW51DTvY1LI3vuM1r2jty1zuQtZ/ob1u d/O7Wfdq8LsJ
TCZ0UyvBZUbFmcojSTcdvE1vRvjB3ITwhCVc4QrpL0G/WMdeu4IPvq7jFwky oXjJK+DkYreB
/U0hdFW83/+emICVjTFmwXtAzR74tCYe8Iu3++MEqTe66Q3yiefb4/HWeMXB vO5ndfzeBLoY
xqFkMZCrDECF7Mc70lnTRkD4GH++9KIuHbOYOf9aZjSfWc0jTTOb1yxSOJ+U zG+Ws5ndfOc4
r7TNeZZMDXP7C2CQY8T/EDQ5gDForSVZuYc1b6Ol2+j6QnrRB27vo58sacYy WtMuDnB9M73Y
5RqY058u8qe1G+lS05i+qy7uqKX86k2Lt9Kg3jSoLS1l/7J6vaR273djzetf t1rXQ36xqk8d
YwOrONJPZrWoM93cWu94184WNqmzC99bP9vaMt5srqnd6Sknl9H5be+kbV3t Ivea2QAsMZHR
7ekUP5rUS+UTsp7plihiVS3TMCbAqHHVfDMr4B4ZuCQBfnCuFvwgCMeqwh3O cIFDnOASN3jC
Kb5wiwuEX/7AeLM03JX/X6iDHBwkh8jVgejA7nrapd4xroVM7nSzfOUmhvm5 pU3elyOZuoxV
dHGTHO+ZpzrVqG62zXd+c3kTu+g957HP/6tebhP72EZHdsypTvXHSv3Wou7x sQXj8ngrvcav
XvnPZT5ksENd7LmWttihzna4Wz3rLOdvddGubKyD3epIX7LQr453pK9WP9Z6 7Ub03Ri12Iy4
IVJ849+1+EQP1/ELCui/bXt52s5mJHFhi4J2qxAPh1y4jBd3fO0e5NM/O+el x/bPpR7gmiNd
7ZW++3tnrXLZq3rmsNe1f0Mt+/XOveW3JzvT6a7y1LNd61xffbHL3urW8335 Zkd78X/vfEXb
/533tg518n2N+tvffPblPm7bva9kmced7k03O7ef7/fmQ3/uay9ggddfbnhz f/iJTXAzYZE8
aCIRfICOeOoXhqAwBLywBLQwBsQwE2GOaPq4f3CGEeswdQC9X+gp2wC8p0s/ mns/d4u964u6
vXs5/cs+oOs54xM3oNO6znIy/Ys/E3w7WVNB4MO6vSPBGKS+HFzBGzw+4Ws7 eWtBIztBIoy9
9gsvITzC8upAuUNC1FM+vns/9UtBH/M59is/KhxCGew2+lsgXHNCG1tCr9Cy 5+myNtGnt0i8
BNmCG+CCG4jDFpo8n6JDyXs8OyQ9BWmGacA8P8w81ti8TwmVBampkP8zhpPL wDo8QrcrQUcM
QhM0PpqDxOdzQSRsRB88OyBEPr9jwhq8OrLDRL37wS68Mdc7PlB0PkwEviDE vRA0tijUPRp0
RG/zQRikv7WbRCksxXDrtk1MMfbLMVUsQlZERRw0Rs6yv1fEPeyLLHojvKZ6 quWhKn5LkBv4
h2PZBi5gJ375t7hyK3D8RnGEK3Kcq3E0R7jyA1HwA1Qgm3YUBa9iR3dUR3bE qjT0uNzqimYQ
sV/gMA1MkJQTPkcDP9cbN/qKNugjQmorPV4bOm3LuUszSHKTyPxLO2tzuV47 xewbxfmqtoyM
woR0uoHcOiUbSRv0SE9TN72LNlmbxY2Er4r/jL7oO8Wvu8h1c8VguzZzE8Nv Q0idFD+K5Lny
grZPHD7wG8Ur9Ehi/DaGBMYczELvkj+bNMVJE7zW4o7C2xmPiIsO+QcuUI9r RBPs2IaseZEN
7EoWOUtKMcu0bMsHtDxAjMtcmQub8YPIoMt3sUtZUovO4yXFeqcrQz8rRCD+ SkoVCsxMQkwG
asW/BCrFPCb7y6D+04r/u7fliaYFuYGxjIVt3IIYcEM35CR5VJB2BBGbSYWP UEDVbMAFdMCv
