Xtend, rich strings and SEPARATOR option [message #876315] |
Thu, 24 May 2012 07:05  |
In a previous post I have seen this code with rich strings
toString(Entity e) '''
«e.name»
«FOR member: e.members BEFORE "(" SEPARATOR "," AFTER ")"»
«member.toString»
«ENDFOR»
The result will be the members separated by commas, in parentheses. If there
are no members, there won't be parentheses.
OK, but how can I do if I have a conditional inside the FOR?, as in the example:
«e.name»
«IF (a condition...)»«member.toString»«ENDIF»
«ENDFOR»
Then, the result could be something like: m1, , , , m5, m6, m7, , , , , , m13,
How can I do if I want a result will be m1, m5, m6, m7, m3 ? Do I have to work it by hand?
Thanks in advance,
Aran
Re: Xtend, rich strings and SEPARATOR option [message #876379 is a reply to message #876315] |
Thu, 24 May 2012 09:36  |
What about wrapping it into an extra extension using map and filter?
e.g.
«e.name»
«FOR member: e.members.filter(m|a condition) BEFORE "(" SEPARATOR "," AFTER ")"»
«member.toString»
«ENDFOR»
[Updated on: Thu, 24 May 2012 14:08] by Moderator
FUDForum. Page generated in 0.23711 seconds
