Home » Modeling » QVT-OML » Code Completion / Operations in QVT installation
Code Completion / Operations in QVT installation [message #870078] Sun, 06 May 2012 04:06 Go to next message
in the archive (google cache) I found this QVTo transformation:
modeltype entities "strict" uses entities('example.com/entities');
modeltype persistence "strict" uses persistence('example.com/persistence');
modeltype uml "strict" uses uml('www.eclipse.org/uml2/3.0.0/UML');
(link problem, so there is no ht...)
transformation swichprofile(in umlIn:entities, in persistenceProf:uml, out umlOut:persistence);
main() {
	-- copy root model(s)
	var _result := umlIn.rootObjects()[uml::Model].deepclone();
	_result[uml::Model]->forEach(model) {
		-- is "entities" Profile applied?
		if(model.getAppliedProfile('entities') <> null) then {
			-- remove application of "entities" profile
			model.unapplyProfile(model.getAppliedProfiles()![name='entities']);
			-- apply "persistence" profile instead
			model.applyProfile(persistenceProf.objectsOfType(uml::Profile)![name='persistence']);
		} endif;
	-- now transform "entity" stereotype applications
	umlIn.objectsOfType(entities::Entity).map toPersistent();
	_result;
mapping entities::Entity::toPersistent() : persistence::Persistent {
	persistent_name := self.table_name;
	-- figure out which class the stereotype should be applied to
	base_Class := umlOut.objectsOfType(uml::Class)![qualifiedName = self.base_Class.qualifiedName];
(BTW: This is of interest for the profile issue. The profile has to be part of the input models).
Back to my question:
Here we see a lot of operations:
model.getAppliedProfile()
model.unapplyProfile()
In my QVT installation I do not have these operations, even though I need them Smile I have only standard QVT operations like oclIsTypeOf etc. I have the same header (same metamodels). The posting was in the eclipse forum too, so I assume they had the same QVT installation. The posting was 2010 I think.
So whats wrong with my installation? Why do I not have alle these features?
Tex
Re: Code Completion / Operations in QVT installation [message #870116 is a reply to message #870078] Sun, 06 May 2012 13:10 Go to previous messageGo to next message
Code completion is often helpful but I would caution against relying on
it; it's difficult to ensure that everything is offered and nothing
extra is offered. Code completion is not particularly easy to test and
not high on developer's priorities. Even JDT is pretty ropey sometimes.
getAppliedProfile is part of the Eclipse MDT/UML2 API; something similar
might one day appear from OMG.
If you're using UML.ecore in compiled and registered form it should be
available.
Ed Willink
On 06/05/2012 09:07, Tex Iano wrote:
> main() {
> } endif;
> _result;
> need them :) I have only standard QVT operations like oclIsTypeOf etc.
> features?
> Regards,
> Tex
Re: Code Completion / Operations in QVT installation [message #870120 is a reply to message #870116] Sun, 06 May 2012 13:29 Go to previous messageGo to next message
Ed Willink a écrit :
Hi everybody,
Tex, will you publish your end configuration result
on the newsgroup ? This is my next step, I can see
that you are exactly doing what I want to do.
Regards.
Re: Code Completion / Operations in QVT installation [message #870155 is a reply to message #870120] Mon, 07 May 2012 01:22 Go to previous message
No idea what this message is about.
Ed Willink wrote nothing of the sort.
> Hi everybody,
> Regards.
Previous Topic:Access localPart of QName
Next Topic:[QVTo] UML 2 UML transform
Current Time: Sun Jul 20 09:54:53 EDT 2025
Powered by FUDForum. Page generated in 0.05527 seconds