wMsFQQUZocfSlEd4ZJ4My0d2a0x3urLSesz0cz/g9K6aNExTGk7CDE7KKs4C +jrkJM7tMyDn
1Mn8S07erMLpYs79/8kye+IyfPIyNaQhF7mB4likayzLDFFL9ETLgmDP9HRL uozPrpiL9fQQ
uPxD/DQVuSGbu5QfvXwLOOmUvhwgyLtOAz1QBE1QBV1Q/0kqyaSfenMqywSJ gCPAr3hDDOUC
yCOu6nSIL4w8PZzPBBmbEd1Q+5y4jGu4i3u4FI24FkVRFX3RiotRGnXRGoVR GxU42CTNhqOk
C2HRG53RHMVRIhXSIu24ITVSJUXSIwXSJGXSJXXSJl1RKpVRKL1SKY3SKg1S LN3SJ83SLrVS
MB1TL51SMS1TLT1TNeVSMl3TL0XTMGVTOG1TOXXTIrVKVvIWjICtrXwL1Owi rbqB0ISlA/88
LYYorKoqCI9QkUIlVK1q1H/og7ws1EQ90fy8VGqogimggk2lAk5Fgf/UT/9s jFziS908JQZN
VVVdVVZtVXdyUAyaTJtYsACkEBP9hy3AVa+MAezqpeXyUGHrvsIgNROFTdm0 Q9RsTWVdTdes
kT/AAz+ggmgF1Wb1ih1NEFR4EXCSwACCVVf9VnANV3Ed13aqp/24p3zakDdZ Ehi4ARigERXZ
kOBIkfZciHnFC3sNDHqNEdgMkyMRRLkM2LeoAjz41FBtlWudz8YQIZmyGXww ht2C2JQrUHKt
WIu9WIwFV2+1oGcEF3tjsA65FzH5hwx9w14aWV/9CmAtrJX9it//W9nqGlnG 8wdRyEutQVnJ
27xzDMdy5Fl0/FmfvapnpdagPceE/QdUyCofzUd8OMR7UIeTC6yUy1iqrVqr vVqs3R887Y+s
PLy0GIku+kqKIFlApVR7pVSCYNS0PcC1VVtFLduyxcuyGVG4NdvnuE+BDdgq OFhXCR1S/doB
XQjeAq6bAq5fwCSKhazn7EWnE0zHFErHTUL3A7Ie1K/7ikrB2qTFbc4WYzJh erthuskGlU4F
4j9mWqJZrUyQxc2RvcZtoAgNXY/XRQ6ZxVfDOK2WNcJfxV2Vpdt/EAWHoMtj PdneZbxkZdZl
ZU3kXV4h2dbcQsQLBC6BgFpjIDHbM0XQ/1JI/PJFzc1EG4tO38Q59EK/38RO IoNK5YzOydXC
SJQv+frJIwO3bMusy13MyHXcwrTO0dLO7F3f5ypd7jxX70zXhYCLNDxA8oyQ a2xXGNiCdrXb
uyhUwTjUtn3btzUuu10IsilUsqlbDwZYTA3hIwpQavCzBQEGRKze6VWH3bpD YzTO+g1BMPSl
MLxf0IVhy3XK7cLeGQMwJTzJ4GSxJvthKvxAS6tcEaRfYBpiyXIyxaxh7ExM AiPdKOuKpCiU
j4WiqIKODiHPWLgFzjQRhRiRMT6RMhbjFTnjr1Bjh2BjfCHjNGYeb4zTN7XT NK1TPK7jPDbT
PZakpV2QXFgHcv8gh64ouXFYh1wASOxDSabsSdNbSNijvW0DNq6jZFp7ZNvb QaVcyOC7PqIb
QkZstnGbOlir5IOEyEaeX+zlSEqGYkZ2ZG1TSlfkySIcNWVzt2UTRi7MyZ/c 5LLDtEkmyFML
tuqU3PQdOlPG314ev8Z1NE7ev2DGMVFOZiCEScSyyvTQkz01vNj62gNECDeM QziMorQoFXMu
Z3QmZ3X+ZnY+53V253ZO53iOon4SYXv+oVLFrQUBNA/Tq5ADBmBwYRVcxaNr RErURd1NQYPu
rvhTyGSbNlduuhlE5mBctdqbaFG0wfYVSSLWQSG0SJv7RVIEwZgbZl4WOk77 yJpbxbD/O8ax
c2hJ1N7yG8GGjuKSBOVZVlzia9yiu2hN/FABKjGLpkUdDkUrPt3TTV0AXBbM LOORdeo17t02
