Home » Archived » BIRT » Birt logging
Birt logging [message #870527] Tue, 08 May 2012 10:36 Go to next message
So the newbie is trying to figure out how to get the Birt server going. Got everything setup right, because when I want to open a report:
http://localhost:8080/M2LicenseService/birt?__report=helloworld.rptdesig
I get a nice exception:
org.eclipse.birt.report.exception.ViewerException: The report file : C:\Documents and Settings\User\My Documents\m2license\server\trunk\source\service\src\main\webapp\birt\report/helloworld.rptdesig does not exist or contains errors.
Which is correct. It shows me the path where it is trying to load that report. So I created helloworld.rptdesign with only a label on it and typed the correct URL this time.
http://localhost:8080/M2LicenseService/birt?__report=helloworld.rptdesign
That response confused me, so I figured it would be good to see what is going on and added this to the web.xml.
<context-param>
<param-name>BIRT_VIEWER_LOG_DIR</param-name>
<param-value>/tmp/birtlog</param-value>
</context-param>
<context-param>
<param-name>BIRT_VIEWER_LOG_LEVEL</param-name>
<param-value>FINEST</param-value>
</context-param>
But nothing is written in that folder. Where are my logs going? The other settings (like BIRT_VIEWER_WORKING_FOLDER) are picked up.
Tom
Re: Birt logging [message #870532 is a reply to message #870527] Tue, 08 May 2012 10:48 Go to previous messageGo to next message
Forgot to copy the response: "There is no report design object available.".
Found out that it is a version conflict: the report was created with designer 3.7.2, while I have runtime 3.7.1. I still have no logging, though.
Tom
Re: Birt logging [message #870590 is a reply to message #870532] Tue, 08 May 2012 16:56 Go to previous messageGo to next message
Tom
How do you have it deployed? I would have expected to see something
with one of the viewer servlet mappings in it ie:
http://localhost:8080/birt/frameset?........
Jason
> though.
> Tom
Re: Birt logging [message #870616 is a reply to message #870590] Wed, 09 May 2012 00:47 Go to previous messageGo to next message
> How do you have it deployed? I would have expected to see something with one of the viewer servlet mappings in it ie:
I've bound the BirtEngineServlet to /birt, got that from some blog that said "all you need to do". And aside from logging into c:/tmp/birtlog I do get my "helloworld", so it is working. No Ajax stuff, but just that.
But I did find a more complex setup with filters, listeners and servlets in the viewer webapp, so my next step is to copy over that and see what happens. It does seem to be quite an overkill; filters and listeners and servlets just to render a report.
Re: Birt logging [message #870805 is a reply to message #870616] Wed, 09 May 2012 14:28 Go to previous messageGo to next message
Did you want to try to just deploy viewer? On tomcat it should be just a
copy operation.
Jason
Re: Birt logging [message #870832 is a reply to message #870805] Wed, 09 May 2012 15:09 Go to previous messageGo to next message
On 2012-05-09 20:28, Jason Weathersby wrote:
> Did you want to try to just deploy viewer? On tomcat it should be just a copy operation.
It needs to run on glassfish, but I've got Wicket and Jersey already setup, so I need to merge it into my web.xml.
Tom
Re: Birt logging [message #870838 is a reply to message #870832] Wed, 09 May 2012 15:31 Go to previous messageGo to next message
Tom
I assume using the tag libraries is not acceptable for your app?
Jason
>> a copy operation.
> Tom
Re: Birt logging [message #870864 is a reply to message #870838] Thu, 10 May 2012 01:04 Go to previous messageGo to next message
Since I'm using Wicket, there are no JSP's. That is, I could use them, but it would be an mixing apples and oranges thing. The servlet is preferable. I'm going to work on Birt again today.
Tom
Re: Birt logging [message #870912 is a reply to message #870864] Thu, 10 May 2012 04:54 Go to previous message
Ok, I've found the logging; apparently /tmp does not mean the filesystem's root, but somewhere in my project tree.
Seems I've got the servlets running as well. However, I'm finding the impact in my project somewhat severe; the need for axis, the requirement to roll in 70MB for the designer vs the sensitivity for the version (my eclipse plugins were 3.7.2, runtime 3.7.1, but it did not render, so I downloaded the 3.7.1 designer). The fact that some lock is blocking recompilation and I need to do clean builds and glassfish restarts every time.
I'm in doubt if I should continue. Maybe first I'm going to drop the viewer part and see how things fare with just the engine. I do like the power of the engine (based on my reading).
Tom
Previous Topic:Birt mavenization
Next Topic:downgrading plugin to 3.7.1
Current Time: Sat Jul 19 07:54:58 EDT 2025
Powered by FUDForum. Page generated in 0.31828 seconds
