Home » Archived » BIRT » org.eclipse.birt.core.archive.FolderArchive Example?
org.eclipse.birt.core.archive.FolderArchive Example? [message #870450] Tue, 08 May 2012 05:54 Go to next message
I'm trieing to use the FolderArchive to manage my ReportDocuments.
Example:
FolderArchive archive = new FolderArchive("c:\\temp\\Documents");
// IRunTask
runTask.run((IDocArchiveWriter) archive);
IReportDocument rptdoc = getReportEngine().openReportDocument(null, archive, null);
This never returns a document able to render. The render result is always a blank PDF (when rendering PDF).
Is there a example how the FolderArchive should work? Do I have to use one for each executed task? Or is it meant to work as a container for more then one job?
Thanks!
Jan
Re: org.eclipse.birt.core.archive.FolderArchive Example? [message #870584 is a reply to message #870450] Tue, 08 May 2012 16:37 Go to previous messageGo to next message
Jan
Try something like the following:
package REAPI;
import java.util.HashMap;
import java.util.Locale;
import org.eclipse.birt.core.archive.FolderArchiveReader;
import org.eclipse.birt.core.archive.FolderArchiveWriter;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IRenderTask;
import org.eclipse.birt.report.engine.api.IReportDocument;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import com.lowagie.text.pdf.PdfReader;
public class RunThenRenderFolderArchive {
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
IReportDocument document = null;
try{
config = new EngineConfig( );
config.setBIRTHome("C:\\birt\\birt-runtime-2_6_1\\birt-runtime-2_6_1\\reportEngine");
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
FolderArchiveWriter faw = new
FolderArchiveWriter("c:/test/myfolderarchive");
FolderArchiveReader far = new
FolderArchiveReader("c:/test/myfolderarchive");
IReportRunnable design = null;
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
IRunTask task = engine.createRunTask(design);
task.setLocale(new Locale("en", "US"));
task.run(faw);
task.close();
document = engine.openReportDocument(far.getName(), far, new HashMap(
//HTMLRenderOption options = new HTMLRenderOption();
//options.setOutputFormat("ppt");
//options.setOutputFileName("output/resample/topnpercent.ppt");
//options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
PDFRenderOption options = new PDFRenderOption();
options.setOutputFileName("output/resample/topnpercentFA.pdf");
options.setOutputFormat("pdf");
IRenderTask rtask = engine.createRenderTask(document);
rtask.setLocale(new Locale("en", "US"));
rtask.setRenderOption(options);
rtask.render();
rtask.close();
document.close();
engine.destroy();
System.out.println("Finished");
}catch( Exception ex){
ex.printStackTrace();
finally
Platform.shutdown( );
* @param args
try
RunThenRenderFolderArchive ex = new RunThenRenderFolderArchive( );
ex.runReport();
catch ( Exception e )
e.printStackTrace();
On 5/8/2012 5:54 AM, Jan Kohnert wrote:
> Hello,
> Example:
> // IRunTask
> archive, null);
> more then one job?
> Thanks!
> Jan
Re: org.eclipse.birt.core.archive.FolderArchive Example? [message #870702 is a reply to message #870584] Wed, 09 May 2012 07:57 Go to previous messageGo to next message
Thank you Jason.
I there a way to get a IReportDocument without using files but the memory instead?
Do I have to create one folder writer / reader for each document or can it be used as a container?
Jan
Re: org.eclipse.birt.core.archive.FolderArchive Example? [message #870814 is a reply to message #870702] Wed, 09 May 2012 14:49 Go to previous messageGo to next message
Jan,
I do not know of a way to write the rptdoc in memory unless you wanted
to use something like a MappedByteBuffer.
The folder writer is writing the contents of the rptdocument, so you
will probably need to do a dropStream first.
Jason
On 5/9/2012 7:58 AM, Jan Kohnert wrote:
> Thank you Jason.
> memory instead?
> Jan
Re: org.eclipse.birt.core.archive.FolderArchive Example? [message #884990 is a reply to message #870814] Tue, 12 June 2012 04:25 Go to previous messageGo to next message
I wrote an IDocArchiveReader and IDocArchiveWriter implementation that uses memory byte fields only to create a document. It passed all my tests. However, I cannot assure that everything works with it! Especially the listStreams:relativePath. String method remains untested since all my tests return an empty list here (also when using FolderArchive). So I only return any stream that contains the relativePath String at this point without knowing if this is a correct behavior.
The call is done like this:
MemoryArchive memoryArchive = new MemoryArchive();
runTask.run(memoryArchive);
Map<?, ?> properties = new HashMap<Object, Object>();
IReportDocument reportDocument = getReportEngine().openReportDocument(memoryArchive.getName(), memoryArchive, properties);
With this message attached the source code. Do with it whatever you like. If you run into problems using it, or if it is just running fine, I would appreciate you feedback. Thank you!
Re: org.eclipse.birt.core.archive.FolderArchive Example? [message #885181 is a reply to message #884990] Tue, 12 June 2012 10:55 Go to previous message
Jan,
Cool example. You should put this on the dev share at birt-exchange.org
to get feedback.
Jason
On 6/12/2012 4:25 AM, Jan Kohnert wrote:
> Hello,
Previous Topic:API: setProperty() with Type
Next Topic:Decreasing image quality in PDF-Export
Current Time: Sun Jul 20 02:23:48 EDT 2025
Powered by FUDForum. Page generated in 0.04270 seconds
