Home » Modeling » GMF (Graphical Modeling Framework) » GMF RCP Application Guide Request
GMF RCP Application Guide Request [message #86358] |
Tue, 19 December 2006 05:08  |
Originally posted by: christian.daenekas.informatik.uni-oldenburg.de
Hi there!
I did a search on the support of generating a GMF application without
the eclipse IDE dependencies. While there is some info around about
building RCP applications, it´s often concerned with very special issues
.. So my request is a general guide about building an GMF RCP application
supporting all features that can be used when using the GMF editor
application within eclipse. I´m using 2.0M2 and my GMF application must
be integrated into an existing RCP application, so I think it should be
the right approach to generate RCP code to get rid of "evil"
dependencies. This could also be the base for a comprehensive RCP Guide
for the 2.0 release. I think there are many people interested in
something like this. If such a guide already exists and I was to blind
to see it, forget what I said ;). Looking forward to your support.
Thanks in advance,
Christian Dänekas
Re: GMF RCP Application Guide Request [message #87010 is a reply to message #86994] |
Thu, 21 December 2006 06:51   |
Originally posted by: 5d5.mail.ru
This wizard page is generated in later builds - after the date request
was closed; please take the last GMF build. It really makes no sense to
install early builds and wonder why some features are missing.
Christian Dänekas wrote:
> Hi Alex,
> The GMF version I downloaded is M3 for sure, but apart from that I was
> confused because the Dialog I searched for seemed to be present since
> some time according to some posts I read. I now tried the approach
> suggested at
> http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg01533.html
> .. I just added a GenApplication Child to my gmfgen model and generated
> the diagram code. Most of it seems to be failure free. But there is a
> Problem with a Wizard Class that can not be resolved. The import of
> org.eclipse.ui.dialogs.WizardNewFileCreationPage fails and causes a
> bunch of additional errors. Do you have an idea what up with that? The
> fault is located in my EditorCreationWizardPage Class, which look like this:
> package de.permeter.analysis.editor.diagram.part;
> import org.eclipse.core.runtime.IPath;
> import org.eclipse.jface.viewers.IStructuredSelection;
> import org.eclipse.swt.widgets.Composite;
> import org.eclipse.ui.dialogs.WizardNewFileCreationPage;
> * @generated
> public class EditorCreationWizardPage extends WizardNewFileCreationPage {
> * @generated
> private static final String DOMAIN_EXT = ".editor"; //$NON-NLS-1$
> * @generated
> private static final String DIAGRAM_EXT = ".editor_diagram"; //$NON-NLS-1$
> * @generated
> public EditorCreationWizardPage(String pageName,
> IStructuredSelection selection) {
> super(pageName, selection);
> * @generated
> protected String getDefaultFileName() {
> return "default"; //$NON-NLS-1$
> * @generated
> public String getFileName() {
> String fileName = super.getFileName();
> if (fileName != null && !fileName.endsWith(DIAGRAM_EXT)) {
> fileName = DIAGRAM_EXT;
> return fileName;
> * @generated
> private String getUniqueFileName(IPath containerPath, String fileName) {
> String newFileName = fileName;
> IPath diagramFilePath = containerPath.append(newFileName DIAGRAM_EXT);
> IPath modelFilePath = containerPath.append(newFileName DOMAIN_EXT);
> int i = 1;
> while (exists(diagramFilePath) || exists(modelFilePath)) {
> i;
> newFileName = fileName i;
> return newFileName;
> * @generated
> public void createControl(Composite parent) {
> super.createControl(parent);
> IPath path = getContainerFullPath();
> if (path != null) {
> String fileName = getUniqueFileName(path, getDefaultFileName());
> setFileName(fileName);
> } else {
> setFileName(getDefaultFileName());
> setPageComplete(validatePage());
> * @generated
> protected boolean validatePage() {
> if (super.validatePage()) {
> String fileName = getFileName();
> if (fileName == null) {
> return false;
> fileName = fileName.substring(0, fileName.length()
> - DIAGRAM_EXT.length())
> DOMAIN_EXT;
> IPath path = getContainerFullPath().append(fileName);
> if (exists(path)) {
> setErrorMessage("Model file already exists: "
> path.lastSegment());
> return false;
> return true;
> return false;
> * @generated
> public static boolean exists(IPath path) {
> return path.toFile().exists();
> I hope someone can help.
> Christian
> Alex Shatalin schrieb:
>> Hello Christian,
>> As far as i can see from
>> http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy#2.0 _M4 RCP
>> application generation support was added in GMF M4 milestone (was not
>> released yet). In the same time you are using GMF 20061117 (looks like
>> it is some stable build, even not M3 which was released 20-11). So I
>> suggest you to take one of the latest integtation builds from
>> http://download.eclipse.org/modeling/gmf/downloads/drops/I-I 20061218-200612181200/index.php
>> (be carefull with the dependencies - it requires Eclipse M4 and
>> integration build of EMF) or wait for GMF M4.
