Home » Modeling » TMF (Xtext) » Duplicate entries / namespace problems
Duplicate entries / namespace problems [message #870248] Mon, 07 May 2012 08:47 Go to next message
Hi guys,
i have this grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http ://www.xtext.org/example/mydsl/MyDsl"
Model:
	(jobfunction += JobFunction)*
JobFunction: name='executeJob'
			(statements+=Statement)*
Statement :
		TryStatement       |
		CatchStatement     |
		DeclarationStatement
enum CatchEnums: NegativeResponseException | NoResponseException
TryStatement       : keyword='try' '{'(tryStatements+=Statement)+ '}' ;
CatchStatement     : keyword='catch' ((exception=CatchEnums | userException=StringDeclaration) '{'(catchStatements+=Statement)+ '}') ;
DeclarationStatement : Declaration ';'
Declaration : StringNumberBoolDeclaration |
			  ButtonDeclaration;
StringNumberBoolDeclaration : StringDeclaration | IntDeclaration | FloatDeclaration | BoolDeclaration;
StringDeclaration : type='string' name=ID ('=' exp=Expression)?;
IntDeclaration : type='int' name=ID ('=' exp=Expression)?;
FloatDeclaration : type='float' name=ID ('=' exp=Expression)?;
BoolDeclaration: type='bool' name=ID ('=' exp=Expression)?;
ButtonDeclaration : type='button' name=ID;
Expression : expSingle+=SingleExpression (op+=Operator expSingle+=SingleExpression)*
enum Operator : PLUS='+' |
				MINUS='-' |
				EQUAL='==' |
				NOT='!'
SingleExpression :
				( litInt = INT ) |
				( litBool = ('true' | 'false') ) |
				( invert='!'? var = [Declaration] )
with this simple file:
executeJob ()
	try
		int bla;
	try
		int bla;
The error Xtext gives me is : Duplicate Statement bla.
The same text worked with Xtext 1.0. The expected behaviour would be for
Xtext to recognize the try block as a seperate scope. If the variable had been declared
in a higher level than the blocks I would have understood that, but not like that.
Now I already tried to hack together a "workaround" like this:
public Class<? extends INamesAreUniqueValidationHelper> bindINamesAreUniqueValidationHelper() {
	return NAUVH.class;
public class NAUVH extends NamesAreUniqueValidationHelper {
	private String getLastSeg(URI u) {
		return u.segment(u.segmentCount() - 1);
	private boolean isInScope(IEObjectDescription descr, IEObjectDescription decl) {
		int diff = descr.getEObjectURI().fragment().length()
				- decl.getEObjectURI().fragment().length();
		String f1 = descr.getEObjectURI().fragment();
		String f2 = decl.getEObjectURI().fragment();
		int slash1 = f1.lastIndexOf("@");
		int slash2 = f2.lastIndexOf("@");
		String sub1 = f1.substring(0, Math.max(0, slash1));
		String sub2 = f2.substring(0, Math.max(0, slash2));
		return sub1.startsWith(sub2);
	public void checkUniqueNames(Iterable<IEObjectDescription> descriptions,
			ValidationMessageAcceptor acceptor) {
		Iterator<IEObjectDescription> iter = descriptions.iterator();
		if (!iter.hasNext())
			return;
		List<IEObjectDescription> decls = new ArrayList<IEObjectDescription>();
		while (iter.hasNext()) {
			IEObjectDescription descr = iter.next();
			for (IEObjectDescription decl : decls) {
				// if in scope and name value is identical, print an error!
				if (isInScope(descr, decl)
						&& descr.getQualifiedName().getLastSegment()
								.equals(decl.getQualifiedName().getLastSegment())) {
					acceptor.acceptError("Duplicate variable "
							+ descr.getQualifiedName().getLastSegment() + " ("
							+ descr.getEObjectURI().fragment() + ")",
							descr.getEObjectOrProxy(), null, -1, null, "");
			decls.add(descr);
			CancelIndicator cancelIndicator, ValidationMessageAcceptor acceptor) {
		this.checkUniqueNames(descriptions, acceptor);
[Updated on: Mon, 07 May 2012 08:49] by Moderator
Re: Duplicate entries / namespace problems [message #870353 is a reply to message #870248] Mon, 07 May 2012 14:00 Go to previous messageGo to next message
you have following options
(1) the hack
(2) remove the general duplicate validation and add some custom for the scopes it should be checked within
(3) give the stuff names (IQualifiedNameProvider) that takes the context (try, ...) into account
i would prefer (2)
~Christian
Re: Duplicate entries / namespace problems [message #870414 is a reply to message #870353] Tue, 08 May 2012 02:07 Go to previous messageGo to next message
Could you please elaborate on option (2) ? That would be really helpful.
Re: Duplicate entries / namespace problems [message #870419 is a reply to message #870414] Tue, 08 May 2012 02:32 Go to previous messageGo to next message
simply remove the namesuniquevalidation from the workflow and write a java validation as described in the docs.
Re: Duplicate entries / namespace problems [message #974003 is a reply to message #870248] Tue, 06 November 2012 14:51 Go to previous message
late reply: a simple fix i found for this, perhaps it will be useful for someone :
public class MyNameProvider extends DefaultDeclarativeQualifiedNameProvider {
	protected QualifiedName qualifiedName(Statement ele)
		if (ele.eContainer() instanceof TryStatement)
			if (EcoreUtil2.isAssignableFrom(MyDslPackage.Literals.STRING_NUMBER_BOOL_DECLARATION, ele.eClass()))
				StringNumberBoolDeclaration decl = (StringNumberBoolDeclaration) ele;
				return QualifiedName.create("try", String.valueOf(NodeModelUtils.findActualNodeFor(ele.eContainer()).getOffset()), decl.getName());
		return null;
the only remaining problem: now only duplicates in try-blocks are recognized, so i've got to find another solution to providing a qualifiedname.
[Updated on: Tue, 06 November 2012 14:54] by Moderator
Previous Topic:implementing Xtext functionality in Xtend
Next Topic:Resolve proxies
Current Time: Sun Jul 20 19:40:28 EDT 2025
Powered by FUDForum. Page generated in 0.03297 seconds
