Home » Modeling » TMF (Xtext) » java.lang.OutOfMemoryError: PermGen space
java.lang.OutOfMemoryError: PermGen space [message #812923] Sun, 04 March 2012 10:00 Go to next message
Hello, when I launch the second eclipse, with a project that needs Xbase dependency, I get this error:
¿Any solution?
Thank you very much.
Re: java.lang.OutOfMemoryError: PermGen space [message #812937 is a reply to message #812923] Sun, 04 March 2012 10:25 Go to previous messageGo to next message
> ¿Any solution?
Did you try increasing the PermGen space? (in the launch config).
- henrik
Re: java.lang.OutOfMemoryError: PermGen space [message #812998 is a reply to message #812937] Sun, 04 March 2012 12:42 Go to previous messageGo to next message
I have modify the file eclipse.ini to increase it to 512:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.100.v20110505
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512m
--launcher.defaultAction
openFile
-vmargs
-Xms40m
-Xmx384m
is this what you meant???
Re: java.lang.OutOfMemoryError: PermGen space [message #813016 is a reply to message #812998] Sun, 04 March 2012 13:17 Go to previous messageGo to next message
shouldnt you change the Jvm Arguments of your Launch Configuration (Run -> Run Configurations...) e.g. by adding
-XX:MaxPermSize=128m
there
~Christian
Re: java.lang.OutOfMemoryError: PermGen space [message #813046 is a reply to message #813016] Sun, 04 March 2012 14:19 Go to previous messageGo to next message
Hi Christian
eclipse.ini editing is what Eclipse FAQs recommend; it fixes all uses of
one Eclipse.
I do the same as you which fixes one use of a potentially migrating Eclipse.
Ed Willink
On 04/03/2012 18:17, Christian Dietrich wrote:
> there
> ~Christian
Re: java.lang.OutOfMemoryError: PermGen space [message #813084 is a reply to message #813046] Sun, 04 March 2012 15:29 Go to previous messageGo to next message
Hi Ed,
adding --launcher.XXMaxPermSize
256m
has no influence on runtime "eclipse applications" at least in my experience
the only influence is on "Launch Eclipse Runtime"
so you have
(a) always make sure you choose "Launch Eclipse Runtime" and not "Eclipse Application"
(b) add the XX:MaxPermSize manually to the Launch "Eclipse Application" Config
~Christian
Re: java.lang.OutOfMemoryError: PermGen space [message #873110 is a reply to message #813084] Thu, 17 May 2012 10:05 Go to previous message
Christian Dietrich wrote on Sun, 04 March 2012 15:29
Hi Ed,
256m
so you have
~Christian
I've tried editing eclipse.ini at first, but didn't work. Changing the launch config did. Thanks Smile
Previous Topic:Problems with formatting rules
Next Topic:(Xtext) 15 Minute Tutorial needs to be updated for version 2.2
Current Time: Sun Jul 20 02:57:17 EDT 2025
Powered by FUDForum. Page generated in 0.04822 seconds
