Home » Newcomers » Newcomers » How do you edit the eclipse.ini file?
How do you edit the eclipse.ini file? [message #874395] Sun, 20 May 2012 15:31 Go to next message
W7 64bit.
When I right-click and select Edit on eclipse.ini, it opens Notepad and it's all one long line with no breaks. That already seems bad since there is no space between options and arguments. Anyway, I'm trying to set the -vm option so I broke the text so that it looks like what you see in the Wiki for eclipse.ini and added (as 2 separate lines)
-vm
C:\Program Files (x86)\Java\jre6\bin\javaw.exe
Saved it and invoked eclipse.exe, but continue to get this message:
A Java Runtime Environment or Java Development Kit must be available ...
No Java virtual machine was found after searching the following locations:
C:\eclipse\eclipse\jre\bin\javaw.exe
javaw.exe in your current PATH
Re: How do you edit the eclipse.ini file? [message #874468 is a reply to message #874395] Sun, 20 May 2012 20:50 Go to previous messageGo to next message
You should post the full current contents, it would be difficult to figure out otherwise. But it probably didn't completely lack spaces, you were probably seeing a file as it opens in Notepad when the lines are only separated by Line Feeds and not pairs of Carriage Returns and Line Feeds.
Re: How do you edit the eclipse.ini file? [message #875317 is a reply to message #874468] Tue, 22 May 2012 10:14 Go to previous messageGo to next message
What's the situation with the eclipse.ini file as released for Windows platforms? The Wiki for eclipse.ini makes it look as if you can read it in a straightforward manner with Notepad. From your remarks, that appears not to be the case. What text editor sholud I use on eclipse.ini on a Windows platform?
As far as posting the current contents, I'm using that which came with indigo 64bit and only want to add the -vm option.
Re: How do you edit the eclipse.ini file? [message #875322 is a reply to message #875317] Tue, 22 May 2012 10:24 Go to previous messageGo to next message
It's straight, ASCII text. Use Notepad, Vim, whatever.
Re: How do you edit the eclipse.ini file? [message #875345 is a reply to message #875322] Tue, 22 May 2012 11:00 Go to previous messageGo to next message
It may have ASCII text, but it does not read properly. In Notepad, there is no visible spacing or newline-ing as shown in the eclipse Wiki page. Therefore, it isn't clear how one edits it to add an option, in my case the -vm option.
UPDATE: Setting that aside, attached is a human-readable eclipse.ini that does not allow me to set the -vm option.
When I invoke eclipse.exe in the same folder (eclipse) where the eclipse.ini file is, I get the following message:
  • Attachment: eclipse.ini
    (Size: 0.50KB, Downloaded 334 times)
[Updated on: Tue, 22 May 2012 11:17] by Moderator
Re: How do you edit the eclipse.ini file? [message #875376 is a reply to message #875345] Tue, 22 May 2012 12:15 Go to previous messageGo to next message
> the -vm option.
Well, then toss Notepad for a proper ASCII text editor. I would suggest
Notepad++ if you're not a vi initiate.
I'm not sure what you mean by saying there's no visible spacing or
newline information on the wiki page. Nevertheless, to add the -vm
option, place it alone on a line. On the next line, give the full path
to the JRE in your JDK as shown in http://wiki.eclipse.org/Eclipse.ini.
Re: How do you edit the eclipse.ini file? [message #875440 is a reply to message #875345] Tue, 22 May 2012 15:01 Go to previous messageGo to next message
Your putting the -vm entry after the -vmargs entry. This will pass the lines to the vm as arguments and they will not be stripped off by the launcher as you need. These lines have to appear prior to the -vm line.
Also, you are specifing a 32 bit vm. However, it looks like you are running a 64 bit version of Eclipse. This won't work. Eclipse and Java have to be the same bit size.
Re: How do you edit the eclipse.ini file? [message #875541 is a reply to message #875440] Tue, 22 May 2012 19:44 Go to previous messageGo to next message
Thank you!! Very Happy That made the difference and I no longer get the error message. Now I'm getting a Java return code of 13 which is almost certainly due to the 32bit vs 64bit issue you write about. So it's off to get the Java 64bit.
I missed the crucial line in the Wiki about the order of the options.
[Updated on: Tue, 22 May 2012 19:57] by Moderator
Re: How do you edit the eclipse.ini file? [message #875543 is a reply to message #875541] Tue, 22 May 2012 19:49 Go to previous messageGo to next message
Russel (above): I didn't write it clearly. I meant to say that the eclipse.ini file that's part of the release package, when I open it, all I see is one line, UNLIKE that presentation on the Wiki. In any event, I saved a copy of the original, inserted newlines where appropriate, and then added the -vm option at the end. As clarified, that's not the place to put it since it follows a -vmargs line and the parsing isn't as it should be.
In any event, I want to thank you for stopping by an examining my problem. If it wasn't for the forum, I'd be totally stuck.
[Updated on: Tue, 22 May 2012 19:51] by Moderator
Re: How do you edit the eclipse.ini file? [message #876389 is a reply to message #875543] Thu, 24 May 2012 09:53 Go to previous message
> should be.
Glad you're up and running, Larry. Best of luck to you.
Previous Topic:tag suggestions
Next Topic:Export Product Wizard Problems - No repository found
Current Time: Sat Jul 19 12:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.14937 seconds
