Home » Archived » Jubula » Eclipse RCP e4
Eclipse RCP e4 [message #875931] Wed, 23 May 2012 11:17 Go to next message
Hey Guys,
is there a way to test e4 RCP Applications with Jubula? I've tried to adopt a tutorial with an eclipse 3.x rcp application. But after adding the jubula.rc.rcp bundle to my dependencies, the bundle needs a bunch of dependencies to the old eclipse 3.x stuff. Is there a special bundle vor e4 rcp? Or is my way completely wrong?
greetings,
thomas
Re: Eclipse RCP e4 [message #875942 is a reply to message #875931] Wed, 23 May 2012 11:40 Go to previous messageGo to next message
We're doing some work on e4 applications with the compatibility layer at the moment - the results are generally encouraging, though there is a problem with menus that is linked and described in this thread. We haven't started evaluating applications without the compatibility layer at the moment.
HTH,
Alex
Re: Eclipse RCP e4 [message #876215 is a reply to message #875942] Thu, 24 May 2012 02:53 Go to previous messageGo to next message
Hi Alexandra,
thank you for your quick response. Until now we doesn't need the compatibility layer, and the goal was indeed to develop a plain e4 application which is easy deployable and testable Smile Are there UI Testing alternatives for such a solution?
greetings from munich
thomas
Re: Eclipse RCP e4 [message #876223 is a reply to message #876215] Thu, 24 May 2012 03:26 Go to previous messageGo to next message
Hi Thomas,
we just started work on the e4 support, but with limited resources. The current plan is to have e4 support implemented by the end of 2012. Depending on the overall demand we might postpone an actual release until Kepler. If your are willing to help or sponsor the work we are not to proud to accept every bit of support we can get Wink
Achim
Re: Eclipse RCP e4 [message #879230 is a reply to message #876223] Wed, 30 May 2012 16:02 Go to previous messageGo to next message
Hi Achim,
All i can offer is to support you in my freetime. I'm not sure if this is enough for you. But if you want, feel free to send me a PM Smile
greetings,
Thomas
Re: Eclipse RCP e4 [message #880073 is a reply to message #879230] Fri, 01 June 2012 07:19 Go to previous messageGo to next message
Well, either I'm to stupid or there is no PM feature on the forum...
Marvin is working on e4 support. You may contact him at Marvin dot Mueller at bredex dot de
Achim
Re: Eclipse RCP e4 [message #894354 is a reply to message #880073] Sun, 08 July 2012 11:47 Go to previous messageGo to next message
I was trying to run jubula with a rcp e4 application, written under eclipse 4.2). My problem is that the rcp plugin seems to be unable to connect to the AUT agent. However, I have no dependency problems as mentioned above. Is my problem related to having e4 not fully supported or should the plugin and the agent be able to communicate?
thx for any help
Robert
Re: Eclipse RCP e4 [message #989572 is a reply to message #894354] Thu, 06 December 2012 14:27 Go to previous messageGo to next message
I've searched the news, the forum and the plan: Is it still down-to-earth to await to have a real (not compatibility layer) eclipse 4 application tested with jubula 1.2.3 or at least 2.0?
Re: Eclipse RCP e4 [message #989633 is a reply to message #989572] Fri, 07 December 2012 01:11 Go to previous messageGo to next message
We are working on it. If we don't encounter unexpected problems the Kepler release will be able to test e4 (w/o the compatibility layer). Can't make any promises for JunoSR2.
- Achim
Re: Eclipse RCP e4 [message #990063 is a reply to message #876215] Mon, 10 December 2012 11:58 Go to previous messageGo to next message
Thomas Kölling wrote on Thu, 24 May 2012 02:53
... the goal was indeed to develop a plain e4 application which is easy deployable and testable Smile Are there UI Testing alternatives for such a solution?
Hi Thomas,
Yes, Xored Q7 is a testing alternative with full e4 and latest GEF, GMF, Platform support.
Thank you,
Andrey
Re: Eclipse RCP e4 [message #998563 is a reply to message #875931] Thu, 10 January 2013 03:45 Go to previous messageGo to next message
Hy,
we are trying to test an e4 RCP application with Jubula (Kepler-Release Eclipse V4.3 M4).
Now we have the problem, that our AUT do not start correctly (the progress bar in the Progress View is pending and does not disappear).
Is e4 support with the Kepler-Release fully supported already?
Alex
Re: Eclipse RCP e4 [message #998681 is a reply to message #998563] Thu, 10 January 2013 08:53 Go to previous message
Hi Alex,
Thanks for the message and the interest. The support's not in yet, no, but Raimar is working on it at the moment. The plan is to have it in for the next Jubula standalone release (19th March, just before Eclipse Con), which means it will be in Kepler. I've just opened a bug to document our progress on it (here). As I've mentioned there, we'll be happy to provide artifacts to test / use even before it's in the official build.
HTH,
Alex
Previous Topic:Associating component names as parameters
Next Topic:Control didn't display in component type of new Test Step
Current Time: Sun Jul 20 04:28:20 EDT 2025
Powered by FUDForum. Page generated in 0.04976 seconds