luo37l2onmqcveqqfmqq1uqrTkPlDetqTd6xhhHnXRBEBD3Qo17rZb2jFDLv O7+sO79N1M6D
fkpJpjXq3Gijk8WS3j5XRmkyhOuWrslPlGiRruRVLumtq+lK7GSZTGJPVkWD dDUZ4zHtq87f
c19mBEmpnL+QNuzF5mygVs7BXD9kZNwvNOq+TsktrOLNputmBDVzHbwBBk91 BVB5hmfe3m3f
fuffnmfh7m3gJmd+wtt7Tm5XYVhCBMhETmGFiIdckAeBBuVl/2TCTLzumJZC l7bERbPCLKRB
SjRC37PczX7sGrxuVkZsl/bo86Zlv2ZpktZk7Ya/KeRED4Sx935hKJNhrztt ZgPtZcxfLQRv
vmbfymXtHyTiGw5qJRxBIB7oc+vYPsliqJIi5i1rsfa3ou3Znf1wDw9xoAXx Eb8XfHyXpmVh
vopaBQnITtxo9pY+og46jbTFWY5EyU5t3btx/MZpjX5x/LblG1zvxH7tGs/p IR/Gv2vo8aZl
DpxJ75VvVJRyHZ7CXNREEuTFHObeIs5pXRZp+yboKlc7/g43kLZuLgQ1bB6P i8gIbu5Tb1bu
HKq8vJVzWcnnwO0KedgtXEBh6l5ELP83SUEPSkY+SpmOSaY8yIeE6Moi9IYM ZpAmukmrbE90
9I6UtDAk5kQnyRyTyJPEdLeW5SMW9WTTbtGOSML2b6l8t5vEbGpuSlEfaJZs dWzb9Ifu5aEE
8lxGysE0yaUb9PN9yjJv60pP5kifcKRWMNWtVQ/RcGcn6yWRmZaZdmmv9o7J TQPa2KztO849
L/vd8vu9oM39X8867W0/oXEH1wC27YhAwy/rlDqPdzufd8kgYRMuoMQ99+3t YW+fYXBP973e
8SXuXmPeL/5Fr4PPrIRvzoOfTm5vTG2noCuOUGmk0C2+Yz3OeD7WeIzfeI/v eJCn448X+ZCn
0y/940vSd5X/X3mWb/nGXPPw0GY318pY8lN5v3l6z3m1ANwxwHmf13mg/3mh D3qiH3qj/8Oj
vmL/W+rLrJBnz3Boh3qpF+uo76azrj+Xz3qt33qup6dVEuB2/06wLmDdxhVU wfmzT4y+KHp6
Z+5T9Z9873q5n3u6v9qInyAKrxcJXd2L74jB6nBmUZGBSAhzRFQSLywRpyqD EPzAV/zEJ3HA
j3zIn/zHN/F80c27KqdyMqGprXvP/3zQD324f4gCaXM+rfk4143XwI20t5Xf gI20R5XWZ/t4
x/N8bIZi4K3e6sd/BFHR/33gD/6/vHsES/aln9CRxR9DxdcJzhDj0teGSFu9 uNfn/xc2E2FZ
vvAKwZBXvRC2Dnn+eFUR8K9XDI5Z8R8sqp/6p7ewqycxvNIrviJc9IwggIcg 0TXtKttfz4JB
Jcbcbxd+gPgncCDBggYPIkyocCHDhg4fQowocSLFihFRWPyHAt+/ats8gvxY LVa1av9UHRoz
jdo/f/+oUfMXk9pKmShiorA586ZMfzlx+uyZ82fQoUKDAt1JjedMnTqZ3mTa s6nRpEerXs1K
lGjTrlO/eg0LdqzYsmTPmk2Ldq1aas1mThszpqC6X+ri/TP2L168X3oFusx4 ECNGhIUVokh8
2OJigYcbG1z8WCLkyBcHVn6YmeBmypYddr4seDTp0qZPo/9OrXo169YUWXpm LLAarJIjb5Mk
+Q+W3FRfZf7jmCq4z+A3NQLHyBLfceZL8dl0bvx586iKNybXiH25RuKEXyLH yHG5T8UshwbX
npj6ecXSnW+83hw8dO7k7RPHXz/9ff75/e833n8CBkgfcAQeaKB+CfaH4IIL DidcSgX9Eo86
6giEzzp3/TIQR6h9N1hoocXGmWYmOlZiQiQWxGJDJLr44mcykhajazfimKOO O/LYo48U2TiY
