Home » Eclipse Projects » Mylyn » Choice lists not updating for Target Milestone
Choice lists not updating for Target Milestone [message #8696] Mon, 09 July 2007 19:25 Go to next message
Originally posted by: david_whiteman.us.ibm.com
How do I sync the choice lists for various fields in the Bugzilla bug
editor? Is the following a bug, or is there something I need to do to
get the choice lists to update?
1. Use Mylyn for a long time, creating and updating bug reports,
assuming you have Target Milestones i1, i2, i3, i4.
2. Your PMC adds two new milestones to the project in Bugzilla: i5 and i6.
3. Open a bug report in Mylyn and it still does not show i5 and i6 in
the list, even after those target milestones have been in the system for
several days
I'm using eclipse 3.3 with the GA version of Mylyn for Europa.
David
Re: Choice lists not updating for Target Milestone [message #8710 is a reply to message #8696] Tue, 10 July 2007 03:30 Go to previous messageGo to next message
You can right click on the repository and choose "Update Attributes". Does
that work?
"David Whiteman" <david_whiteman@us.ibm.com> wrote in message
news:f6ug5u$vf$1@build.eclipse.org...
> editor? Is the following a bug, or is there something I need to do to get
> 1. Use Mylyn for a long time, creating and updating bug reports, assuming
> 3. Open a bug report in Mylyn and it still does not show i5 and i6 in the
> several days
> David
Re: Choice lists not updating for Target Milestone [message #8722 is a reply to message #8696] Tue, 10 July 2007 04:17 Go to previous messageGo to next message
Originally posted by: richard.richardmiskin.plus.com
If you right click on a repository in the Task Repositories view there is an option to called Update Attributes. I think this will do what you want.
I've no idea if there is a way get Mylyn to regularly do this (e.g. once a week) - possibly worth raising a bug for it?
Richard
Re: Choice lists not updating for Target Milestone [message #10850 is a reply to message #8722] Tue, 10 July 2007 16:48 Go to previous messageGo to next message
Originally posted by: beatmik.acm.org
If you have background synchronization on Mylyn will currently do this
on every 10th synchronization:
http://wiki.eclipse.org/index.php/Mylyn_FAQ#Why_are_my_updat ed_repository_attributes_not_showing_up.3F
Note that we are currently brainstorming on how to make this policy
smarter than "every 10th time".
196056: [performance] reduce frequency of repository configuration download
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196056
Mik
> Cheers,
> Richard
Re: Choice lists not updating for Target Milestone [message #10890 is a reply to message #10850] Tue, 10 July 2007 17:18 Go to previous message
> Mik
Thanks Mik and others! I just went in and checked, and apparently it
had been through 10 syncs, since the new attributes were now showing up
in open bug report windows. Sorry that I didn't think to check the FAQ!
David
Re: Choice lists not updating for Target Milestone [message #570360 is a reply to message #8696] Tue, 10 July 2007 03:30 Go to previous message
that work?
> several days
> David
Re: Choice lists not updating for Target Milestone [message #570437 is a reply to message #8696] Tue, 10 July 2007 04:17 Go to previous message
Richard
Re: Choice lists not updating for Target Milestone [message #570705 is a reply to message #8722] Tue, 10 July 2007 16:48 Go to previous message
Mik
> Cheers,
> Richard
Re: Choice lists not updating for Target Milestone [message #570819 is a reply to message #10850] Tue, 10 July 2007 17:18 Go to previous message
> Mik
David
Previous Topic:Force query to refresh with up to date credentials
Next Topic:How do I update the list of milestones
Current Time: Sun Jul 20 08:58:08 EDT 2025
Powered by FUDForum. Page generated in 0.06156 seconds
