Home » Eclipse Projects » Remote Application Platform (RAP) » MenuManager on right click doesn't work properly with 1.5M6
MenuManager on right click doesn't work properly with 1.5M6 [message #873542] Fri, 18 May 2012 09:47 Go to next message
I have a MenuManager on a Text field, using Rap 1.4 goes well. I migrated to Rap 1.5M6, and it seems there is a problem.
Here is the code:
Text valueText;
MenuManager menu = new MenuManager("#PopupMenu");
menu.add(action);
valueText.setMenu(menu.createContextMenu(valueText));
On Rap 1.5M6 your mouse position should be exactly on Text borders. If its position is inside the Text area, on mouse right click the menuManager wont show up.
I also tried with rap 1.5M7 and I have same problem.
Bianca
Re: MenuManager on right click doesn't work properly with 1.5M6 [message #874591 is a reply to message #873542] Mon, 21 May 2012 03:45 Go to previous message
Hi Bianca,
sounds like a bug for me. Could you please open a bugzilla and attach a
snippet to reproduce the issue there?
Ivan
On 5/18/2012 4:47 PM, Bianca Cojanu wrote:
> Here is the code:
> Text valueText;
> menu.add(action);
> menuManager wont show up. I also tried with rap 1.5M7 and I have same
> problem.
> Bianca
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:Multi User Application - Guidelines?
Next Topic:Change default meta headers in M7
Current Time: Sun Jul 20 15:09:58 EDT 2025
Powered by FUDForum. Page generated in 0.03622 seconds