S7GIBJJtuZ0k1zQEdpUKTvItpdRRQG2FVFFWYtUVVFxBFeVTXlUZJU9VGkWm Vmyh2Vaaa6rZ
JptvpuWkTKnIVVAuxpDT4T95kmP/jJ4tRZZYdymqF2hhhAk646CYiXioYo49 CqmjkgmKaKLq
UWrpY5diFmmkhU6aYqigSiopZJ5yWuigqCLa6aSjonhoqZg2aqqtP+Kaq667 8trrjrAxuuqs
181oqXaE2lZbSbWRVNtuXYzhW1OAsjTcUi6d151LGGGb00tDseTTtd+K6+21 x4kLKLfkgqdc
d+t+Fy6749JrLrjgthRVt+Xuqy142FIbMMAD/1uwvAcLbHDCCBPMsMINLxwx xBODZ+0/qUxI
kF3kfEiOOh7/CSyhI4dY7LsrohisYYuW3PKiKrs8GcyMykwyyy831mqLN09W M88mx0xo0KKu
LGzPKlt2//TIvjLdtNNPQ820rCcTvXTVUxPGUkhb32YSSiod3NVbVoop5U7r 2aRY2leGad5U
1knlpZdqP6kl3WRfd+VSal+XlNtywxm4m4MLXjjhNM3UDLR0/cLRXf8AU9df gKZ8NWeVEluy
opvbqjTVn8/suWShE0v6o6PTmunQn6MOuqnfySfsu5nTvDLsmMacKO1Vvxy1 778DH7zwCol8
Muy7926z0bPZ1jVuJvEW7Vf0XQwg9fpdbz3222vfPYHZf899+N6DX7745pN/ vvrpsz++++i/
f36EF2c8UDMdXqiO47804+HOJk5tc5r7X9FStrrVha52S6vZABNYuQMqkHU3 c/9g5VyHtd55
bme3yxnSfsa7IA0vhCIcIQlds0EMdlB5svIWkWxTpG0gSRVKYtJU5HQ4w+Hw hjrMIQ936MMe
ArFJM6HTXApyP7sYoy78I0hgUugzA4Kudcnj4Ac96DorumxmVaSg5iBYRdFB 8VS1U9oKI9hA
LYIxjGasYAnb6MY3wpEhxZtgGskotEElK4/Ngh60pNWTgFmMYg4bpMQeZkhC CrKQiDykIhuZ
yEcyEpKLnKQjI2lJQloMY0U04jp+4cl4OKMgc/xUpgwltACSslGvwuKsjsXF W3WKjqmilapI
lbrL6S5EnurgLk25Kt3dUVUym+UEhfkpXGoKllaLIzP/m+nMNzIwl5dCpewI w5GtfUQkJPFa
SlZCra7U5IfiDCI5x2nOcqLznGUZG03qJJEmPjOe8mQNFedpz3vic1dz1BFt jvQ83UTPjzFJ
UIQYNCAFAcigBWoQQh2U0Ac9NKIOnWhDK8rQix4UowvNKEc36lGFghSiFNUo SOenyYl8KJ8q
XSloCMjSl8I0piEc0gubF8MZ0keI6dypOnnq054Clac2JOJE4CnToyI1qUpd akz3maM8Lus2
zoJFH6cHsEBespKUlKRWu8rVr2YVrFsNK1nHatauZnJCYvVqWdl61rXCta1x fatc60rXu7o1
r3PVq135ite9Aravgf2rYAtL/9jD+jWxgw0YNo20zZN0M2xTYedPKxvUy1o2 s5gNSzgVt0mI
GJWpoh0taUtr2qY5FUfNc15uoNeb6XFnfuuLX/vgZ9vZ3ra2uN2tbntL29/m Fri8fZ9J6weR
lJ42ucpdLnObO9N/tLAkL7ypSmg4xM1qNrvY3a52gzhUdxYEH8Uohl+KUbzQ Oje96l0ve5Wa
2htBtZ97fJb0pnVVwyoWv4vdr377i1j+YrJixs2QXe6SxMYR5L3tXTCDG+xg 9V4zm1x77Ne8
iS1wcjfD3dUwhzecJnbG5bPBqdBejIGXvqQUvTcCIfBYnLwVl4aYZ5RNLBnS GRdXBMdsnCKI
