Eclipse based LPCxpresso problem [message #878060] |
Mon, 28 May 2012 08:50  |
I am using and eclipse based IDE LPCXpresso for embedded software development.
I would appreciate if you could answer the questions below:
I created a simple C project in LPCXpresso and built it succesfully. Then I was able to enter the debug mode using Xpresso board.
The problem:
When I try to change the MCU Settings, I have got the Error: "Internal: MCUCommonPageUI: ConfigInfo is empty". Now, I am not able to enter the debug mode. I got the error: Internal Error: Debug configuration is Empty.
These are the logs:
!SESSION 2012-05-28 11:29:11.692 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_30
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=tr_TR
Command-line arguments: -os win32 -ws win32 -arch x86 -data C:\Users\sena.ergullu.artesis\Documents\LPCXpresso_4.2.2_275\workspace5
!ENTRY org.eclipse.ui 2 0 2012-05-28 11:29:13.069
!MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2012-05-28 11:29:13.069
!MESSAGE Could not parse key sequence: plug-in='org.eclipse.cdt.make.ui', id='org.eclipse.cdt.make.ui.targetBuildCommand', keySequence='Shift+F9'
!ENTRY org.eclipse.ui 4 4 2012-05-28 11:29:15.237
!MESSAGE Unable to find view with id: com.crt.trueview.views.DisassemblyViewer, when creating perspective com.crt.lite.perspective.CRTPerspective
!ENTRY org.eclipse.cdt.core 1 0 2012-05-28 12:12:36.489
!MESSAGE Indexed 'deneme_2' (0 sources, 22 headers) in 0,27 sec: 189 declarations; 50 references; 5 unresolved inclusions; 0 syntax errors; 0 unresolved names (%*0,00)
!ENTRY com.crt.utils 0 4 2012-05-28 12:13:46.941
!MESSAGE Invalid byte 1 of 1-byte UTF-8 sequence.
!STACK 0
com.sun.org.apache.xerces.internal.impl.io.MalformedByteSequenceException: Invalid byte 1 of 1-byte UTF-8 sequence.
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.invalidByte(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.io.UTF8Reader.read(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.scanQName(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanAttribute(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.crt.utils.xmlparser.XMLParser.parse(XMLParser.java:260)
at com.crt.utils.xmlparser.XMLParser.parse(XMLParser.java:223)
at com.crt.utils.xmlparser.XMLParser.parseXML(XMLParser.java:378)
!ENTRY com.crt.advproject 4 -1 2012-05-28 12:13:46.988
!MESSAGE Internal: MCUCommonPageUI: configInfo is empty
!ENTRY org.eclipse.cdt.core 1 0 2012-05-28 12:55:07.120
!MESSAGE Indexed 'deneme_2' (2 sources, 24 headers) in 0,10 sec: 351 declarations; 206 references; 5 unresolved inclusions; 0 syntax errors; 0 unresolved names (%*0,00)
!ENTRY org.eclipse.ui 2 0 2012-05-28 12:55:07.808
!SUBENTRY 1 org.eclipse.ui 2 0 2012-05-28 12:55:07.808
!ENTRY org.eclipse.cdt.core 1 0 2012-05-28 12:55:08.666
!MESSAGE Indexed 'deneme_2' (2 sources, 24 headers) in 0,08 sec: 351 declarations; 206 references; 5 unresolved inclusions; 0 syntax errors; 0 unresolved names (%*0,00)
!ENTRY com.crt.advproject 4 -1 2012-05-28 13:19:12.383
!ENTRY com.crt.advproject 4 -1 2012-05-28 13:24:22.432
!MESSAGE Internal: No linker script for vendor=NXP proc= nature=0, project=deneme_2
!STACK 1
org.eclipse.core.runtime.CoreException: Internal error: debug configuration is empty
at com.crt.ctrlcenter.launch.CRTMCUDebugger.<init>(CRTMCUDebugger.java:253)
at com.crt.ctrlcenter.launch.CRTMCULaunchConfigurationDelegate.syncLaunch(CRTMCULaunchConfigurationDelegate.java:241)
at com.crt.ctrlcenter.launch.CRTMCULaunchConfigurationDelegate.launch(CRTMCULaunchConfigurationDelegate.java:194)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:924)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1128)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SUBENTRY 1 com.crt.ctrlcenter 4 0 2012-05-28 13:24:30.722
!MESSAGE Internal error: debug configuration is empty
!ENTRY com.crt.ctrlcenter 4 -1 2012-05-28 13:25:23.107
!MESSAGE Error launching Debug\deneme_2.axf
Cancelled:
I found out that the some part of the .cproject file is odd:
</storageModule>
<storageModule moduleId="com.crt.config">
<projectStorage><?xml version="1.0" encoding="UTF-8"?>
<TargetConfig>
<Properties property_0="" property_3="NXP" property_4="LPC1788" property_count="5" version="1"/>
<infoList vendor="NXP"><info chip="LPC1788" name="LPC1788"/>
</infoList>
</TargetConfig></projectStorage>
</storageModule>
</cproject>
I have tried hard so far but I could not find any solution. There are some strange characters like >
and < instead of '<' and '>'. Is that normal?
Please help.
Re: Eclipse based LPCxpresso problem [message #878827 is a reply to message #878496] |
Tue, 29 May 2012 22:44  |
On 05/29/2012 07:33 AM, Yahya Civelek wrote:
> 924 wiev and no reply. woov :) any clue?
LPCxpresso appears to be a third party tool that is based on Eclipse.
As such, you should probably pursue the support provided by LPCxpresso.
FUDForum. Page generated in 0.03648 seconds
