Home » Archived » Jubula » Tests on more than one AUT
Tests on more than one AUT [message #871009] Thu, 10 May 2012 10:14 Go to next message
I want to test some synchronization between two clients with a server. So my problem is, when I start a test case I want
1. Clean up server directory and start server
2. Start first AUT
2.1 Make some changes in AUT1
3. Start second AUT
3.1 checkout changes
4. Compare changes at filesystem level via script
Is this possible with Jubula?
cheers,
Muki
Re: Tests on more than one AUT [message #871013 is a reply to message #871009] Thu, 10 May 2012 10:27 Go to previous messageGo to next message
to test multiple AUTs you can use Test Jobs. For further information check this link.
HTH
Oliver
Re: Tests on more than one AUT [message #871149 is a reply to message #871013] Fri, 11 May 2012 03:17 Go to previous messageGo to next message
There is also a blog entry on testing with Test Jobs that you can read here.
Alex
Re: Tests on more than one AUT [message #1706804 is a reply to message #871149] Mon, 31 August 2015 05:41 Go to previous messageGo to next message
Hi Alex!
I am reading your post about testing multiple AUT but I have some doubts. I have a Test Job that uses two AUT and I want to test it using command line (test executor)
I have tried starting applications with autrun before test executor, I have tried starting only one and then configuring the other on the parameters of test executor but anything worked.
Could you tell me what steps to follow in my case?
Thank you
[Updated on: Mon, 31 August 2015 06:29] by Moderator
Re: Tests on more than one AUT [message #1706969 is a reply to message #1706804] Tue, 01 September 2015 04:37 Go to previous message
what exactly is not working? Are the AUT´s not started? Can the AUTs not be found by the testexec? On which platform are you trying to do this? Which toolkit do you want to test? Please add more information!
Have you followed all the steps described here?
Oliver
Previous Topic:import data with Excel
Next Topic:How to data loop at parent test case level
Current Time: Sun Jul 20 18:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.03988 seconds