DKPjwf88mKkKbk0/S9La1u7mtU0haEdDKlGLNlmkUP6olEla5Sg/2cpZxvJI uTxlJ3eZygkt
roiTqL+9BOdCk0OujnRcuoz8eMcoWyaMfwnCzcw4xxJEDJ8hEjsVsRjPGjRN ZZ64xYXE+TSJ
DvJoYHUamrrQpiNJUnVzWsMOY9rDmd60Zr8rYr+o4y/4SKIxgDEQFZtQz4SO sZ9TWGflnch2
inZ1AYGsItHQ2cZzjmCjbY1oXPNq0YyGiFMNXZr4Mquf9BWoS+77X//m99nS jja1AUzttIo4
F+oYB4b+wW2P5WIgo6yUnQddS1ZtMZU7ZtUqh8UpXU5TmulO1elISW97hyr/ 3oWmIr6Ddbox
FtNVWdylsWD1ZleV290MpFm/fXnMYQmcjf8WVcORqfDZAXPi7PbxqOoNy40r 3NHD3hG9W/lw
f5/yOI3VZkkgC7ZvTpbTMtc0zWcuzs4ujiDAsAte/lEXJZ7apcAUkc1ad7t0 uzRpa8wgpIqu
xjTCOouwttyehe70YC786Cg8NNEg+EQpRtFkX3SiFpUedbFL0GdgXDsrDW30 arZ96bweuWtG
Gas1fqaMBGGtPwGq5D/G1rfBHfxwCS/4wiP+8IoX7uIND1wyFySJjnMcqf13 ubLbEneu9CC8
T05n5Hm9WJnL+tUOnnXT+1vjFPd8NOv9cNLrfeJ7/6Zd7mRf8Fh5vOkPlB3G Z7lwi/+exwrs
GepXT+6xs32Zb79g8nuPQLrzqPWYY73xMAVp6bqQukuy9HVr7n2bfz/8cRoi eAUij3BHzhgc
WUcu5BH0QAUcivC3YwB3/crmYz6W9M816X09NL3PGdgJmtMB4P0BHNN9HQDB zKYgjS7NHQGp
Hd7FH87w3owhoNw1nxg5EACGnhpB343YHQXK2QH2DrJJFR/V1x85W7VBm7W5 YAvC4LS9YLUI
mIiN2IXEw4EhV7FN4NnJnQ9qoAGOHQQ2ICtNXf+JYNrdkbENUB2dndR5oBJ2 4NZx3dvJX9WV
3fJloQC9khBK4Q8K39VxYP/cDWGufWBqNKEEEuGicMQ2SRjLcdPLXdhUhJP4 2SH44eH3gVj5
DYQ8lBol+AWbGVUvtdICyRvEGSITblwdxdsDHaIwNaDvDVzJpZwDJlzSlE7F 1R/t0VomLuLs
6dupHN/oOVo9vZnnudLJZaIK+dgC6puhdNwPjuLQvRi6wd0p0mIsnpIZnqFF 2N2fVRzaRQrf
HZlrpeBABZ6YhRmYfdmVKWMzbtkzatkyOiMzTiM0UmM0WmOTQZ5EsFkvRo2w /do4jhDYoaH9
1Zo4No06gmP03cj1GYlHaJ91zUke2uMd4uOmeVpRtePvsCM6+poImeM5ck5A /mOvHGQ/okbx
uJj/fLjICUbVfFHVMTZbxcQgC8rgRc4gRnLkYmHbRAyZQorkSJJkSb5GR7yh Y7VchUlW4tzj
S+ZjTG4Xzo0BTNqkTOLkTepkTvLkTvpkTwJlW8zGNhGjMTIb9chW4yUe4zGl 4znlUj6lUkpl
U0JlN0bEN5pkVmrlVnIloERXPMLQpMlQpS2HTv3kWQZlWnYfNRDVO3XlW8Jl XOJTSK6GCUpk
VdmXRWbkXnakRvolX24kV32kQVADMxSDMRQDPBQPXcplYzrmY4pWG2KfhHWN y1nYS2CYWmom
WvrkHtrg/RRDPDRDDhZD/7wfZKJmaqomrzBmahQlkgXUbyTjNkqjl13j/23a Zm7W5m7SZm9W
429qI3Auo1UKBDWYmM9ZiM8ZA7Bg5as1U0P2SEICSa9xDjtmBjHR2GpqJ47A 43SJJU6V5aVt
5nhyZj7uI0H4CV/kxV5IzmmSHGOgIrDBWavx4mpgDXbGWtKl40QM4ANm5xUq YH0K6HtuJ1KF
