Home » Archived » BIRT » Birt styles priority(Birt styles are broken when the report is embedded in uPortal)
Birt styles priority [message #874763] Mon, 21 May 2012 09:58 Go to next message
When we define styles properties in a report, it appears Birt generates the css classes at the top of the report, for example on a table header:
.style_31 {color:white}
When a report is embedded in a portal, and if this portal globally defines the css table header, then it will override the birt style. For example, uPortal adds a css class 'uP' on the body element of the page, and in the portal css there is something like:
.uP th {color:black}
Because of the 'th' tag, the weight is stronger in the portal css, and the birt table header style is overridden. Thus, the whole styles are completely mixed and the report cannot be used. I wonder if there would be a way to increase the birt styles weight, for example if the class generated by birt was such below it would resolve most of the issues:
.style_31 {color:white!important}
Since these classe names can be namespaced, it could not disturb the other page components. If it is not currently possible, would it be a good idea to submit this feature?
thanks
[Updated on: Mon, 21 May 2012 10:00] by Moderator
Re: Birt styles priority [message #874902 is a reply to message #874763] Mon, 21 May 2012 13:57 Go to previous messageGo to next message
This would be a good enhancement request. Do you want to open a
bugzilla for it?
Jason
On 5/21/2012 9:58 AM, donino donino wrote:
> example, uPortal adds a css class 'uP' ont the body element of the page,
> uP th {color:black}
> most of the issues:
> feature?
> thanks
Re: Birt styles priority [message #875158 is a reply to message #874902] Tue, 22 May 2012 04:42 Go to previous messageGo to next message
Jason,
This enhancement request has been logged as Bug 380216
Re: Birt styles priority [message #875383 is a reply to message #875158] Tue, 22 May 2012 12:22 Go to previous messageGo to next message
Thanks for logging it. BTW have you tried to import a style likeL
..mystyle
background-color: Yellow!important
and then apply the style and see if that makes a difference?
You could also look at trying the link at view time styles.
http://www.eclipse.org/birt/phoenix/project/notable2.3.php#jump_9
Jason
On 5/22/2012 4:42 AM, donino donino wrote:
> Jason,
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=380216
> Thanks
Re: Birt styles priority [message #875450 is a reply to message #875383] Tue, 22 May 2012 15:21 Go to previous messageGo to next message
Jason,
When the styles are imported, the !important annotation is removed and will not be used. If the css file is linked at view time then it will work, though i'm not sure how the relative path must be filled for a css file: is it relative to the resource path, the web application or the report?
However it is in my opinion much more efficient to take advantage of the eclipse birt designer to style the report items.
thanks
Re: Birt styles priority [message #875497 is a reply to message #875450] Tue, 22 May 2012 17:13 Go to previous message
I believe this is relative to the web app. If you use this technique
both the view time css and designer css files will be in the output.
The engine will try to locate the external style first and if not found
it will default to designer styles. I agree with you that the better
option is to let the designer handle it.
Jason
On 5/22/2012 3:21 PM, donino donino wrote:
> Jason,
> report? However it is in my opinion much more efficient to take
> thanks
Previous Topic:Button in a BIRT report
Next Topic:Viewer request encoding
Current Time: Sun Jul 20 07:22:30 EDT 2025
Powered by FUDForum. Page generated in 0.05880 seconds
