Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 1.5m7 + FORMS
RAP 1.5m7 + FORMS [message #877457] Sat, 26 May 2012 15:35 Go to next message
I'm using Rap 1.5M7 and when I try to use Rap with org.eclipse.ui.forms
I'm getting "No Adapter for type forms.widgets.ToggleHyperlink". but if I remove ExpandableComposite.TWISTIE style it work fine.
Section section = toolkit.createSection(form.getBody(),
	ExpandableComposite.TITLE_BAR | ExpandableComposite.TWISTIE
						| Section.EXPANDED);
Error: Error: Operation "create" on target "w84" of type "null" failed:
Properties:
parent = w81
images = rwt-resources/generated/7b687d84,10,10,,rwt-resources/generated/39c1da32,10,10,
bounds = 6,3,12,12
children =
tabIndex = 40
foreground = 74,74,74,255
background = 0,0,0,0
font = Verdana,Lucida Sans,Arial,Helvetica,sans-serif,11,true,false
cancelKeys = #38,#40
Re: RAP 1.5m7 + FORMS [message #877625 is a reply to message #877457] Sun, 27 May 2012 03:44 Go to previous messageGo to next message
I can't reproduce it with the current Git master. The
ToggleHyperlinkAdapter.js is there (in forms bundle). Could you try to
create a small project that demonstrate the problem. Please open a
bugzilla and attach the project there.
Ivan
> | Section.EXPANDED);
> Properties: parent = w81
> images =
> bounds = 6,3,12,12
> children = tabIndex = 40
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP 1.5m7 + FORMS [message #878146 is a reply to message #877625] Mon, 28 May 2012 13:04 Go to previous messageGo to next message
Sorry about delay to replay back I have created a test project.
I used web project type (standalone web app) other than eclipse plugin project.
SO I have create the test project with same setup as it include rwt runtime in lib folder it is too big to attach here so I have upload it to my drop box. please find link dl.dropbox.com/u/33401761/forms-test.zip
when you run web application with tomcat url for app is localhost:8080/test/forms
Re: RAP 1.5m7 + FORMS [message #878174 is a reply to message #878146] Mon, 28 May 2012 14:42 Go to previous message
if you are using the forms bundle in a RWT Standalone application you
have to register all needed resources (from the extension point)
manually. Here [1] is a similar question about FormsText in RWT
Standalone application.
[1] http://www.eclipse.org/forums/index.php/m/130256/
HTH,
Ivan
> project.
Ivan Furnadjiev
Previous Topic:[ANN] RAP 1.5 RC1 available, all source code moved to Git
Next Topic:get IHandlerService from background thread
Current Time: Sat Jul 19 08:22:19 EDT 2025
Powered by FUDForum. Page generated in 0.06898 seconds