YHyOBkTKl7JN5FGuYGD+ZV8CZoRCKF8O5kD8wob0HD5YSCeJm4/gmDoKm40Y W6rln3zS54AW
pNXkGX8GJECSY7AVqGmVaEZoTUrCoWW2pExQVnn6KHmKH01SCDDkiUDwyc65 Z6l0nrk1HMGl
XgI6HMgZ0+gY3CFOYs5M36Zg6SuCipYSHe55Kf/JTF/14aIkihwkKpMo1l6Y WtyU9t7qJdzB
4dLFSVOYlumtIOiMzhND8huX5l3KDaU/GdltJBlFIuVURiVVIipUMuqiOqqi QurgEec/bEzH
fExdWF4k8h81aaETjqASlmGNZdDRQF0xQWECMp+roY6nGt0Yut2JHtqrXh0W ZuDP1KrVUd0U
TqGeKtWqqiHKfU53Zt93kmVwmCWQ/miy1tx5DoSfOA5e2IVfJOk0RWLLjN4G 2hl27tvxgeoV
aSnmYOurWKHzyd/urJCcRh0p3tsWlqoPRlzwBSHVEN8xzSu3Bs2t7l6ukiG5 Mh2vqlQIsoy6
FhqZDmNURSSD4qUK6qX/hDJshTYshUIsYl2oQDgD/lzI/pgmeMxfJ6rq//Ee QNZqvyoi533s
FVqgLPJO0QggokmdF5lsFAZfEXJqAaUh8oFhvNpRtz5fv/prTG2ifg6a1kVY Y1UmS8IcXChr
0iKrpnmmQRxRqClRxlKO2b2YqQZo1Q0TF5bh81ntzWIeEmqhvjIhFQ6cue1r EEZgrJLdy6at
ztqq1+KqvG7t2SZhz+4p1c7qdQLrQKxWMfodRTIZbwonNhIubgpucCJuNipu 4eqmbybul02q
QDSDEmWo1KbHnOIMJV4cImauItapEdqbI1YpNSFci1zpGporoAIZMPpplYIu 653pKtJRK4qp
/59GHJqC6iySrunq4rly6TDlou5Jp90+jaaM7q5pKaRR5qDGAqVtX3iu5dIq 7fRaFrOCFvGy
Wq4sWn/a3/BqL/YuGMC6hl0irKE+aMQ+7ISqb/qy71pN7EO0JvjWWvThp4uu aNzGk/fKLz41
5J8RD0oSLYVF1tHyKPUasPT+lJC65f4ycANDZvyeRt/2nVHCVnokZaQ2KgY/ aqJycAZ38AYX
HuR58AiDcAlr8Al/MAqTsAqbcAq78Aq/cAvD8AzLcA2z8A3HMA7LSwstrzY5 Lz2y5QELMQID
lfU+BKo5cBIrsUhCsGmQ71QlbEwAEvo6bBVT8RWvL8S8r0M08RJ78f8X6+nQ pmTRDvAcIi0R
o/EQm1PTGsSo+clhCiIYy/Ec010Xk4YEF2OhMlvgOu7iGm4fM+7h+nHjDu4f FzIhPy55RC4+
INE9XAiCZSodS/IkF6jyxiNu/DD31WMac7IaG44RUwOJ5eCJQfLUEqgzQac7 zhozJdrAAu1/
UnJy2XGCGuyCQrH5LqwVZzEWty8vO+z7mhlH4AU+qNmHRid81m9+CgaJ0lpr 3Kebqdoavkie
6loz99mLiqjUxHKLFaJp3GgAr2QZY2bMdXI5e/LgKPBAAIOZZQip/QkS01M0 10j2tpSKrvLU
oeh85vN0WjOMsug9y+g2+woP2rNESDDzUvD/tCRjDjM0DeuwDTc0ROPWpObC OnCbkdYF+0Wy
kl5i6dlpxj0pL9UKLd1pLcnr74K06iJcSd+um9pujYW0yd1uk5Lb8chbxxHi 8AUvurop79bu
QHIi7ibTSKPb54Zc6Xqi/go0f/Ypm/7PM1tyTRHr8xqreJ6zOWP1+M0JH/5C 5PRcXZADkgKG
0NXf5VnR2yLdp+rqFM1sApUq2AKo3GJhEYJu3tZtSrutyLb1XHct1cZs0e01 FC7Q8M1tyC51
r4hvYNtaAXZELSfbLTtoLvvyZO9yZfeyhdZg5J3ZZhdzcZru19rrtYphtuot LNIt2oo2yYor
