Home » Eclipse Projects » Remote Application Platform (RAP) » NullPointerException in SetPerspective
NullPointerException in SetPerspective [message #870993] Thu, 10 May 2012 09:40 Go to next message
Hola,
I'm using Indigo and JavaSE 1.6 to create a Rap app.
I created an additional plugin which defines a new Perspective.
In the ApplicationWorkbenchWindowAdvisor of the main plugin, the configurer.setShowPerspectiveBar is set to true.
In Run Configurations I added/selected the new bundle.
When I try to switch to the new perspective, i got the following error.
Am I missing something?
	at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3715)
	at org.eclipse.ui.handlers.ShowPerspectiveHandler.openPerspective(ShowPerspectiveHandler.java:146)
	at org.eclipse.ui.handlers.ShowPerspectiveHandler.openOther(ShowPerspectiveHandler.java:118)
	at org.eclipse.ui.handlers.ShowPerspectiveHandler.execute(ShowPerspectiveHandler.java:57)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:306)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:167)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:239)
	at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:155)
	at org.eclipse.ui.internal.actions.CommandAction.run(CommandAction.java:169)
	at org.eclipse.rap.internal.design.example.builder.PerspectiveSwitcherBuilder$2.widgetSelected(PerspectiveSwitcherBuilder.java:158)
	at org.eclipse.swt.events.SelectionEvent.dispatchToObserver(SelectionEvent.java:196)
	at org.eclipse.rwt.internal.events.Event.processEvent(Event.java:44)
	at org.eclipse.swt.events.TypedEvent.processEvent(TypedEvent.java:161)
	at org.eclipse.swt.events.TypedEvent.executeNext(TypedEvent.java:201)
	at org.eclipse.swt.widgets.Display.runPendingMessages(Display.java:1143)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:1133)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2733)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2694)
	at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:2530)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:702)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:685)
	at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:157)
	at org.vsoft.vmenu.web.Application.start(Application.java:18)
	at org.eclipse.rap.ui.internal.application.EntrypointApplicationWrapper.createUI(EntrypointApplicationWrapper.java:25)
	at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createUI(EntryPointManager.java:81)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWTLifeCycle.java:204)
	at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadController.run(RWTLifeCycle.java:88)
	at java.lang.Thread.run(Thread.java:636)
	at org.eclipse.rwt.internal.lifecycle.UIThread.run(UIThread.java:101)
Re: NullPointerException in SetPerspective [message #872254 is a reply to message #870993] Tue, 15 May 2012 15:19 Go to previous messageGo to next message
Hola Hugo,
our demo bundle org.eclipse.rap.demo contains different perspectives.
The bundle org.eclipse.rap.demo.databinding contributes another
perspective. Maybe you can spot the difference between your application
and this demo? Have you tried your application with RCP?
Saludos, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: NullPointerException in SetPerspective [message #876059 is a reply to message #872254] Wed, 23 May 2012 16:31 Go to previous messageGo to next message
Hola Ralf,
thanks for your response.
I did another try with a simple sample and it worked.
I will dig a little bit more on mine.
Gracias!
Re: NullPointerException in SetPerspective [message #886766 is a reply to message #876059] Fri, 15 June 2012 11:41 Go to previous messageGo to next message
Hola Hugo,
did you find out something more on this issue?
thanks,
Agnes
Re: NullPointerException in SetPerspective [message #910662 is a reply to message #886766] Mon, 10 September 2012 03:08 Go to previous message
Had the same issue (rap version 1.5).
Helped to add configurer.setShowCoolBar(true) to resolve the issue.
public class ApplicationWorkbenchWindowAdvisor extends WorkbenchWindowAdvisor {
	public ApplicationWorkbenchWindowAdvisor(IWorkbenchWindowConfigurer configurer) {
		super(configurer);
	public void preWindowOpen() {
		IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
		// some how cool bar is required for rap to switch perspectives,
		// otherwise - NPE
		configurer.setShowCoolBar(true);
[Updated on: Mon, 10 September 2012 03:09] by Moderator
Previous Topic:Java to Java script conversion
Next Topic:[ANN] RAP 1.5M7 published, API changes
Current Time: Sun Jul 20 02:37:51 EDT 2025
Powered by FUDForum. Page generated in 0.05027 seconds
