Home » Eclipse Projects » Standard Widget Toolkit (SWT) » selection and deselection in treeviewer(Selection Event)
selection and deselection in treeviewer [message #875276] Tue, 22 May 2012 09:07 Go to next message
When I change a selection in a treeviewer, it appears to have two selection events, one for the deselected item and the other for selected item, in that order.
This is not at all desirable at some times, especially if it involves making server calls. Is there anyway to avoid the first selection event i.e. event from deselection?
Thanks for your help!
[Updated on: Tue, 22 May 2012 09:07] by Moderator
Re: selection and deselection in treeviewer [message #877077 is a reply to message #875276] Fri, 25 May 2012 17:01 Go to previous message
SWT's Tree does not send selection events for event deselections, so
they must be originating in the TreeViewer. You should ask this on the
JFace forum since TreeViewer comes from JFace.
Grant
Previous Topic:How to set Scroll bar thumb position programatically
Next Topic:Mac Cocoa:-Z order of canvas inside view is changing on resetPerspective
Current Time: Sun Jul 20 06:19:02 EDT 2025
Powered by FUDForum. Page generated in 0.03257 seconds
