Home » Eclipse Projects » P2 » Is building own distribution by p2 is correct way?
Is building own distribution by p2 is correct way? [message #875828] Wed, 23 May 2012 07:50 Go to next message
Hi.
I want to build own eclipse distribution that includes some common plugins (like wtp) and plugins build by my own. I know that if I will install additional plugins to my installed eclipse and next I zip them, then there will be some metadata in plugins that shouldn't be there. If I will use p2 director to install eclipse and all other plugins that I want then zip it, will I bypass such problems like after packing my own eclipse?
Or maybe I try to resolve problem in wrong way? Maybe I should use some other tools to build distribution?
BR
Re: Is building own distribution by p2 is correct way? [message #875894 is a reply to message #875828] Wed, 23 May 2012 09:59 Go to previous messageGo to next message
On 2012-23-05 13:50, Tomasz Kowalski wrote:
> Hi.
> eclipse?
> BR
In general:
- Build product against a p2 repo that supports all platforms.
- Install with director for specific platform.
- Zip up result and distribute.
- Provide your p2 repository as update site.
For cloudsmith/geppetto @ github, we do this. We have a composite
repository that consists of all releases. When we make a new release
build, we simply add it to the composite.
Our build uses Buckminster, so everything is automated - a build
produces a p2 repository and zips for 4 different platforms. Everything
is in the geppetto git repository (except our jenkins setup) if you are
interested in more details about how we do things...
- henrik
Re: Is building own distribution by p2 is correct way? [message #876687 is a reply to message #875894] Fri, 25 May 2012 01:38 Go to previous message
Thanks for reply. I'll check your repo, hopefully I will learn something Smile.
BR
Tomek
Previous Topic:Perform site.xml "Build All" programmatically
Next Topic:Usage of dropins in RCP fails after renaming installation location
Current Time: Sun Jul 20 06:27:58 EDT 2025
Powered by FUDForum. Page generated in 0.03083 seconds
