Home » Eclipse Projects » WindowBuilder » Same code, but designer doesn't work
Same code, but designer doesn't work [message #870961] Thu, 10 May 2012 07:10 Go to next message
I create a Swing dialog on Windows and copy it to Ubuntu. However, on Ubuntu I can't open the designer. And vice-versa. Windows edition can't open the designer of a dialog created by Linux version. Both use the same version of Eclipse with WindowBuilder integrated. Then I create the same project (name, jdialog class - default), and compare code. They're the same. Do you meet the same problem? Could you tell me how to use same code on 2 environment? Of course I need the designer.
Thanks and regards,
Jakov
Re: Same code, but designer doesn't work [message #871019 is a reply to message #870961] Thu, 10 May 2012 10:37 Go to previous messageGo to next message
I would suggest posting a test case. What you describe works fine for me.
Re: Same code, but designer doesn't work [message #871333 is a reply to message #871019] Sat, 12 May 2012 02:31 Go to previous message
Yes, thanks. maybe there's no problem with designer. I can do it now. Just some problem of difference Java version (between Eclipse and project setting) or HeadlessException that's delayed me post until now. I fix them all now.
Thanks and have a nice day!
Previous Topic:Trouble Using Created Jar files on Windows
Next Topic:WindowBuilder SWT editor exception in Juno M7 (not happen in M6)
Current Time: Sun Jul 20 10:38:13 EDT 2025
Powered by FUDForum. Page generated in 0.03597 seconds