2xZftt4iT0uf8RJh/+xQqxd2oO3B7csC3xbOtm0rSs6uNW3752EHdMC6nowR bGKI8YSFsxyO
8xlfdXRnNVmwsYeEWxIBgzC3X5I2XYmO7P5VrcR5rch2rGrzHwX1ttiO48rS bC120XiDIdYa
oW7bNT7Pt8vStVwHd3oTd64caAWNCJkWBB4/jx7LpgUj8iALciADsiEncoIz +CEvuIMjyCIj
UQ7WBXI1p2Dz9tyyYtIZdsq6q9seYRfadap+HtnO7nyHXWHjHdTh94jD+NrK d7smoSXud6gq
dX/rmin24Ip7pVQzbyZD7yZL95FP91q2ZXj5CS74hfsxkU93Llkfb8CpG++u EiMyYLWaXP/w
lu7lAa+P31I1aavmnVttk/Qj4jYuxqkrdlEo0hL8mTSefrhpl1LnoKItMl+T xjTwFjSPk8Yv
JvWXC2OiPDEKRjYNWrYuX3ajM/ovZ7ZEzDID73g1g2iPze/9Zro+A/o86e83 j7EAOzdMkDOS
m3pWp/P1EnelW/oxY/orzzmN0HOnvxFDAon/LsRBF3hsKjSCP/SvRzSwO3Sw E/tEW/CAOURz
0vqyM3t6Cat0zaMmB3GSU/uRe9qpY3u1a3u2c/u2e3taME+R2TKiW5VkLzpl Ozq6P3pbbXFD
THqzw3u8r9RyU6aoXyapQ/e363vSVreqy/u/Azxq4Yq4+21C9wT/H0t4g0M4 hUf4g0/4wkP8
w0u8P0TuSyDmxRePsgf8xnP8PT37kI8lVePDsXZ7yZOnEf9DM5CXaPbFEnF3 x8N8zKvGu1vE
oS9buSt6up/7zut8z+/V+xonPPwDPCRnDgILzdsvKvPzKRc3LCvfq3/2qsm8 VoI6c8fhvYuN
yWs9eaa6z/HcevKFtI61q996MtczdZ49q2Od2cdoPw/2rQF4eCd9XHOdP/+I 2sv8gbJ9Reg6
bP6dFC/0sAu+RBO+sBc+B09qhajDOmSIhv6Jxsfz0s/z5Kc92f/42QPa3IO4 3MM95/853l/z
1H/vnzvEx4dl84Y8ENvQvrO+jxrxnRTp/578Qp+8syktaYDS9BieG9CCXEnT 6yXquSxtaZy/
Xu5vHuw+deuudE2/qTJtLuZ+q8TZK/GbKU7btO/GaZ5bKbhSf7tN6ZmK/sxH fUzHOtbNis03
KM5XD8+vO/ur+/tT0vtWKkaDjDFratXu9NO9OKzn9QPmv1sDxD+BKP4RHCjw YMKCCxUydHjQ
YESHBhE2lAgR4UW
Re: web.xml error timeframe [message #88278 is a reply to message #88187] Tue, 29 March 2005 12:08 Go to previous messageGo to next message
Hi Hoi,
This schema file is invalid on its own. It is part of a larger group of
schemas that, when grouped together via include statements, form a valid
schema. Here's how you should register the schema from
in the XML catalog.
1. Save the j2ee_web_services_client_1_1.xsd file above to an Eclipse
project in your workspace on your local machine.
2. In Eclipse select Window->Preferences->Web and XML->XML Catalog.
3. Select New to add a new entry to the XML Catalog.