>> Alex Shatalin
Re: GMF RCP Application Guide Request [message #87345 is a reply to message #87128] |
Fri, 22 December 2006 08:43   |
Hello again,
today I tried to generate a editor application after I added my
validation stuff (Audit Containers etc,) to my models. Everything
concerned with code generation works fine so far, but I get an
unresolvable import in my ValidationProvider class. The import that
doesn´t work is
"org.eclipse.ui.actions.WorkspaceModifyDelegatingOperation". Is this a
GMF bug? Of course I can´t run my application because of this, so I´m
desperate for help. I also searched after the concerned class, but I
found no explanation or hint what is wrong.
Thanks in advance,
Christian
Dmitry Stadnik schrieb:
> In my setup I have 63 binary plugins + gmf runtime without *.ide plugins
> and that's all. We may throw away some parts such as geoshapes and
> something from emf but there still be a lot of bytecode (((
> I also think that we may ask to break down gmf runtime in smaller pieces
> to ease RCP developers efforts.
>> Alex and Dmitry,
>> I tried the latest stream integration build
>> ( http://download.eclipse.org/modeling/gmf/downloads/drops/I-I 20061218-200612181200/index.php).
>> The dialog still doesn´t show up. I tried the thing with the
>> GenApplication Child in the gmfgen model again and this time the code
>> was build without errors and I got an application with my editor which I
>> can run from eclipse. Is this the same you get when using the RCP from
>> the dialog that is hiding from me? My plans are to integrate the editor
>> application as a perspective into a RCP application. Of course when I
>> run the RCP app now I don´t have a proper perspective to use the editor
>> in. I can select the editor by selection a perspective called Resource,
>> which worked before as well. But now I can create a editor document
>> without the need for a project, which is pretty neat. But I noticed that
>> the editor application still needs a total of 85 plugins to run. Is this
>> normal or did I something wrong. Do you have links to useful documents
>> that show how to integrate a GMF editor into a RCP application ?
>> Thanks for your help,
>> Christian
>>> Hello Christian,
>>> Yes, you need latest stable build - RCP support was not fully included
>>> into M3.
>>> Alex Shatalin
Re: GMF RCP Application Guide Request [message #87419 is a reply to message #87345] |
Fri, 22 December 2006 10:14   |
Use IRunnableWithProgress instead.
> Hello again,
> doesn´t work is
> Thanks in advance,
> Christian
>>> Alex and Dmitry,
>>> Christian
>>>> Hello Christian,
>>>> into M3.
>>>> Alex Shatalin
Re: GMF RCP Application Guide Request [message #87448 is a reply to message #87419] |
Fri, 22 December 2006 11:11   |
Okay,
I´ve just noticed that the error was caused by a missing dependency to
org.eclipse.ui.ide . The problem at runtime is that the diagrams can´t
be validated. When using the code generation that fits for executing the
editor in eclipse itself, a menu "Diagram" appears, when the diagram is
in focus. Within this menu you can choose "Validate" and the Diagram is
validated using the audits/constraints that I have implemented in java.
However there is no "Validate" option when generated and executed as an
RCP application. And if I use the editor plugins inside the sdk, the
validate option still appears but doesn´t have any effect. My question,
if this is normal and I have to look into creating the Validate action
myself or did I something wrong and my application is broken?
Greetings,
Christian
>> Hello again,
>> doesn´t work is
>> Thanks in advance,
>> Christian
>>>> Alex and Dmitry,
>>>> Christian
>>>>> Hello Christian,
>>>>> into M3.
>>>>> Alex Shatalin
Re: GMF RCP Application Guide Request [message #101763 is a reply to message #87448] |
Tue, 06 February 2007 16:09   |
Hi Christian,
I've exactly the same problem.
Hugues
Christian Dänekas a écrit :
> Okay,
> Greetings,
> Christian
>>> Hello again,
>>> doesn´t work is
>>> Thanks in advance,
>>> Christian
>>>>> Alex and Dmitry,
>>>>> Christian
>>>>>> Hello Christian,
>>>>>> into M3.
>>>>>> Alex Shatalin
Re: GMF RCP Application Guide Request [message #102085 is a reply to message #101763] |
Wed, 07 February 2007 10:34   |
You might like to use the GMF 2.0 nightly version since it includes the
working Diagram validation functionality thanks to Dmitry.
Greetings,
Christian
Hugues Rerolle schrieb:
> Hi Christian,
> Regards,
> Hugues
>> Okay,
>> Greetings,
>> Christian
>>>> Hello again,
>>>> doesn´t work is
>>>> Thanks in advance,
>>>> Christian
>>>>>> Alex and Dmitry,
>>>>>> Christian
>>>>>>> Hello Christian,
>>>>>>> into M3.
>>>>>>> Alex Shatalin
Re: GMF RCP Application Guide Request [message #102386 is a reply to message #102085] |
Thu, 08 February 2007 15:04  |
Hi Christian,
OK ! I'll try It, Thanks !
Hugues
> Greetings,
> Christian
>> Hi Christian,
>> Regards,
>> Hugues
>>> Okay,
>>> Greetings,
>>> Christian
>>>>> Hello again,
>>>>> doesn´t work is
>>>>> Thanks in advance,
>>>>> Christian
>>>>>>> Alex and Dmitry,
>>>>>>> Christian
>>>>>>>> Hello Christian,
>>>>>>>> into M3.
>>>>>>>> Alex Shatalin
Current Time: Sat Jul 19 14:49:32 EDT 2025
Powered by FUDForum. Page generated in 0.36288 seconds
