Exceptions between MySQL and Eclipse using the clause SELECT in a table named condition [message #869590] |
Thu, 03 May 2012 12:40  |
I'm working with EclipseIndigo, EclipseLink and MySQL I have a table called condition I need to keep it with that name but when I execute this command "Query qb = em.createQuery("SELECT c FROM Condition c ")" in eclipse it throws this exception:
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'condition' at line 1
at sun.reflect.GeneratedConstructorAccessor5.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.Util.getInstance(Util.java:386)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1052)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4096)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4028)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2490)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2651)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2683)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2144)
at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:2310)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeSelect(DatabaseAccessor.java:931)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:607)
I know that MySQL has a command called condition and that's why this command throws me an exception. The question is: there is a form to keep my table named as condition and I can execute this command "Query qb = em.createQuery("SELECT c FROM Condition c ")"?
FUDForum. Page generated in 0.03441 seconds