4. Click browse and select the file you just downloaded.
5. Change the Key Type to 'Schema Location' and enter the key
http://www.ibm.com/webservices/xsd/j2ee_web_services_client_ 1_1.xsd. (This
key is specified in one of the include statements in one of the other
schema files for J2EE 1.4.)
6. Click OK to save your new entry.
7. Click OK to exit the Eclipse preferences dialog.
8. Validate your web.xml file. It should validate correctly.
Lawrence
>Hi Lawrence,
Re: web.xml error timeframe [message #88335 is a reply to message #88013] Tue, 29 March 2005 12:25 Go to previous messageGo to next message
WTP tutorials are WTP content just like code. If something doesn't make
sense I encourage you to open a bugzilla report against the Web Tools
project's website component. This will get routed to the tutorial author
who can then work with you to make changes that will clarify the tutorial
and make it easier for others to use.
Lawrence
Re: web.xml error timeframe [message #88427 is a reply to message #88278] Tue, 29 March 2005 14:53 Go to previous messageGo to next message
The remote schema can now again be accessed at the correct location. You
should be able to validate your web.xml file correctly when working
connected.
Lawrence
Re: web.xml error timeframe [message #88671 is a reply to message #88427] Wed, 30 March 2005 01:53 Go to previous messageGo to next message
Originally posted by: qminor.austin.rr.com
Thanks Lawrence
Re: web.xml error timeframe [message #95308 is a reply to message #88278] Wed, 27 April 2005 02:25 Go to previous message
> Hi Hoi,
> in the XML catalog.
> Lawrence
Thank you Lawrence,
I'm really sorry that Eclipse come back to old problems again and again
Previous Topic:'localhost' are always set as the host name at wsdl.
Next Topic:An internal error occurred during: "Starting server".
Current Time: Sat Jul 19 09:14:36 EDT 2025
Powered by FUDForum. Page generated in 0.06622 seconds
