how to actually run VE code...? [message #87102] |
Thu, 14 April 2005 01:20  |
Originally posted by: simon.ou.edu
Hi...
How do I actually run the code generated from VE? When I try to run the
code, I get the following (see below at the end of the message). The
tutorial at
http://www-106.ibm.com/developerworks/opensource/library/os- ecvisual/
says to put something like what follows in the arguments:
-Djava.library.path=C:\eclipse\plugins\org.eclipse.swt.win32 _3.0.0\os\win32\x86
but I do not see a 'org.eclipse.swt.win32...' plugin any where. I wonder
what I could do to run the code? Thanks.
Regards...
Miguel.
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-win32-3128 in java.library.path
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
at SWTExample.main(SWTExample.java:30)
Re: how to actually run VE code...? [message #87199 is a reply to message #87129] |
Thu, 14 April 2005 11:52   |
Hi Joe...
Thanks for your help.
The SWT launcher did not work, but we know this now.
With regard to the article, I have not been able to put time into this
yet, but it does look very promising. I think that the format is
adequate, and the message does get across. It seems that the article is
adequate at least for folks at my proficiency level ( <= medium).
Thanks for the efforts that have gone in the article.
I am interested in a 2D plot widget that scrolls as inputs come by. I
will use your article to see if I can do something along this line.
Thanks again.
Regards...
Miguel.
Joe Winchester wrote:
> SWT requires a bit of native code every operating system it runs on, and
> the name and location of this varies. If you're using Eclipse 3.1 as
> your development platform then this has a new friendly launcher called
> "SWT Application". Select this instead of "Java Application" and it
> does a pretty good job of finding the location of the native library and
> adding it to the VM arguments for you. If this works you can also go to
> the debug perspective, bring up the properties on the entry in the Debug
> viewer you will actually see the whole arguments to the javaw.exe
> command and you could copy and paste the -Djava.library ... bit if
> you're trying to create a batch file for example.
> How did you find the tutorial overall ? If you've got any feedback
> please add it to the bugzilla
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=88801. It's having its
> final review right now by the Eclipsecorner editors for formatting and
> stuff, but if you found any errors or anything more that needs
> explaining please let us know, as in the new few days it'll move from
> our CVS repository where we can make instant change to the Eclipsecorner
> one where we don't have commit rights and updates will become harder.
> Best regards,
> Joe Winchester
Re: how to actually run VE code...? [message #87228 is a reply to message #87213] |
Thu, 14 April 2005 12:38  |
Hi Joe...
Yes, this works. Simple and easy. Thanks again.
Regards...
Miguel.
> Hi Miguel,
> Run your class with the main(String[]) method using the Java Application
> launcher and look at the error message. You had one like:
> Find the file swt-win32-3128.dll in the file system. You could just
> Windows explorer and just search for it starting at the root location of
> your Eclipse install. Once you have file right mouse click and bring up
> its properties and in Windows you can select beside the Location label
> and use Ctrl+C to copy this into the clipboard. Let's assume the label
> is something like:
> C:\Eclipse_3_1_M6\eclipse\workspaces\dev_04_11\org.eclipse.s wt.win32\os\win32\x86\swt-win32-3128.dll.
> Then go back to your Java Application launcher configuration, select the
> second tab called Arguments and in the text box called VM Arguments:
> write the line;
> -Djava.library.path=""
> and between the quotation marks copy the clipboard contents and remove
> the last segment (the actual dll name) so it'd become something like
> -Djava.library.path=" C:\Eclipse_3_1_M6\eclipse\workspaces\dev_04_11\org.eclipse.s wt.win32\os\win32\x86 "
> I think from Rich's post that there might be some issue with the actual
> location of the dll being in a jar file in which case you'd need to
> extract it. However it worked for me using an M6 3.1 driver although I
> had imported the plugin project org.eclipse.swt into my workspace.
> Best regards,
> Joe
Re: how to actually run VE code...? [message #607141 is a reply to message #87102] |
Thu, 14 April 2005 05:32  |
Hi Miguel,
> tutorial at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88801 It's having its
Joe Winchester
Re: how to actually run VE code...? [message #607144 is a reply to message #87129] |
Thu, 14 April 2005 10:34  |
Joe, The SWT launcher from Eclipse is broken right now. They also got
caught by the everything in jar problem that we got bit with!
Rich Kulp
Re: how to actually run VE code...? [message #607145 is a reply to message #87174] |
Thu, 14 April 2005 11:42  |
Hi Rich...
Thanks for this update. I was not sure of what I was doing wrong because
I could not get any thing to work.
Using E.3.1, with the latest VE nightly build, how could I run the VE
SWT example? I do not find the org.eclipse.swt.win32_3... plugin. Is
this broken somehow, or... I am not too sure of what to do. The following:
-Djava.library.path=" installation_directory\plugins\org.eclipse.swt.win32_3.0.0\o s\win32\x86
seems not to be an option? Thanks for your suggestions.
Regards...
Miguel.
Re: how to actually run VE code...? [message #607146 is a reply to message #87129] |
Hi Joe...
Thanks again.
Regards...
Miguel.
> Best regards,
> Joe Winchester
Re: how to actually run VE code...? [message #607147 is a reply to message #87187] |
Thu, 14 April 2005 12:22  |
Hi Miguel,
is something like:
write the line;
Joe
Re: how to actually run VE code...? [message #607148 is a reply to message #87213] |
Hi Joe...
Regards...
Miguel.
> Hi Miguel,
> is something like:
> write the line;
> Best regards,
> Joe
FUDForum. Page generated in 0.08462 seconds
