Home » Eclipse Projects » EGit / JGit » Initializing New GitHub Repository with API
Initializing New GitHub Repository with API [message #871291] Fri, 11 May 2012 15:17 Go to next message
I want to use the GitHub API to initialize a newly created GitHub repository. I want to mimic the new functionality that's apart of the web UI, where a README will automatically be created and committed so that the fresh repo can just be cloned.
I'm having trouble though because every call to the GitHub API responds with a repository empty error.
I've tried following the procedure here: swanson.github.com/blog/2011/07/23/digging-around-the-github-api-take-2.html
That didn't work obviously because there are no existing commits.
So, then I thought I could:
1. create a blob
2. create a tree from that blob
3. commit that tree
4. create a reference pointing to that tree
That failed on step 1 because the repo is empty.
I've tried permutations of the above steps (creating the tree first, creating the ref first, creating the commit first) and each time - I get a repo empty error.
Is it even possible to do what I'm trying to do from starting from an empty repo?
[Updated on: Fri, 11 May 2012 15:18] by Moderator
Re: Initializing New GitHub Repository with API [message #871293 is a reply to message #871291] Fri, 11 May 2012 15:19 Go to previous messageGo to next message
What exact error are you getting when it is failing?
Could you post the code snippet you are using for this as well?
Re: Initializing New GitHub Repository with API [message #871294 is a reply to message #871293] Fri, 11 May 2012 15:23 Go to previous messageGo to next message
Exact error is "Git Repository is empty. (409)" REALLY rough code is below. I added a content field to TreeEntry.
	public void initializeRepo() throws SmartServiceException {
		DataService service = createDataService();
		RepositoryId repo = new RepositoryId(repositoryOwner, repositoryName);
		try {
//			if (LOG.isDebugEnabled()) {
//				LOG.debug("Getting reference " + repo.toString() + "/"
//						+ MASTER_REFERENCE);
			//Create a blob for the file with its contents
//			String blobSha = service
//					.createBlob(
//							repo,
//							new Blob()
//									.setContent(
//											README_CONTENTS)
//									.setEncoding(Blob.ENCODING_UTF8));
			//create a new tree with our blob
			TreeEntry treeEntry = createTreeEntryWithContent(readmeFileName, README_CONTENTS);
			List<TreeEntry> treeEntries = new ArrayList<TreeEntry>();
			treeEntries.add(treeEntry);
			Tree newTree = service.createTree(repo, treeEntries);
			//Commit our blob
			Commit newCommit = new Commit().setTree(newTree);
			Commit createdCommit = service.createCommit(repo, newCommit);
			//Create a reference to the new tree
			Reference newRef = new Reference()
					.setObject((TypedResource) new TypedResource()
							.setType(TypedResource.TYPE_COMMIT)
							.setUrl(createdCommit.getUrl())
							.setSha(createdCommit.getSha())).setRef(MASTER_REFERENCE);
			Reference createdRef = service.createReference(repo, newRef);
		} catch (IOException e) {
			e.printStackTrace();
	private TreeEntry createBlobTreeEntry(String path, String sha) {
		TreeEntry treeEntry = new TreeEntry();
		treeEntry.setPath(path);
		treeEntry.setMode(TreeEntry.MODE_BLOB);
		treeEntry.setSha(sha);
		treeEntry.setType(TreeEntry.TYPE_BLOB);
		return treeEntry;
	private TreeEntry createTreeEntryWithContent(String path, String content) {
		treeEntry.setContent(content);
		return treeEntry;
[Updated on: Fri, 11 May 2012 15:24] by Moderator
Re: Initializing New GitHub Repository with API [message #871303 is a reply to message #871294] Fri, 11 May 2012 16:27 Go to previous messageGo to next message
Which call is throwing that exception?
Re: Initializing New GitHub Repository with API [message #871304 is a reply to message #871303] Fri, 11 May 2012 16:30 Go to previous message
That exception is thrown on the below line (when it's not commented out)
String blobSha = service.createBlob(repo,new Blob().setContent(README_CONTENTS).setEncoding(Blob.ENCODING_UTF8));
Previous Topic:pushing to remote repo fails, authenticity error
Next Topic:project decorations still broken with local tracking
Current Time: Sun Jul 20 17:13:41 EDT 2025
Powered by FUDForum. Page generated in 0.27259 seconds
