Home » Language IDEs » ServerTools (WTP) » IWAB0019E Error in getting method from Java bean.
IWAB0019E Error in getting method from Java bean. [message #85750] Tue, 22 March 2005 13:10 Go to next message
Originally posted by: amol.xx.xx
I am selecting a simple java bean with getXX():String method to create a
webservice.
After selecting this, a click on next and I select the web apps and click
next. at this point, instead of displaying the methods, it generates this
error:
at
org.eclipse.jst.ws.internal.axis.creation.ui.command.JavaToW SDLMethodCommand.execute(JavaToWSDLMethodCommand.java:95)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
at
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveForwardToNextStop(CommandFragmentEngine.java:208)
at
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.run(SimpleCommandEngineManager.java:206)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
Re: IWAB0019E Error in getting method from Java bean. [message #86839 is a reply to message #85750] Thu, 24 March 2005 11:06 Go to previous messageGo to next message
Would you mind sending me your java bean to try debugging this? You may
also want to open a bugzilla and attach the stack trace.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols
-seng
> webservice.
> click next. at this point, instead of displaying the methods, it
> generates this error:
> at
> at
> at
> at
> at
> at
Re: IWAB0019E Error in getting method from Java bean. [message #87387 is a reply to message #86839] Fri, 25 March 2005 14:21 Go to previous message
Originally posted by: eric.mcintyre.tenethealth.com
I am also getting this error. I have entered bug 89121
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=89121).
Eric
Previous Topic:Eclipse 2.1
Next Topic:Source code not being compiled and copied
Current Time: Sat Jul 19 23:53:18 EDT 2025
Powered by FUDForum. Page generated in 0.06209 seconds
