Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3(SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3)
SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #874969] Mon, 21 May 2012 17:57 Go to next message
Hi, all:
I was just trying a simple SWT Slider example at http://www.java2s.com/Code/Java/SWT-JFace-Eclipse/SliderExample.htm .
My Environment:
Ubuntu: 12.04
Eclipse: Version: Indigo Service Release 2
Build id: 20120216-1857
OpenJDK: 6b24-1.11.1-4ubuntu3
SWT: 3.7.2-2
I've been expecting exactly the same results (a dialog with 2 sliders ) as shown http://www.java2s.com/Code/Java/SWT-JFace-Eclipse/SliderExample.htm . But what I got now is just http://www.visionopen.com/questions/SliderExample.png, there is no slider at all.....
So, does SWT work with OpenJDK 6b24-1.11.1-4ubuntu3 ?
Cheers
Pei
[Updated on: Mon, 21 May 2012 17:59] by Moderator
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #875403 is a reply to message #874969] Tue, 22 May 2012 13:13 Go to previous messageGo to next message
The same code works fine under Windows7.
The Environment:
Windows 7
Oracle Sun Java: Java SE 6 Update 31
SWT: 3.7.2-2
Still, it doesn't work under Ubuntu 12.04 + OpenJDK.
Can anybody help to explain why it is so, and how to modify to make it work?
Cheers
Pei
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #875417 is a reply to message #875403] Tue, 22 May 2012 14:03 Go to previous messageGo to next message
Now, I tried the following environment, still doesn't work:
Ubuntu: 12.04
SunJDK: jdk1.6.0_32
SWT: 3.7.2-2
Now, I would ask, is SWT (Slider) able to work properly under Ubuntu 12.04?
Cheers
Pei
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #875850 is a reply to message #875403] Wed, 23 May 2012 08:55 Go to previous messageGo to next message
Am 22.05.2012 19:13, schrieb JIA Pei:
> The Environment:
> Windows 7
> SWT: 3.7.2-2
> work?
I am also using Ubuntu 12 LTS
You may want to test it with Oracle Java:
1.
Download the
jdk-7u4-linux-<architecture>.tar.gz file and extract it to e.g.
/usr/lib/jvm/
2.
Make a symbolic link, that you can change it to a another version easily
ln -s /usr/lib/jvm/jdk1.7.0_04 /usr/lib/jvm/oracle-jdk
3. update-alternative just to the symbolic link (auto-modus)
update-alternatives --install "/usr/bin/java" "java"
"/usr/lib/jvm/oracle-jdk/bin/java" 1
update-alternatives --install "/usr/bin/javac" "javac"
"/usr/lib/jvm/oracle-jdk/bin/javac" 1
update-alternatives --install "/usr/bin/javaws" "javaws"
"/usr/lib/jvm/oracle-jdk/bin/javaws" 1
update-alternatives --install "/usr/bin/jar" "jar"
"/usr/lib/jvm/oracle-jdk/bin/jar" 1
"/usr/lib/mozilla/plugins/mozilla-javaplugin.so" "mozilla-javaplugin.so"
"/usr/lib/jvm/oracle-jdk/jre/lib/<architecture>/libnpjp2.so" 1
Thomas B
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #877192 is a reply to message #875850] Fri, 25 May 2012 23:36 Go to previous messageGo to next message
Hi, Thomas:
Thanks for your reply.
I tested jdk1.7.0_04 as well. SWT Slider also fails to display.
I didn't do the following yet. But, my question is: is the following step (your 3rd step) a must for Eclipse to run the real Java? You know, I've already added
Windows->Preference->Installed JREs.
Thanks again Thomas, thank you..
Best Regards
Pei
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #878513 is a reply to message #877192] Tue, 29 May 2012 09:12 Go to previous messageGo to next message
the third step is necessary to get your "alternatives" installed on
Ubuntu, and you can change it with "update-alternatives --config java".
You dont need to remove your OpenJDK. But if you want to start Eclipse
or your other Java programs with Oracle Java, then you need to activate
this alternative. Of course you can change your JRE within Eclipse, if
you just want to start/test your programs within Eclipse.
Thomas B
Am 26.05.2012 05:36, schrieb JIA Pei:
> Hi, Thomas:
> I've already added Windows->Preference->Installed JREs.
> Quote:
> Best Regards
> Pei
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #878705 is a reply to message #877192] Tue, 29 May 2012 15:17 Go to previous messageGo to next message
You're actually running the snippet fine, I see the same problem on
Ubuntu 12.
The strange behaviour is caused by Ubuntu 12's new custom overlay
scrollbars. They are overriding the default GTK scrollbar, which is the
native widget that swt uses for Slider controls. The overlay scrollbars
are not used when Eclipse is run because Ubuntu has "eclipse" in a list
of apps whose scrollbars are not to be overridden with the overlay ones.
However when you run a stand-alone swt example you're not running
"eclipse", so Ubuntu goes and replaces the conventional scrollbars with
the overlay-style ones, which do not appear when not contained in a
scrollable parent control. I'll likely log a report with Ubuntu about
this to see how to deal with this going forward.
In the meantime, they provide a workaround for manually turning the
overlay scrollbars off. Set Linux environment variable
LIBOVERLAY_SCROLLBAR to 0 and your snippet will run fine.
Grant
On 5/25/2012 11:36 PM, JIA Pei wrote:
> Hi, Thomas:
> Quote:
> Best Regards
> Pei
Re: SWT 3.7.2-2 is not working with OpenJDK 6b24-1.11.1-4ubuntu3 [message #883367 is a reply to message #878705] Fri, 08 June 2012 07:39 Go to previous message
Thank you so much Grant Gayed. By just removing the following 3 packages related to overlay:
overlay-scrollbar
liboverlay-scrollbar3-0.2-0
liboverlay-scrollbar0.2-0
Now, SWT comes back to life ^_^
Thanks again...
Cheers
Pei
[Updated on: Fri, 08 June 2012 07:40] by Moderator
Previous Topic:Drawing an image on a double buffered canvas
Next Topic:SWT Print to file - any way to get the output type?
Current Time: Sat Jul 19 10:25:49 EDT 2025
Powered by FUDForum. Page generated in 0.26607 seconds
